The 26650 Thread
Saw this Dongrui today at Manafont (never came across it before). Product page says it takes "1 x 18650/21660". What is a 21660? Do they mean 26650? It's also discussed here.
And don't forget the Fandyfire HD2010 discussed here, available here at DX.
Do 26650's fit in a Maglite C body? Require boring at all? What about length for (2) 26650's in a (2) C cell light?
-Garry
I'm curious about the 3 XML single 26650 lights that have been popping up on ebay (looks very similar to the beamtech bt4000 from Tmart). Curious enough in fact that I was bidding on one. Unfortunately the auction ended while I was on the road to the in-laws for dinner yesterday and I got outbid. Has anyone got one of these (or the one from Tmart)? I really like the idea of this light but it would be nice to know how hard the 3 XMLs are driven from a single cell.
There are some details of single xml version, it doesn't seem to be very well made, but may be considered as good beginning I think: https://budgetlightforum.com/t/-/5251#comment-105666
I already ordered some liquid to be able to weld aluminium to the driver, this driver pressing oring is not capable of high currents in my opinion, it should be solid welded. We do not know anything on driver, I suppose it may be the same as in 3x xml lamp, hope not, but have to be ready for it, looking now for best 1 cell driver capable of delivering enough power to 3 xml's :)
That looks very promising. I'm interested to see what you find in your search for a good driver.
OK, I got DONGRUI today, bought on ebay, it came in 10 days :) NICE! I will place photos and more, but at first glance, it is gunmetall coloured, coating is not very strong, original electronics sucks-2.7A by 4.2V and...1.5A by 3.6V :( Buuuut...I put my sandwiched Nanjg 105C at 3.8A and there is a new leader in my collection! Tight spot, a little blueish, but throws better than my TK35 modded clone and probably than Trustfire T1 XML T60 :) Reflector might be better coated, double orings, it is exactly 26650 size :) Heavy toy, but veeery nice, now I only wait for Shadow JM05, we will see if there is any difference. Anyway, I sell my C8 SST50, T1, this baby rocks :) More soon to come...
Eagerly awaiting full review with pics!
Oh, and can you provide a link for the Ebay seller?
-Garry
http://www.ebay.com/itm/160692798941?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
It cost more than Manafont, but I could see in my purchase history, that usually ebay sellers do have items on stock, as some shops don't.
Torch::
It came wrapped with protective stuff in an envelope. Inside there was 18650 to 26650 connverter. Outside I give 4+ in 5 degrees scale, it is anodised/covered with titanium/gunmetall colour. The cover is not very resistant to scratches, it came already with some and some point decoloured spots, it may be a problem in future. Reflector is not very well made, some stains on it etc.
Shape and form fits great in men hand, not too long, not to short, in spite of 47mm head it lies nicely in trousers pocket, you fell it more than C8 (44.6mm), but less than TK35clone (51-49mm). It has GITD switch, can do a candle mode without any problems, it came with things attached to end you can see on pictures.
Weight:
It is solid, big radiator, head of fat aluminium only with hole for ref and led pill. Exactly:
Dongrui - 281g
C8 - 213g
Klon TK35 - 336g
T1 - 401g
How it looks comparef to C8 SST50:
In parts:
Led cables are not bad, driver is pushed into messing ring and this is pressed into led aluminium pill. Unfortunately there are no holes to screw pill into head, I had to do it with spring and mcpcb holes.
Original driver (5 modes) showed by 3.6v only 1.5A at tail, by 4.2V it was 2.7A. Quite a lot of light. But not enough for me :) I put there sandwiched Nanjg 105C with 3.8A measured at the tail. Original driver looked like this:
After changing the driver my smile had to be removed by a surgeon ;) 37mm deep ref and almost 50mm diameter is focusing well! C8 SST50 is no competition to this light, so for comparism I took teoretically stronger 2 cell flashlights: moded to 2.8A XML TK35 clone and ordinary Trustfire T1 XML T60. All with good, fresh charged batteries went with me for a walk ;)
Don't look at first pictures at colours, my white balancewent wrong, cTK35 and Dongrui are Bluish, as T1 is quite warm.
Raw sample dark as in the ass picture:
T1:
Cloned TK35 modded:
Dongrui:
IMHO Dongrui throws nearly or better as T1,but it has more close light and thanks to that you can see things closer too. cTK is a flooder, lighter closer, dimmer further.
Now closer shots, unfortunatelly one is not sharp :(
T1:
Dongrui:
cTK35:
And now wall about 30m away:
Sample without anything:
Left Dongrui, right cTK35:
Left Dongrui, right T1:
Here colours and light power is perfect. In my opinion Dongui is veery similiar to T1, but difference in light colour may be fooling me. Anyway, I am very pleased with my new toys and I look forward to original (?) Shadow JM05 :)
To insert images, just click the "Insert/Edit Image" icon which looks like a boxed tree. Then paste the URL of your image in the "Image URL" entry. In the appearance tab you can set the size (tip I read - set the first dimension box to "100%" (including percent sign) and the image will resize relative to browser window size). I believe this is all you have to do. Be sure to leave off the "IMG" codes.
EDIT - Here's a thread on inserting photos.
Nice review! Sounds like I'll pass on this for the less expensive FandyFire HD2010 discussed here.
I am curious to hear, was it fairly easy to mod that TK35 clone? (ie. New driver install.) I thought that driver would be difficult to remove. My issue with that light is that from your beamshots it appears to be mostly flood, and I'm in search of maximum throw with useable spill along with max runtime. Do you have any posts concerning your TK35 clone mod to point me to?
Thanks,
Garry
Clone TK35 is sooooo easy to mod :) You just sandwich 0.2Ohm resistor over existing already 2 of them on the board :) But it is flooder, never will be a thrower I think. I thought of this HD2010, but 55mm reflector is quite big into the pocket, and for throw i have STL V6 :) You can mod it to 1 cell short version :)
I got 2 26650 lamps today. First JM05, it is better finished than dongrui, driver is better (3A @4v and 1.4A@ 3.2v), led is better, ref is better, hotspot is smaller, it will throw better, but less flood for sure.But driver stopped switching power :( It is always on high, I wait for Wang answer what now. Anyway, good lamp.
Second one is 3x XML single 26650 cell from ebay Uwelectronics (same host as HD2010). It has only 2.4A on fresh cell at tailcap, so it is not really bright one, driver seems to not very strong :) I will change it today I hope, anyway, more photos and reports later :)
Well crap. I'm pretty sure that's the same light as the Beamtech BT4000 that I ordered from Tmart. If you don't mind would you take pics and start a thread when you swap drivers? I have a feeling I'll be doing the same thing relatively soon.
Thanks,
Tony
Link? Can't even find that greedbay seller.
http://www.ebay.com/itm/260904008924?ru=http%3A%2F%2Fwww.ebay.com%3A80%2Fsch%2Fi.html%3F_from%3DR40%26_trksid%3Dp5197.m570.l1313%26_nkw%3D260904008924%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Flashlight is good quality outside, GITD,nice coating and colour. I almost don;t have any black flashlights due to recent trends now ;) Dropin poor quality, it doesn't have enough good contact to the rest of the body, driver is 20mm step up, 5 modes (low mode is not really low), 2.4A on fully charged cell, 1.35A on 3.2v, so it is not very bright at the moment. I have to switch leds to parallel and give some 5.5A AMC7135 driver and we will se what this baby can. Anyway it has big spill, so it will be a flooder.
Some photos:
Are you interested in selling the driver ?
Thank you very much for sharing these lights with the rest of us.
Your pictures look really good with a good sharp quality to them (I'm no photographer so maybe that is a silly term?)
But this is so interesting to follow, and by god you do a lot of mods! Yikes :-)
I can’t wait to see this one,I have this light and please show us how and what u do to it;)thanks patiently waiting
i’m vry interested i getting 18650/26650 lite, i’ve seen several and am wondering could the drivers be changed from 5 to 3 mode, could u change the emitter, and is it safe to assume that a 26650 lite would take a 18650 bat?
keygos m13
http://www.ebay.com/itm/26650-1800Lm-CREE-XM-L-XML-T6-LED-Flashlight-Torch-KEYGOS-M13-Charger-SET-/180796759614?pt=US_Flashlights&hash=item2a18539e3e
http://www.ebay.com/itm/26650-18650-1800Lm-CREE-XM-L-XML-T6-LED-Flashlight-Torch-KEYGOS-M13-/350524040835?pt=US_Flashlights&hash=item519cdc6683
with special xm-lt6 that is ~80% brighter than every other t6 lol
too bad that light is 2 cells only or I"d like it much more
