Nice Work!!! Thanks for sharing. You guys that do that are just tough!!! :+1:
TL
Well done, very nice finished light.
Thanks, nice compliment from you guys
Awesome sharing !! Thank you.
Looks like a new project for me
Now where can I find copper
CRX, your craftmanship skils never stop to amaze me! :+1:
cheapest copper I could find was in home DIY shops, like Home Depot, Lowes, … paid about 1.5 $ for a short copper pipe that should be good enough for 2 P60 dropins (if you’d follow this build or something similar).
copper rods on the other hand… are not necessarily available in the regular home repair shops. The home depot I went to didn’t have them.
Amazing work, love it :+1:
Thanks for the comments.
The host materials i got pretty much for free.
The outer tube is a scrap piece of plumbers pipe, the aluminium was a scrap cutting too. The copper slug sample cost a pound from -bay and the 17mm brass driver adapter ring can be found for pennies.
That is just nice clean work. PERIOD!!!… well, not quite PERIOD!!! It is BEAUTIFUL TOO. ok… now P E R I O D ! :heart_eyes:
TL.
Helloo-o-o-o China — steal this guy’s idea, clone this thing and sell it cheap ….
That would save me a lot of work
amazing…great job!
Question…sorry I’m a noob in modding. I wanted to build my own P60 quad since I can’t get a pre-built one in the specs I want. (and i can’t find any tutorial).
How’s the mcpcb secured to the pill? solder? Thermal adhesive?
thanks
Thanks :+1: .
I did not use solder to fix the MCPCB with this build as the copper slug and driver mount are soldered into the pipe and it would most likely have ended in disaster and tears if they moved any amount as the whole unit would need to be up to solder melting temperature - better to use the soldering technique on solid copper or brass pills.
It is the best although most difficult method.
I left the MCPCB loose for ease of future changes, it has arctic silver 5 thermal paste under it, this requires care when screwing the flashlight head down tight as you can twist & dislodge the wires from the board or driver. You would probably be better fixing it down with a small amount of thermal adhesive like arctic silver alumina two part epoxy or better.
Hope this helps and remember to show us your build when you get it done
what are the “control specs” of a p60 module, dimensions wide?
i mean, DIY copper p60s, tend to look straighter and longer than “stock”. and tend to be “all pill” as compared to stock, IE the “pill” takes over the outside dimensions of the reflector, too.
whats the “blueprint”, the “specs”… or, do you just “wing it” and make a custom fit??
This one is a custom fit for the light it is used in, i only have one p60 type light so couldn’t tell you if it would fit another - probably the reason why the normal ones are so loose. I didn’t even bother taking any measurements from the stock one to transfer over.
I suppose a slightly shorter length and the use of a spring would be a good idea for interchangeable units.
I guess i could see about getting one custom into my 501 empty host i found, lol… then go from there.
it just stands to reason, though, that when a standard exists, even a de-facto standard? there should be some specs SOMEwhere for it, you know?
I’m sure there is, read it somewhere ages ago, i think…
to CRX…
yes, thats my memory tickling ME too, it seems like i remember SEEING a blueprint of one before. just cant remember where…
Just saw this; very impressive build and skills. :+1:
