Donāt forget they also filled them with some of that left over contaminated Chinese drywall.
I have taken some ebay cells apart that were given to me as part of a trade.
They felt stupid lightweight. It had āUltra Fireā on the label. I knew soon as I picked them up they were fakes. Once apart, there was a freaking small capacitor in it! Talk about a scam job.
I keep a small scale and weigh suspect cells. There can be a several gram difference between the scams & authentic cells. One good way to get a idea is get you some quality laptop pulls. Those are unprotected flattops. Compare the weight of them to your āProtecteā āFireā cells.
Scary stuff out there.
This is why I only buy cells from reputable dealers.
Some what yes. Only if you are dealing with name brands. Its also good if you buy a few cells to see how much they weight compared to each other. If they are the same brand and make you may be able to tell which one has more capacity. BLF members done this with the Basin 26650s to see if they where from the same batches.
The Chinese communist government I hear is really good at throwing propaganda at the Chinese people (who canāt get outside news) and so I wonder if they do this to USA bound stuff more often?
I wish the USA could get back to making more of itās own stuff.
Weight is just one factor- look for any anomalies and if you find any, look deeper. Thereās no non-destructive way to know whatās in a cell. The only reliable method of knowing what you have is electrically testing the cell, usually done with an analyzing charger
if you order cells from a not fully trusted vendor (trusted, like RMM, and others) or a vendor in China who had no idea what is actually shipped or sold (like many on AliExpress) that is advertised as being an A brand cell, weight certainly is something that can give away if it is fake.
Also when presenting your case to AliExpress or paypal, it is good to be able to show a much lighter cell then the official specs state for example. (I must be really lucky, only the no name or Ultrafire cells I received were poor in terms of low mAh and higher internal resistance, all branded ones tested OK so I have not disputed cells)
Getting a charger that does just a little more then charging (for example, my Littokala Li500 for $15 shipped without adapter) can give you some more info, they may be not all that good at giving you a 100% result on internal resistance and mAh but using the same charger on all cells surely give you a good idea on those things and also over time, since the faults are present in each measuring, a decline in mAh or elevation of internal resistance can be seen easy.
And well for $15 having a quad bay charger capable of charging a lot of different cells is a good deal in itself IMHO
Edit clarified a bit
Donāt feel bad āRichardinNCā, I thought the same thing until I reread it 3 or 4 times.
I think (hopefully), that CRX has the correct answer. :+1: ā¦
@CRX: Thanks for posting those picts. When Ricflair told about a small capacitor inside an hollow cell i had a hard time to believe it - no offense intended. Such a blatant scam is mind boggling.
Lol clarified, when posting I was certain it was clear, but well donāt want people reading it several times before getting it, its just that BLFers usually and generally seem rather smart, keen and sharp
If it is too light, it is definitely weak in all areas. (Talking to you, āUltraFireā, though Iām sure others perpetrate this too, I have at least one light/verified crappy UF*)
If I remember correctly, it is like 20g too light.
But as others pointed out, itās pretty cheap to add sand, so that doesnāt work.
And a battery that is good but old, will be weak but not weigh any less.
Amazing posts! Thanks for the photos. I sure am learning a lot here.
So tell me, when they put a capacitor inside a battery like that, what will the test results be from a charge/discharge test?
I mean, I assume it will have less capacity, but by how much?
In other words, could I have a battery that seems to test reasonably close to expected results, but still only have a capacitor inside?
And if it tests reasonably close, whatās the problem?
Sorry if these are noob questionsā¦.but Iām a battery noob
Oh, and maybe (again, Iām a noob so this could be silly) butā¦ā¦
Why couldnāt a chart of some sort be created listing what the average or expected weight range might be for different cells of different capacities?
For example, shouldnāt the weight of an authentic18650 of 2400mAh capacity fall in a certain range since it also claims to be Li-Ion chemistry?
My thinking being that if itās the chemistry it claims (inside) the weight of that capacity for a given chemistry āshouldā be fairly uniform?
For example, I just weighed an UltraFire 18650 that claims 5000mAh (lol) and weighs 35 grams.
Iād bet the weight of a real 3400mAh 18650 weighs more than that.
Granted, a smart Chinese battery faker (vs an authentic battery maker) will add sand or whatever to make up the difference, but maybe a lot of Chinese fakers are also lazy fakers and donāt do that?
So at least in some cases, a quick weight comparison could be handy in cases where the faker didnāt fake good enough?
Finally, if you shake a battery and can feel the weight shiting or hear movement, itās probably a good bet you got a fake right? lol
I donāt think itās capacitors being used, just very small lipo cells with capacity anywhere around 100 - 300mAh judging by the sizes so maybe 5-10% stated capacity if youāre lucky :laughing:
I just bought a 10 pack of cheap cheap UltraFire 18650ās ($1.00 each) off of ebay and I guess I got lucky because they all consistently tested at 700mAh which is at least usable in my small 1000lm Cree flashlights.
