thanks for quad optics,spacers.it fit,its ok.soon i will order next batch:))
1 copper B-158 pill. $14
1 led link 35mm punch optic. $ 3
1 shipping under 100g $ 6
Total $23
If this correct please pm and I’ll send payment and address. Thanks. Any chance you’ll do more A6 pills (as in your avatar)? They may not make sense but they sure look good.
The parcel has been received today.
Very nice, Thanks
Got the two P60 pills today thank you!
Bought one of his quads off e-bay months ago. It sat for a long time awaiting other parts. When I finally went to assemble it (still in original packaging), found the domes off 3 of the emitters and one of the emitters damaged. Tried to work with him through ebay but he refused to do anything. That’s pretty poor customer service.
Those who have real problems and use other way to communicate, we fix them asap.
Cheaters that cant provide any proofs for three month can go their way.
Wtf :person_facepalming:
Picked my S2+ triple pill and optics up from the post office yesterday, great packaging, complete with a handy storage box
Screws into my existing S2+ host fine and the LD-3 driver fits nicely, although I may have to shave a little off the retaining ring to get a bit more clearance on the moonlight components (not a problem with the ring, just my choice of driver ).
Just need the green host and triple 219C to arrive now!
Kiriba, you may want to change the S3 inclusion from these threaded spacers. Current S3 have the integrated shelf for the emitter. Or include (Old Version)
Will work in the new S3 with integrated shelf but without a glass lens.
Still working on my copper collection from you. May make another order when the M2 Quad are back. Some nice new additions.
Yep, I had this message (Old Version) on ebay, have lost it moving here.
Not sure about spacer. Convoys have 2 reflector dimentions and S3 should have similar one to S2+. Need more feedback (some members have bought this spacers in 5-10pcs quantity, Im sure somebody else have mod his S3).
IIRC the S3 reflector is between the S2 and S2+ depth. I don’t have one anymore though so I can’t find out for sure.
Simon is selling reflectors for S2+/S3 20*12mm.
Maybe he changed it when he went to the integrated shelf, the one I used to have was the old version with a pill.
measured all my S2+ and my S3 reflector and all measure to 11.6mm
My S3 was bought recently as a Host, it is the integrated shelf Flat Balck new version.
11.6+1.2(center ring)+1.0(stock pcb)=13.8mm
7.2(spacer)+1.8(triple pcb)+6.0(optics)=15.0mm
Can anybody confirm any issues with Convoy triple builds?
I still have 3 of your standard Copper S2+ spacers, all measure 7.15mm, 7.17mm, 7.19mm
Noctigon DTP MCPCB is what is widely used in single and triple build
Here are pics of stacks I mocked for measurement.
Noctigon single XM-L with emitter and reflector spacer, S2+/S3 reflector and Stock Glass.
Noctigon Triple, your Carclo Quad and S2+ spacer
Noctigon Triple, your Carclo Quad and S2+ spacer and stock Glass
The stack without Glass works fine in the S3 Triple. Just the threads on the Stainless bezel to hold it together, only has a couple threads. I can not get it to start with Glass on top. I have no problem here just want to inform with my findings on currently made Hosts.
Also the S2+ spacer used in the measuring is the 7.15mm high. It has already been Lapped into the head of the S3 to make full contact and the top has been wet sanded Flat on glass surface. So material has been removed in head, on bottom and top of the copper.
Thanks for the info.
I can just suppose that hosts with integrated shelf are still rare in combination with triple, that`s why nobody have found it out earlier.
I need to check triple sets from KD height and make decision about required spacer height.
i have triple xpl and also nichia sets,if you need height…also on the new copper board…
Yes, please measure height (without extra legs length).
