Behold the Megazoomie!
Came across this on Aliexpress, surely the biggest zoomie? Linky
Any of you guys seen or used this monster?
That looks like a fun light. The lens seems not larger (or just a fraction) than the (60mm diameter) lens of the Uniquefire UF1405.
Yes it does look like fun! According to the info the lens is roughly 73mm - seems to be several colours too (light).
It depends on what dimension the 73mm is referring to, I interpreted it as the outside diameter of the lens holder. But you could be right too.
Looks like a big thermos bottle…. and a lot of fun. Although this version here has the LEDs arranged off center axis. Not sure how this affects die focus… probably not good.
https://www.aliexpress.com/item/Portable-Spotlight-4-Color-Lamp-Zoomable-Rechargeable-30W-T6-LED-Flashlight-Fishing-Hiking-Caving-LED-Night/32690205712.html?spm=2114.10010108.1000014.4.Q1Upqp&scm=1007.13338.50051.0&pvid=98d0d304-1acc-4a08-8d72-f1347d1b5327&tpp=1
Here’s a non-aspheric version…. that looks like it has two business ends… and 9 (!!!) 18650 cells.
https://www.aliexpress.com/item/SKYFIRE-Fishing-lights-searchlights-flashlights-can-be-hunting-fishing-lighting-unique-focusable-30W-3000-lumens/32728371224.html?spm=2114.10010108.1000013.4.7hYY5C&scm=1007.13339.60109.0&pvid=36a13d7d-3c23-4157-a1d0-b8e888a7782e&tpp=1
So what LEDs are inside
a RGBW Cree chip wont be close to 30W advertised
Probably 4 separate emitters on a star like this?
I would love to see what this is capable of
