The charger has a standard 12V DC connector. You can just buy a 12V AC adapter with the desired line cord/plug as long as it can output at least 3 amps at 12V. Because of the issues on the V2.0, I actually use a 6 amp AC adapter, and that solves the problems that v2.1 fixed. The problem is that the charger basically uses PWM to charge, so during the charge cycle the peak current is a lot more than the average current, and the original 3 amp supply didn’t have enough output to provide the peak current required. A larger power supply solves that problem.
Hmmm? OK, but do you have any specs from an operation manual to show that the 3100 works with 'C' batteries? All the specs I have read on the 3100 do not list 'C' batteries as being compatible, but they list 'C' batteries in the specs of the 3400 as being compatible.
Nevertheless, do you have a pic showing real capacity with mAh with the exact same batteries in the test mode?
I think the question here is that if the 3100 was apparently not designed to work with 'C' batteries but does appear to be working with 'C' batteries, is it really working properly with 'C' batteries?
I'd love to see a pic with those same exact 2000 mAh batteries showing the mAh real capacity in the test mode. This would be very convincing that the 3100 works properly with 'C' batteries even though it wasn't apparently designed to work with 'C' batteries.
By the way, have you been able to get it to test for mAh real capacity with 'D' batteries?
And, to advance this discussion to the reported v3.1, this is the difference:
This is a customer made model. We changed some function like voltage for termination is changed to voltage with load condition, and discharge termination voltage is changed to a higher level to prevent charger from triggering protection for cells with protection.
I am guessing by your username that you are into eating right.
As you already know I’m sure, you can’t always believe what’s inside the package no matter what it says on the outside.
OK, I just had a little fun.
One legitimate concern could be that if one tries to charge a “C” or “D” cell that has too high of a capacity, the delta V voltage may be missed by the hardware. In order to detect the delta V, the recommended charging current for NiMH cells is approximately 1/2 C where C is the mAh capacity.
The OPUS will charge at a maximum of 2000 mA if only the 2 outer banks. Perhaps charging a 10,000 mAh “C” cell at 2000 mA is too low to enable the OPUS to detect the delta V point. I would assume there would be a secondary point of shutdown, perhaps as simple as a maximum measured voltage across the cell.
There probably was a time, well over a decade ago, when Delta -V charge termination required 1/2 C charge rate with some cell and charger combinations, but for any decent modern charger, and after battery capacity went up too, that’s rarely if ever the case. Most can detect fine at 1/4 C and some, lower still. I doubt you could even find one today that can’t do 1/3C unless it was just a defective design, some generic clone/garbage/whatever.
Consider 2600mAh NiMH AA cells. How many people are using 1300mA rate capable chargers outside of flashlight junkies and the R/C crowd? They really shouldn’t even if they could as cell impedance may be higher to achieve the higher capacity in the same cell form factor. A charger capable of 1300mA ought to have a cell temp shutdown sensor and might end up using it.
This is Thomas and I just registered, as I will need your valuable help for an issue that I have a BT-C3100 unit.
I bought it 1 year ago from Chinese reseller everbuying, after I had seen all the good reviews about this model.
I am charging mainly AAA batteries and it was doing its job quite good, until a few weeks ago.
Suddenly the unit started behaving really funny. Sometimes, even if there were 1-2 batteries inside the slots, the readings were not working properly and were showing null after a few minutes.
Or other times, the screen was stopping responding at the buttons, when I was trying to change the screen readings.
Also, the fan is not moving any more. I don’t remember if it should start working since the first second that you enter a battery for charging or it starts after a few minutes though.
I have read most of the other comments and I couldn’t find any similar behavior, which is really strange. And I don’t know what to think about these problems. Is the unit faulty or maybe there is an issue with the power supply, although the screen never stopped being on so far.
I dont have any help for most of your problems but one of mine became very noisy and the fan was “sticking”. I took it apart in a matter of minutes and gave the fan a good whack and it’s working fine again now.
I’m tempted to put a better fan on mine as the fan really is noisy and annoying!
GearBest is the worst company I have ever dealt with. A better name for this company is GearWorst. If I had known they were a Chinese company before I ordered, I would have never ordered from them, but they fooled me by offering me PayPal for my payment. Chinese company policies are very different than US company policies. They don’t care about their customers in China. They just want your money.
This is nothing more than a scam company. After sending me an $85 defective XTAR Dragon Plus charger, they said I could keep the defective item and they would refund me $15. WTF, and here’s the punchline. They will only refund me credit to be used when I buy another item. My refund goes into my GB Wallet. Who in their right mind treats their customers like this? I’ll tell you who. Scam companies in China!
I will never do business with GearBest again. I went to a GearBest review site and found hundreds of similar complaints about this company. Don’t believe the fake positive reviews or the employees. They are lying. I wish you the best of luck should you choose to do business with this scam company.
Fans issues are known with this unit they give out eventually and it has thermal shutdown if it gets to 60c inside it cuts current not much higher the system shuts down until it cools enough. With your fan not working might be something thermal GearBest sells replacement fans for under $2 I bought a couple a week or so ago just to have on hand. To me its s great charger even if I have to change a fan occasionally no big deal takes 5-10 minutes
