All of the drivers before the Q8 and Texas Avenger have the voltage spike issue, it was an issue all along, we just didn’t notice it with the tiny13 because it had a lot more tolerance for it.
After DEL figured it out on the Q8 driver the ones since then have the new components that fix this issue.
The MTN FET+1 is a middle ground, it still has the spiking issues but it is bled off with a zener.
Nah, C1 is still 10uF. You can see the TA driver with the link in my sig but basically the small 4.7ohm resistor before the diode/C1 is the most important thing to eliminate the spike. Then adding C2 smooths out the last little bit.
Adding R4 and R3 to the FET reduces the feedback and helps reduce the spike before it starts as well.
That’s interesting about the driver mods to fix the turbo>moonlight bug. My S41 exhibits this behavior as well (2nd production run, presumably not Manker) but I usually don’t leave the light in turbo the full time and notice the bug when I go to backstep to level 6 manually.
I do have a question that I haven’t seen mentioned yet (please forgive me if I missed it, I haven’t yet read the first 30% of the thread!).
On the S41SC, I saw that the colors are due to a heat treatment. What effect does the heat treatment have on hardness of the corrosion-resistant steel? Did they let the colors run and then quench? If so would it be safe to assume the hardness is across the board depending on location on the light? Or is something else going on here?
How would this hardness compare to the hardness of the (un-colored) S41S?
I don’t think it is really heat treated… We talked about it somewhere in the first pages of this thread. It is likely some sort of ‘rainbow finish’ similar to anodizing. They call it ‘colored’. There’s a name for it that i don’t remember right away. We’ve seen this finish on a number of mechanical ecig mods and parts one or two years ago. What gives it away are the too vivid colors, especially the green that is not part of heated steel color ‘spectrum’.
Thus it should behave the same as the plain SS version except there is a coating… No idea how resilient it is.
Can anyone confirm that the BLF A6/Astrolux S1 18650 Body Tube fits on this Astrolux S41S Stainless Steel New Version A6 Head? mattjk post #607 indicates it does. Thanks!
Just tried my Astrolux S1 & BLF A6 into the newest version S41S.
Heads, tubes and tails all fit each other, As do all the S41 parts into all the above.
A quick and cheap weight reduction is the S41 aluminum tube. Don’t like the black, strip the anno.
Sorry can I just ask, if I get this with the 18650 tube, will I be able to get the best from it using a protected 18650? Or will I have to use an unprotected battery? If I use a protected battery, what will the results be?
For what i understand, when in turbo mode, the leds are drawing current from the battery without restriction and that generally induce a high current and the corresponding higher output. With a protected cell there are chances the protection will trip on turbo and the light will shut down until the battery protection resets itself. For best performance you’d want an unprotected high drain cell - 30Q for instance. But that only affects turbo mode.
My $25.70 S41S came in today and like the others it is the latest model with updated head and no glue.
It is a great little light, very nice looking and heavy. Only real complaint would be the overly aggressive grip. I am thinking about using some sandpaper to take the edge off, anyone tried that?
Makes a bit over 3000 lumens with a 30Q 18650 and the XP-G3. I plan to swap it out for 219C 90+ CRI LED’s.
VERY happy for the price, glad I grabbed it while I could.
Not yet, but i’m planning to do that too.
Will have to make a make shift lathe and use wet paper.
Hope it’ll work out good.
Unfortunately i didn’t…
I have the XP-G3 version too.
It’s stupid bright with VTC5. Considerably brighter than with Enercig or Keeppower 18350.
Did put in a fat switch and shortened the leads to the MCPCB.
Also opened up the bezel so the optics aren’t shrouded anymore.
(edit) Just took a grainy picture (without flash):
