Haikelite mt03 mods? Update!
156 posts / 0 new
hannesremo
Last seen: 4 years 3 weeks ago
Hey guys! Does any of you know how I could go about increasing the output of the mt03? I thought about direct drive but don’t know. I know it can be done but how?
Soldered on 6 extra r100 resistors. Have to do some testing to see if it got any brighter! Atlest got warm quicker!
Edited by: hannesremo on 01/13/2017 - 14:05
keithd
keithd's picture
Last seen: 1 year 11 months ago
Is yours 4S1P or 2S2P?
If it’s 4S like mine, you can’t do direct drive unless you modify the battery carrier I believe.
hannesremo
4s as in 4 cell?
hannesremo
oh you mean 2 in parallel 2 in series, or 4in series?
Mine has 2 in parallel and 2 in series
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 10 hours 39 min ago
Mine the one in the video is 2P2S so 2 cell are parallel and 2 cells are series. 6 volts total
The newer lights where 4S so 4 series they are having issues apparently. 16 volts total
How is your output?
hannesremo
Hey! 2s2p, technically 8,4v when fully charged
Yea 8.4 fully charged or 7.4 nominal volts. Well you got the 2s2p? Thats good then. How is the output?
hannesremo
Have to probably measure it on turbo mode, with a welding mask on lol. So if I would get 8,4 that tells me that turbo is dd right? If it’s less and the batteries are full at 8,4v or 4,2 each, that means that it’s not dd, iow, the driver limits the output. Have to see what it says. Looks to be 3 leds in parallel though. Will measure it when I get home.
hannesremo
however I suspect it’s limited since maybe 9000 at turbo, and afaik, xhp’s can do 5000 lm each?
Stock its not Direct drive. Its about 3.7amps per LED at the LEDs so total amperage is 11amps at the LED maybe a little more. You can get more out of it but it will get hot quick. It should be about 10000+ lumens if its working correct. It will drop down after a while.
hannesremo
Tell me how ! Master I must know!
No but seriously, maybe drilling and put + to the spring and – where ever it goes, I’m guessing the outer ring? I will make it dd, if I don’t like it I could always revert to stock again. Or is there a way to keep other modes? maybe a smaller driver along side?
hannesremo
perhaps remove or change out the current limiting resistors?
hannesremo
Ok, so I think I know, I need to have 3 separate drivers, in parallel, so each driver gets 8,4v. Then if each driver is 5A, each led gets 5A.
I would think the sense driver would be the safest way. When Haikelite where built the MT03 they put the current up but said it gets to hot for the performance increase. I have a written review on here where you can see the driver. Actually i will find the picture. I would have to sit and look over the driver properly i left it because 10k lumens is enough for me but it can be increased easy.
You also risk burning out other components.
!DSC_1248!
I am not sure about this direct drive but you could get more amps maybe even up to 15amps total easily.
hannesremo
how about the triple independent drivers in parallel i suggested? check my earlier post ok?
Yea you could i have seen it done. You could also go for one good FET? Even the standard BLF A6 FET driver can handle 10+ amps i think. So a better quality FET will have no issues.
hannesremo
Do you know any good ones then, maybe the fx6? Tired of my questions yet?
hannesremo
are those big boxes current limitors or which ones?
I would have to have a look properly but the R resistors are the current limiting resistors. I would say the 3 sets of the R100s
You can basically piggy back a 17mm FET onto this board. Heaps of people with Triple or quad Nichia get high amps from a single FET. The bigger the FET the better it is for heat.
hannesremo
hm, could I use the fx6 driver at 5amps, and all the leds in parallel? Would all 3 drivers then get 5 amps each from this one driver? or would I need one driver for each? I would expect some drop in current per 3 leds, even though they are in prll?
hannesremo
one fet powering 3 xhp70 in parallel?
giorgoskok
giorgoskok's picture
Last seen: 1 year 1 month ago
I’m planning a driver swap in one , after i receive 2 resistors .
I will install a Fet driver with Narsil firmware .
hannesremo
one driver powering all 3 in parallel?
Nah one driver in parallel 5amps will between all 3 LEDS. If you put had a series config they will have more amps each.
giorgoskok
Yes , all in parallel .
everydaysurvivalgear i think you are not completely right . It can easily achieve over 5 amps per led , i’m hoping for a result between 14-15k lumens based on existing builds numbers . Just my point of view from existing triple xh70 + fet with 2s2p builds .
Edit : I agree that in series amperage will be higher , but in parallel it won’t be as low as 5 amps per xhp70 .
I Said the original driver can get more amps probably 15 total. But he wants to use a single 5amp driver to to power all LEDS in parallel that wont supply 5amps each?
giorgoskok
Edited my previous post.
I was talking for fet driver , in my post . Sorry
Ah yea sorry mate. People where saying the BLF X6 driver has issues over 10 amps? The older A6 driver will do over that. What driver did you buy? Why not mod the stock driver? Any reason you chose to FET over this driver?
hannesremo
Those are for my xhp50 projects, but I could use one of the fx6 drivers, I ordered. I ordered the ld-3 at 4-6 amps, and fx6 5 amps, 2 of each. Any Ideas how to mod the stock driver though?
hannesremo
probably not quite, but near.
hannesremo
Are you talking about the 3 drivers that would supply 5A ?
If so, then that’s what I was thinking. Don’t parallel supply the same to each? But if you connect them in series, the current would be distribued evenly. Say 30 amps on series will be 10A per led, and in parallel, close to 30 to all example?
