Ah yea sorry mate. People where saying the BLF X6 driver has issues over 10 amps? The older A6 driver will do over that. What driver did you buy? Why not mod the stock driver? Any reason you chose to FET over this driver?
Those are for my xhp50 projects, but I could use one of the fx6 drivers, I ordered. I ordered the ld-3 at 4-6 amps, and fx6 5 amps, 2 of each. Any Ideas how to mod the stock driver though?
probably not quite, but near.
Are you talking about the 3 drivers that would supply 5A ?
If so, then that’s what I was thinking. Don’t parallel supply the same to each? But if you connect them in series, the current would be distribued evenly. Say 30 amps on series will be 10A per led, and in parallel, close to 30 to all example?
I will build my one , with Texas Avenger boards . I use the 22mm boards , with LDO : Texas Avenger "TA" Driver series - Triple channel + Bistro or Narsil + Clicky or E-switch - The Ultimate open source driver!
One main reason was Narsil it self , i really like it .
In series the same current would go through all of the leds , total current will be equal to the current of each one xhp70 .
In parallel , if total current is 30 amps , it will be distributed equally , 10 amps to each led .
For a build like that , you need to mod stock driver (probably a resistor mod) , or use a fet driver (leds in parallel , current will be as high as batteries can give , and leds’ Vf allow ) .
In a series circuit, the current through each of the components is the same, and the voltage across the circuit is the sum of the voltages across each component In a parallel circuit, the voltage across each of the components is the same, and the total current is the sum of the currents through each component.
Getting a bit confused here to say the least lol. So I would connect them together in parallel preferably?
Maybe 5 is enough?
Yea basically but remember these are 6 volts LEDs so you need 2 batteries in series to make the 6 volt led work and 2 batteries in parallel.
The drivers will be connected in parallel if using more then one.
Amperage wise from the driver you want at least 15 amps. In a parallel circuit each led will receive 5 amps. So for the 3 the total 15 amps. That may give you around 12000- 13000 lumens.
that’s whatbI mean, it comes in 2s2p configuration from factory.
So then it gets 6v+. And all in parallel to achieve 5 ish A.
But is one driver enough, or do ai need 3?
what? huh?
If you are using the the 5 amp drivers you will need 3 to get 15 amps. And some panadol lol
I bet a major headache.
Maybe you travel to Finland, and do it for me eh?
And I’m studying to become an electrician. I had a hard time understanding lol. Don’t look good for me huh?
Just go with a fet or mod the current driver first. You can buy resistors for cheap. It’s easy to do it just get confusing to talk about lol.
Yeah will have to sleep on it!
What a soup huh? We all talked at the same time?
Hahaha yea. usually I’m half on here and playing battlefield at the same time lol
This seems the easiest route and you can then report to us on your results. I don't think anyone here has tried it yet. You don't have to remove the stock resistors. Just stack additional resistors on top to lower resistance. I prefer to solder a wire to each end the bank and then swap resistors at the wire ends. Much easier and less heat stress to the driver.
