Yea it would be but it would be a pain to install. Plus then you lose mass for heat absorption. You could place it around the tripod hole.
Few people have done this mod on other lights there are some threads on here.
I woke up a few hours ago its 11am here now.
hannesremo
(hannesremo)
January 14, 2017, 12:09am
83
That placement was my original plan, maybe an extra hole for a temp sensor aswell!
hannesremo
(hannesremo)
January 14, 2017, 12:10am
84
btw my Hg2’s only pulled 4 amps on the thorfire blf drive, weird huh?
hannesremo
(hannesremo)
January 14, 2017, 12:14am
85
maybe make an output jack, one for temp and one for voltage and just plug the display in when checking, remove it after.
Stock it has a timed temp check or just a general timed stepdown. After 2.5 minutes it (might) check the temp and steps down. If one were to reengage turbo after the stepdown it will not stepdown again until the time has passed. Assuming nothing is damaged by modifying the output it will likely overheat well before the timed check.
There is no constant temperature monitoring like in an X7.
Yea it does check the LED temp if its over 60 degrees it wont allow the light to step up apparently. Its not constant monitoring.
I am not sure about the 4s driver.
The reading your getting of amps is held back by your stock Multimeter leads. You need thick gauge shorter wires to plug into the Multimeter.
everydaysurvivalgear:
I didn’t check led temp or stepping up after 60 degrees, but it will definitely go well over 60 degrees on the exterior if you re-engage turbo after the stepdown or presumably if you modify the output, depending on how much it was modified it may overheat even before the initial timer.
hannesremo
(hannesremo)
January 14, 2017, 8:26am
89
Good morningnyou still on here?
hannesremo
(hannesremo)
January 14, 2017, 8:27am
90
Shpuld be fine it’s a Mastech my74
hannesremo
(hannesremo)
January 14, 2017, 8:29am
91
that is why I want a temp display of some sort
hannesremo
(hannesremo)
January 14, 2017, 10:50am
92
Tried to remove the resistors completely on my other Mt03, didn’t turn on then. Will probably do the added resistors on that one too.
Did you leave solder to bridge the connection?
hannesremo
(hannesremo)
January 14, 2017, 12:48pm
94
No, bit accidentally broke one of the fet pins! So the second mt03 needs a new driver maybe?
Hmmm lol
Does it turn on?
Can you take a picture?
hannesremo
(hannesremo)
January 14, 2017, 1:09pm
96
Try and solder a bridge across the broken leg? Use a piece of wire then solder on top of that?
hannesremo
(hannesremo)
January 14, 2017, 1:26pm
99
you mean a bridgebon the board?
Maybe easier to just solder it to some wires to lift it up a bit. The pins like to stick together with solder!
hannesremo
(hannesremo)
January 14, 2017, 1:29pm
100
Too broken, chip can’t be soldered, I got some other similar looking ones, but might be other functions!
Yea try that.
If its only only one leg of the FET you may be able to use it still and make a connection with solder and wire.
