I did get a few items in from Elfie, but not my S41S yet.
The Astrolux lighted tail switches for $1.31ea, 18650 tubes for S41 and S41S. Astro holster for $1.60
Good deal! I’m getting $26 (w/coupon) for the new version head alone.
Any thought on the tint of the XP-G3 being shipped now? Just curious why you didn’t opt for the stock 219 version BG offers. Is it the 219B rather than 219C?
Also, has anyone modded this head to have a combination of (2) XP-G3 and (2) 219 leds? Seems like a way to get the lumens and the high CRI in one light.
Yeah, that was quite the flash deal indeed, I knew it would not last long. If I had had the funds I would have got a few more.
The XP-G3 tint is cold for sure, I would say something like a 1A tint. Way too cold for my liking, once you go 90CRI you simply don’t go back.
I didn’t get the 219 version for a few reasons, first it is the 219B. I am not a fan of the 219B, also for a few reasons. First the lumen output is just too low even if it has a good tint, just not worth the sacrifice. Second the die is too large and it makes the beam floody further reducing the beam intensity. Last the 219B can’t handle nearly as much power as modern LED’s nor can it pull as much power due to the higher Vf.
The 219B that comes in these is also said to have a bit of a green tint and it is questionable if it is truly a 90CRI from what some said.
Lastly the XP-G3 version was cheaper and since I planned to swap LED’s anyways why spend more. The 219C 90+ CRI 4000K is a truly amazing LED when it comes to tint, I have it in I would say half of my flashlights now. Not the highest output LED but it is enough to be worth the tradeoff for the better tint and CRI.
Mixing the XP-G3 and 219C could be done but it would not really do anything. Better off with 4x 219C but I will be better armed to answer that after I swap the LED’s in mine. My other S41 has XP-G3 90CRI mixed tint LED’s in it and it is already good and puts out around 3500 lumens but I think the 219C will be better.
Havnt received mine yet, but great that it is the new version! I asked the seller directly and copied his answer here earlier. He said it was the old version. I don’t think he really knew but it is nice he didn’t guess to his advantage. Hope I didn’t steer anyone away from the deal…
I bought the 219b version of this light because I knew I wouldn’t like the XP-G3 tint. But just as I feared, the 219b’s sagged like crazy, just not the output level I wanted from the light. Don’t get me wrong — I definitely do like 219b’s in certain applications, but it just wasn’t right for this light. So mine got 4000K 219c’s almost immediately, along with an upgrade to a Bistro driver for the temp regulation and better programmability. Its fantastic now, love it. Too bad it wasn’t offered in this configuration from the factory.
Much better now…
Cut the tops off the knurling with a hand file. Only removed the head and went at it. Pretty easy to keep it moving and avoid flat spots. Also easy to see the size of the squares you are making to keep it uniform.
Lots of good info there. Thank you. As I haven’t yet modded leds in any of my lights I’m now thinking to hold off on purchase of a quad set up until the 219C factory-installed is available. I have 219A & 219B in a couple lights & appreciate how red hues are brought out. Unfortunately they are not so bright.
Basic double cut half round Nicholson. Good files but nothing special. Used the flat side of course…
Finished it with a finer single cut flat file. Used 400 grit wet on a sanding block to get it uniform finish.
All by hand, not spinning, took about 20min. Rotate the file over the circumference slightly as you go. Knurling is high enough not to hit the other surfaces. Metal is pretty soft, annealed. You will see the squares appear as you go. Look closely and see they are pretty much the same size. Small squares, remove more in that area.
I’ve got a S41S on the way. The emitter decision was difficult, but I went with 219B in the end because I just can’t stand cooler tints. Really itching to swap in some 219C D320’s* for better efficiency and output. Not sure if I want to try my first reflow or if I just pick up a TPAD+Carclo from MTN. Any definitive results on that combo with the updated head?
*I know these aren’t the High CRI. I’ve tried High CRI, but they just don’t do anything special for my eyes. I’ve been wondering if that’s related to my colorblindness. I’m not very sensitive to reds.
I have the white/green EagleTac 3400mAh batteries, and I bought a fair few back when I did buy them. HKJ tests them to trip at 6.4A, I assume this is too low?
I kind of doubt that you will see 219C options in these anytime soon but I could be wrong. Far as I know Astrolux doesn’t have any lights using the 219C right now and it would not make a lot of sense to get them just for this light.
Last I heard Manker and Astrolux are not friends, like at all lol. Still it is possible they will offer them with 219C’s I suppose.
I just finished modding my S41S (well except for sanding the body).
Swapped the LED’s to 219C 4000K 90+ CRI, used a Texas Avenger driver with bleeder resistor and 20AWG wires. “Activated” the lighted tailcap with a pair of 22k ohm resistors and 2x white 0805 LED’s added some arctic silver and put it back together.
It is VERY nice, like really really nice!
The optics mix the tint very well and give a very nice beam. The 219C die is much smaller then, well everything on the market today. So it also have a noticeable hot spot now and a ream beam.
This is also the highest current single cell light I have, with a 30Q it is 20A, HE2 it is 22A and a efest 18350 it still pulls 8.6A. Compare that to my mixed tint XP-G3 version that pulls about 4A less (but makes about the same amount of lumens due to being more efficient).
Speaking of lumens it is not bad there either. With the 30Q it is making around 3300 lumens and with the 18350 it is still a bit over 2000 lumens. Although with the 30Q it is completely impractical in turbo, 10 second and it is hot, 30 seconds and it is scald you hot. Luckily the TA driver has a regulated mid range mode that works well.
The white lighted tailcap also looks quite nice, I considered building one of PD’s tailcaps for it but just didn’t want to take the time, this setup is not as efficient but it works fine.
Overall I am totally happy with the outcome, Just need to sand down that grip
Just got my s41s from that flash sale a few pages back. It is the newest version, no glue on head.
Interestingly, the knurling on the body is flat without the peaks but the tail cap has the peaks and is very aggressive. I may do something similar to vwpieces so that the knurling matches.
The beam is floody with no defined hotspot, unlike my aluminum s41 which has a defined hotspot. I think the optic to LED distance isn’t spaced correctly.
