Maybe you want to wait for DT70Vn? btw if you want crazy bright light, there’s a member here is selling TK75 modded by vihn using 4 XHP 70, that’s a real eye scorcher…with Fenix deep reflectors it should throw well too, just don’t expect the runtime will last
Just got the DT70 today, they both are the same dimension and length ( DT70 is 1mm longer) probably just my light…
Unfortunately for m, somebody broke the seal on the box and the batteries were down to 3.12V,and the other 3 is around 3.4V and the manual are missing too, did someone from the custom or DHL play around with this light?
Didn’t really get to try the light yet, as both light are very sensitive regarding the batteries, my sanyo GA won’t wotk, even sanyo GA button top won’t work either.
Tried it with protected panasonic 3400B, it work briefly like maybe 5 secs before it shut down and refused to turn ON again. :person_facepalming:
So… I had to charge the Imallent batteries and maybe I’ll try it again before I go to sleep and compare it with Olight X7.
Well… in theory it supposed to be brighter than Olight X7 or HaikeLite MT03 since they both only have 3 XHP70
Now how am I supposed to figure the mode on this light?
2. For various reasons. The DT70; to add another item to my collection, to share a performance slot with the TK75Vn Quad 70.
The DT35; to add a multiple XHP35 light of its size class to my collection.
The answer to “Why?” for me is because an item does what nothing else in my collection does (such as the X65) or because I am adding another item to my collection to share a niche with items that I already have, because I am interested in that particular niche.
It seems like a big part of the flashlight hobby is gambling/chance. Most of the time the lights work, but if it breaks you might have to throw it away due to it being too expensive to repair under warranty or them not selling parts.
Luckily I’ve bought mostly Eagle Eye and Convoy. They will sell replacement parts very cheaply so they are pretty safe.
Serious modders could maybe replace the driver on a broken light with an aftermarket one, but you might lose features.
Ah, it sucks. Maybe Vihns lights from sky lumen are a good bet as he handles his own warranties and is in the USA. It’s covered for 6 months. After that he can fix it for a “reasonable” cost. That sounds pretty decent. IDK.
x2… I completely avoid $$$ lights that are glued together. Replacement part availability is a big bonus too. Reliability is important to me. They just need to work first and foremost. Tint, CRI, PWM, User interface, peak-lux, max-lumens… none of that really matters if I can’t click a switch and have light. Thats why I prefer older lights, that I have used and proven to be reliable. Even if dim or less efficient by todays standards.
These Imalent lights really don’t interest me that much. From the looks if it, their UI and their complexities seems to try and engineer solutions to problems that really don’t exist while opening up QC issues.
