I’m sure I inserted the cells in its correct polarity, and though the manual says the batt carrier can be inserted either way, this carrier can only be inserted in one way only as there is a clicky switch on one end of the carrier and it goes to the end near of the tailcap with a rubber clicky cover.
Sounds like you’ve got the wrong carrier if you can only put it in one way round as the website clearly states “Battery holder can be loaded into searchlight either way”
Gute Sache: Beide Vostro-Modelle haben nun einen Clicky am Lampenende, der zum Ein- und Ausschalten und damit auch zur Unterbrechung der Stromversorgung gedacht ist. Damit lassen sich die Lampen “hart” ausschalten und es gibt keinen Kriechstrom mehr.
Good thing: Both Vostro models now have a clicky at the end of the lamp, which is intended to switch on and off and thus also to interrupt the power supply. This makes the lamps “hard” off and there is no leakage current
if the battery carrier can rotate in the light, it provides 2 poles to the light,
good thing is you have not fried the light with 4s voltage
My thought is one battery was in wrong direction, so you get an effective voltage of 2s
inserting the battery carrier to the light and closing the circuit over a FET or converter
now current starts to flow through all 4 batteries, but one is in different dierection
the outcome is that one cell will work against the other 3 cells as it doesnt like to be reverse charged
but as you said the carrier can be separated by the switch in the tailcap you arenot having a 4s carrier
instead you have a 2s-2s carrier
positive light - switch- negative light 16.8V
positive light 2+2- switch 2+2 negative light 8.4V
you end up with 16.8V and most likely burn the driver down turning on the light
positive light +- switch -+ negative light 8.4V but wont allow an effective current flow, and all current will heat up one cell
while a high reverse current will flow through the ++ cells heating em up
(borrowed images)
Heres the BK-FA02s carrier… is this what yours looks like? It looks like a 2P-2S arrangement for 8.4V. Not sure what would happen if you connected your light to a 16.8V (4S) carrier. But thats 2x the voltage. I would think most definitely that would have a significant bearing. Flashlight circuits have some degree of safety factor built into them to accommodate for production variations… but double the max Vin would be pretty unlikely.
If your carrier is the old type one , without the switch means that can be put in , disregard witch side going in (double sided) !
BUT... in a review done here , on BLF, I do not remmember by who , has been noticed that inside the body that hold the carrier is a spring that COULD short the center (+) of the carrier with the heads of the screws (-) . I've noticed that on mine , so , using a long nose plier I insulated the spring up to the first turn with silicone insulation (was a 18 size or so...). Maybe is your case , I'm just saying...
the same thing happened to me in the original model. i thought i put the batteries in wrong. when the light wouldn’t come on i opened it up and the batteries fell out because the springs shrunk. i put in protected button tops because flattops wouldn’t fit any more. used the light a few minutes and it was fine but the next time i turned it on it wouldn’t work. i inspected the battery carrier and found a trace on the battery carrier’s circuit board melted. i believed it was caused by the wide anode on the flat top making contact with the trace. of course i didn’t figure that out until i paid $30 for the repair
Thanks for taking time to analyze…l have thought about this approach but it still can be a little too risky for 2 reasons:
The positive protrusion in the carrier is just high enough for a flat top to make contact
The original and my replacement springs are quite stiff.
lt will be just practically be a few mm away from another short, but filing the rectangular solder blob then covering it with an insulating material might just raise it nearly as tall as the positive contact, and still be too close for comfort.
My pleasure to try to help. I hear what your saying too.
You could try ‘button tops’, they would give you some extra room.
But even with the flat tops, it seems to me if you have the problem spots insulated well that should solve it. ???
Should be fixed under warranty I wouldn’t say you soldered new springs on and tried again. As that is 99% sure to void the warranty and if damage was done to the light they have grounds to not have to fix it. Id tell them I tried to turn the light on and two of the springs melted. And say there is a solder blob protruding by a positive contact on further inspection. And you would like to send the carrier and light back for inspection. That the manual says the carrier can be inserted eaither way but mine has only one direction it can be inserted it has a switch on the other side. I believe I was sent the wrong battery carrier for this light and if their is any damage to this light from a wrong battery carriee or short from no fault of my own I want it fixed especially for the price I paid
Today I received the supposedly “new, improved” battery-carrier from Niwalker.
In the photo below, while the solder blob that caused the electrical short in the original carrier is now smaller and shorter in the new carrier (right), it is still well within ‘striking distance’ as to rub and tear off the cell’s insulator (as has happened in the original carrier) and create another direct electrical short.
Photo below shows even while the cell is still not properly seated and still at angle inside the carrier (not straight up yet), the cell’s negative casing is still dangerously close to rubbing and tearing its insulator when it hits the ‘smaller’ solder blob of the the new carrier if seated properly. I did not attempt to seat the cell straight up because of two reasons: the solder blob is just microns away, and the springs of the carrier are too stiff for comfort. In fact, I even ground away some of the solder blog to make it shorter.
Well, another result of the ‘too stiff’ springs:
I tried to put in cells in the carrier’s side where there is no solder blob, but when I removed the cells, due to the extreme force exerted by the springs, it forces the cell’s insulator to ‘plow’ into the brass protruding positive ends that it deforms, if not tear, the insulation. Remember, I even use the shortest cells around.
