[SALE] High CRI 90+ Nichias (ENDED)
520 posts / 0 new
tuelleric
Last seen: 10 months 3 weeks ago
clemence wrote:
This time, all those 2700K-5700K 219C will be no less than 3 steps binned
Really looking forward to these. If possible, I’d also like to buy some of the 219B 9080. Could you please put me on the notification list, clemence? Thanks!
fixed it
Last seen: 2 years 2 weeks ago
clemence wrote:
There will be plenty of 2700K – 5700K 9050 219Cs soon Wink
You’re going to make all of us very poor Wink Are the 9080 coming with the same batch?
clemence
clemence's picture
Last seen: 1 year 4 months ago
Broke happily I presume….
THE_dAY
Last seen: 27 min 46 sec ago
I want some Step 7 if they can hit below the belt, the BlackBody belt.
clemence
clemence's picture
Sorry, can’t do that for now. All orders already locked. Besides, I will be likely being stuck with too many “common” unsold Nichias if I do so. You can get tighter selective binned with 757 variants.
clemence
clemence's picture
I’ll update via this thread. Just don’t forget to subscribe
Cula
Cula's picture
I’ve got a question regarding TIR optics and Nichias… again Smile .
This is my first encounter with Ledil optics so bear with me.
How far should i “push” emitters into the optics (all the way to the MCPCB?)? I’m asking because those legs on the bottom side of the optics have 1.4mm extensions (a bit narrower then the legs) and they prevent the emitter to go inside the optic all the way (when everything is on flat surface). Should I sand them down and let the emitter go in all the way or should I leave it as is. Hope you can understand what I’m asking.
Another question is what do you think about putting a AR coated glass lenses on top of the TIR?
clemence
clemence's picture
What Ledil type are we talking about?
Cula
Cula's picture
clemence
clemence's picture
Cula wrote:
http://www.ledil.com/node/2/p/5550?ds=1&mn=0&ld=0&md=0&xd=0&mh=0&xh=0&mt...
http://www.ledil.com/node/2/p/131?ds=1&mn=0&ld=0&md=0&xd=0&mh=0&xh=0&mt=...
I never use these optics but, it’s clearly a positioning pins. You don’t sand it down, you just press it to the MCPCB positioning holes.
The measured beam pattern calculated using pre-defined focal point. But you can always play with it, move it up or down if there’s still free play. The 0,8mm slack seems to accommodate the emitter wafer’s thickness with some tolerances between different emitters.
For example: 219C has 0,4 mm wafer thickness plus some “x” mm for silicone coating while XPG has 0,73mm including the silicone coating.
Seems this optics was designed for XPG. You can try to move the optics down to get the best focus or beam pattern. Try to precision drill the optics positioning holes in the MCPCB (waisted) down by 0,3mm if you plan to use 219C
Cula
Cula's picture
Sorry, I got a wrong link. This is the one I’l be using. It is designed for 219A, 219B and 219C.
http://www.ledil.com/node/2/p/5823?ds=1&mn=0&ld=0&md=0&xd=0&mh=0&xh=0&mt...
And here are the actual pictures:
clemence
clemence's picture
more or less the same solution. I updated the drawing in my earlier post.
clemence
clemence's picture
Cula wrote:
Sorry, I got a wrong link. This is the one I’l be using. It is designed for 219A, 219B and 219C…..
I’m still pretty sure it’s designed to be interchangeable with XPG too, hence the 0,8mm space. Wink
Cula
Cula's picture
I’ll be using kaidomain mcpcb’s, 20mm or 16mm, whatever fits better.
So if I got this right, bottom of the optics should “sit” on top of the led and I must do whatever it takes with my build to make this happen.
Thank you for your patience clemence.
clemence
clemence's picture
Cula wrote:
I’ll be using kaidomain mcpcb’s, 20mm or 16mm, whatever fits better. So if I got this right, bottom of the optics should “sit” on top of the led and I must do whatever it takes with my build to make this happen. Thank you for your patience clemence.
No problemo. I had the same problem with my Gaggione LLC49R too.
malkoff junkie
malkoff junkie's picture
Last seen: 25 min 3 sec ago
Hi-Whats 9080?.
I’m looking for 4000k 9050, but if this is better 9080 I’ll take them.
Thanks!.
Malkoff !
clemence
clemence's picture
- Ra 9050 means CRI 90 minimum (93 typical), and R9 (deep red) minimum 50 points (typical range vary between cold and warm whites)
- Ra 9080 means CRI 90 minimum (93 typical), and R9 (deep red) minimum 80 points (typical range vary between cold and warm whites)
The ideal LED will of course Ra100 with all R1-R15 have 100 points. So, Ra9080 will always give better colour reproduction than Ra9050. Not all Nichias have this options since production cost will be likely much higher while most demands usually already satisfied with Ra8000-9000.
- 219C only available up to Ra9050. I ordered 3 steps binned 2700K – 5700K (sm273 – sm573) Ra9050
- 219B only available up to 9080 in certain neutral and warm CCTs. I ordered only the 4500K (sw45k) Ra9080. Please note that this 219B has different colour binning system than 219C. For 219B, Nichia uses ANSI BBL (below black body locus) rather than MacAdams colour ellipses (around the center of black body locus) thus the different colour bin format. This results in 219B sw45k has more “rosy” tint compared to 219C.
- E21A and E17A available up to Ra9080 in almost all across their CCT range (2700K – 5700K). But I still need to test the sample specimens, later when I have them.
I hope this clarify things a bit.
- Clemence
Tjohn
Tjohn's picture
Last seen: 4 months 4 days ago
- Clemence
Thank you ever so much for the best clarification I have encountered for the esoteric binning system(s) Nichia uses.
Many of us were in need of your comprehensive explanation in a nutshell.
tuelleric
Thanks clemens!
I only wonder that Nichia does not make the 219C as 9050 in 4500K. Do you know the reason why?
clemence
clemence's picture
tuelleric wrote:
Thanks clemens!
I have no idea too …
steve42
Last seen: 9 months 2 weeks ago
Hi Clemence; Just started following this thread last week. Learning lots of details about the newer 219 iterations. Hope to participate with a small order (4 emitters) in your next sale. Steve
steve42
clemence
clemence's picture
Thanks Steve Smile
will34
will34's picture
Last seen: 2 hours 25 min ago
Great news… I’ve been waiting for a 5,700k 90CRI 219C for too long. I know some of you guys will stone me to death but I really love CW tints Blushing
Texas_Ace
Texas_Ace's picture
Last seen: 9 hours 28 sec ago
I had a 90+ CRI XP-G3 in my EDC for a few months, I am ashamed to say that it was not as horrid as I thought it would be. Although I still tended to wash things out and true colors just didn’t seem to come through as well as the warmer ~4500k.
emarkd
emarkd's picture
Last seen: 1 year 1 month ago
5700K may be a bit much for me but I can’t wait for high-CRI 5000K. Speaking of, Clemence, do you have full specs on this stuff? Specifically interested in flux bin for any of them.
clemence
clemence's picture
For workshop and office spaces I always prefer 5700K if possible. Much better awareness and easier to differentiate between colours, especially light coloured objects.
clemence
clemence's picture
Yes, later when I have them as usual. Nichia decides the voltage and Flux bin, I’ll receive whatever delivered.
badhakker
badhakker's picture
Last seen: 11 months 1 day ago
My test.
Camera Canon 6D, white balance 4000K. Brightness aligned during developing RAW. The same conditions for all pictures.
Skilhunt H03 TIR Nichia 219B R9050 sm40 Jaxman (aliexpress)
click
Skilhunt H03 TIR Nichia 219C R9050 sm40 Kaidomain
click
Skilhunt H03 TIR Nichia 219C R9050 sm40 3step BLF
click
Bonus: Zebralight H600Fw mk2 Cree XM-L2 4400K 75CRI
click
_____________________________________________________________________________________________
The results of the measurements:
Nichia 219B R9050 sm40 Jaxman (aliexpress) – 3600K + strong pink tint.
Nichia 219C R9050 sm40 Kaidomain – 3800K + weak green tint.
Nichia 219C R9050 sm40 3step BLF – 3800K + medium green tint.
Cree XM-L2 4400K 75CRI – 4000K + huge green tint.
THE_dAY
Badhakker, now that’s a great comparison. All same host to eliminate any tint variation from different set ups.
This is the Jaxman Nichia, correct?
https://www.aliexpress.com/store/product/High-CRI-outdoor-lights-lamp-Nichia-219B-series-LED-flashlights-upgrade-order/1812094_32601022783.html
badhakker
badhakker's picture
Yes.
