Last I heard Manker and Astrolux are not friends, like at all lol. Still it is possible they will offer them with 219Câs I suppose.
I just finished modding my S41S (well except for sanding the body).
Swapped the LEDâs to 219C 4000K 90+ CRI, used a Texas Avenger driver with bleeder resistor and 20AWG wires. âActivatedâ the lighted tailcap with a pair of 22k ohm resistors and 2x white 0805 LEDâs added some arctic silver and put it back together.
It is VERY nice, like really really nice!
The optics mix the tint very well and give a very nice beam. The 219C die is much smaller then, well everything on the market today. So it also have a noticeable hot spot now and a ream beam.
This is also the highest current single cell light I have, with a 30Q it is 20A, HE2 it is 22A and a efest 18350 it still pulls 8.6A. Compare that to my mixed tint XP-G3 version that pulls about 4A less (but makes about the same amount of lumens due to being more efficient).
Speaking of lumens it is not bad there either. With the 30Q it is making around 3300 lumens and with the 18350 it is still a bit over 2000 lumens. Although with the 30Q it is completely impractical in turbo, 10 second and it is hot, 30 seconds and it is scald you hot. Luckily the TA driver has a regulated mid range mode that works well.
The white lighted tailcap also looks quite nice, I considered building one of PDâs tailcaps for it but just didnât want to take the time, this setup is not as efficient but it works fine.
Overall I am totally happy with the outcome, Just need to sand down that grip
Just got my s41s from that flash sale a few pages back. It is the newest version, no glue on head.
Interestingly, the knurling on the body is flat without the peaks but the tail cap has the peaks and is very aggressive. I may do something similar to vwpieces so that the knurling matches.
The beam is floody with no defined hotspot, unlike my aluminum s41 which has a defined hotspot. I think the optic to LED distance isnât spaced correctly.
I got my S41s in the mail today. Same source as those above. Very nice light, however now that I have one I need to familiarize myself with the documented issues. I can only use it in the bottom two modes or it shuts down at 36 sec and wonât start back up until after a little wait :person_facepalming:
