To anyone considering purchasing these cells……I can’t recommend them….EXCEPT……
In a VERY low drain application where the device has a built in discharge voltage cut off of 1.2v or higher.
In that particular application, the higher voltage of these batteries could be a perfect fit.
They are losing capacity with each cycle when charged to 1.9v and discharged at 500mAh to 1.2v.
The ones tested above are now only reaching 445mAh after just 5 or 6 cycles.
They are dropping in capacity fairly quickly. Again, they were charged to 1.9v on a CC/CV stable DC power supply and never discharged below 1.2v
I am adjusting the charge maximum voltage to 1.8v and 100mA charge current and adjusting the test discharge current to only 100mA
Maybe the PowerGenix cells are better quality?
Ironically, there are people who bought them on ebay and commented they are quite pleased with them.
I would assume those are people who don’t test their capacity.
I can’t see these as a good fit in most flashlights or any high current drain app or any device without a 1.2v or higher built in discharge cut off.
I bought the same cells months ago, They have to be charged gently and not discharged as low as possible, even so one of my cells died within the first week, I stopped using the cells.
I read this thread a couple of day`s ago but i could not remember what capacity i was getting, so i have put my cells though a refresh on my mc3000, And will post the results when they finish.
EDIT: My 3 AAA NiZn cells, 421mah, 412mah, 414mah
These NiZn cells are a waste of time really and i am glad i did not pay a lot for them, And would not buy them again.
Thanks John.
Did you ever try the PowerGenix AAA NiZn cells?
I wonder if it’s the exact same cell……different wrapper?
I have two more of these that I have not yet “cycled”
I think I will lower the final charge voltage to 1.8v instead of 1.9v and see if that makes any difference.
The charge current has only been 100 - 300milliamps. Mostly around 150milliamps
I will limit charge current to 100 milliamps for the other two.
And because I intended to use these in VERY low drain devices that have a built in cutoff voltage of 1.3v I will limit discharge current to 100 milliamps also.
They still “might” work fine for the purpose I want them for.
I have only used the UltraCell NiZn, I bought them to use them in my old Sony mp3 player it takes an single AAA alkaline, I tried NiMh but the battery gauge only shows 3 of 4 bars when the NiZn shows all 4 bars, I think that`s what killed my first NiZn i forgot to remove the battery when i was not using it for a week and it went flat, the NiZn would not charge after that.
I did a quick google search wondering what the advantages of NiZn batteries were (summary: not much - a tiny bit of extra voltage when fresh off the charger, and “theoretically” higher discharge capacity if you believe the marketing materials).
But self discharge is high, and reliability seems to be a MAJOR issue with NiZn - users report time and time again that many of their NiZn batts (like 50, 80, even 100%) are dead and useless (like 30mAh capacity) after a year of only 10 or 15 cycles total.
I’m trying mine in my alarm remotes which only draw .5mA current.
Even at just 400mAh capacity, I calculate they should power it for a month. That’s about what I get out of alkalines in them.
I’m using them in the remotes now to get the real world results but it will be about a month (or less)
At this point, I really believe they have to be VERY gingerly charged (like 100mAh current and only charged to 1.8v (not 1.9)
Then, they can’t be used in a high drain application. They are just not able to handle any stress it seems.
Also, any application that does not have a built in discharge voltage cut off will end in a dead cell.
I think there is a perfect use for these in 1.5v devices that draw VERY low current AND have a built in discharge voltage cut off of 1.2v or higher.
I will know in about a month.
I think HKJ (or somewhere it was said) that these cells can take a fairly high rate of charge.
That hasn’t been my experience. They seem VERY fragile and need low low rates of charge and discharge.
The NiZn chargers that most people use probably damage the batteries if the current is over 100mAh.
I don’t see 1amp charge on these batteries. I used 500mA and the capacity is down.
Maybe it was charging them to 1.9v? Maybe they’re just garbage inside?
Needing to handle them with such care and special regimens would hardly seem to make it worthwhile except in extrememly limited use scenarios. (Why can’t you just use NiMH in your remotes, do they specifically need the 1.5V?) Especially when part of the advertised advantage was supposedly that they were better for high drain devices.
As you said in the last few words above, I also wonder how much of the problems are:
inherent to the engineering/design/chemistry of the cells, and
simply shoddy manufacturing.
The fact that some cells survive but many die indicates problems with manufacturing, but the fact that no other company seems to be interested in the NiZn chemistry also tells me there may be issues with item 1.
The alarm remotes I use only run about 5 days on even the very best NiMh batteries because of the cut off voltage of 1.34v.
The NiMh batteries drop voltage rather quickly compared to the NiZn’s
The NiZns are pretty darn good at holding voltage ABOVE 1.3v for a much longer time it appears. Significantly longer.
They are similar to Alkalines in terms of time vs voltage drop.
For some reason, they like to hover between 1.5v and 1.6v for a very long time, then drop sharply once below 1.4v.
This is ideal for my low current devices that need voltage above 1.34 but can tolerate voltages as high as 1.8v.
For me charging them is no more complex than any battery charger. I pop them into a AAA cradle connected to my CC/CV DC power supply and go.
Just found another potentially stellar use for NiZn batteries.
Smoke detectors / CO detectors
Mine started beeping today. It had top quality Alkalines in it. The cut ouff (warning beep) voltage was 1.46v (I have no idea why so high, but that’s what it is)
In my book, alkalines have a LOT more life at 1.46v, but for some reason maybe smoke detectors have a high voltage threshold.
Anyway, this seems to be yet another superb application for NiZn batts. Just ordered a batch of PowerGenix AA’s for this application.
My only concern is that it uses multiple AA’s (3) and so the initial voltage will be 5.4v instead of 4.6v (ish)
But I’m fairly sure it will handle that difference ok.
I wonder if those Batteriser/Batteroo AA adapter sleeves would work they put out a constant 1.5v at low current, HKJ did a review of them a week or two ago and said they might be of use in certain circumstances.
You got some odd smoke detectors.
I’ve got a 9v one running fine on 8.4v li-on. Get 6 months+ before charge is needed. Completely useless to use NiMh 9v, last a couple weeks.
Don’t think the discharge character of NiZn will work all that well with the application unless you don’t mind pulling and charging them on a routine basis.
I’ll have to test them and see. The same was said about the use I have for my NiZn AAA’s in the alarm remotes (similar circumstances) and so far they are doing very well. 2 weeks in they are at 1.63v I feel certain they will at least make 2 more weeks (if I don’t keep pulling them to check voltage which uses a burst of power when the battery is replaced and the device re-initializes. 4 weeks would be about as good as the best Alkalines I’ve tried. Except the NiZn’s are rechargeable.
With 3 AA’s in the smoke detector, the run time with the NiZn’s should be more than adequate.
These devices work only with disposable batteries. Not rechargeables IIRC…
Unless I’m mistaken, these sleeves contain “Joule Thief” circuitry. Please let me know if that is wrong.
I have not had a chance to test them against rechargeable batteries and while they might maintain voltage…I wonder about maintaining current and if the devices I’m using the NiZn’s in would be compatible with the Batteroo sleeves. Dunno. But I’m also moving away from disposable batteries
It should work great for 1.2v nimh cells as the low voltage will be boosted to 1.5v but only for low drain devices, smoke alarms don't use a lot of power.
His review conclusion didn’t seem overly optimistic.
“Conclusion
_The sleeve is not really a product to save a lot of batteries with, there are probably a few products where it will increase the runtime for batteries, if it can fit in them (Many devices has a fairly tight fit on batteries).
With some devices there is also a risk that either the ripple or the switcher noise will prevent them from working correctly.
Due to the nearly constant output voltage until the battery is empty, battery meters will not really work when using this device.
To find devices where it might be useful, look for devices that have very short runtime with NiMH batteries and considerable longer with alkaline. The sleeve might be more useful with NiMH batteries than with alkaline. The question is how hard the 0.6V minimum will affect lifetime of NiMH.
As a general device to extend battery life it is not very useful, but in a very few situations it might be a useable solution._”
Then I saw this thread…… Batteroo
It’s an interesting idea, but the real benefits don’t seem as great as advertised and I don’t want to risk damage to my rechargeables.
This is exactly my experience. I bought 8 of the Genix AA batteries for use in my Nikon Speedlights. Sets of four went in at a time. Within half a year of moderate use, weekends, 5 of them had gone stone dead. I chucked the rest and went back to old reliable NiMH. When they were working, they really kept the flash cycle time short. But the early death and high failure rate makes them a complete non-starter in precisely those applications where their characteristics would be advantageous.
Wilkey
