5A is cool :sunglasses: (i mean neutralā¦)
Hi Ban, pretty cool that you are the first seller of the XHP50.2 .
I think it is very critical to get the description right. The Cree datasheet says the maximum bin for 3000K XHP50.2 leds is J2, yet the 7C led on KD is J4. The reel picture on your site suggests J4 as well. Iām puzzled.
ā¦and now within 20 minutes after my above post the listing for the 7C led has disappeared from the KD site, and 10 minutes later you edited your above post and removed the link to it.
What is going on? I did order one of those 7C leds so of course Iām a bit curious
Hi
We had contact the distributor to clarify the description of the LED first.
I am sorry for any inconvenience cause to you.
We are responsible seller and make sure all our source of the LED is correct.
You can choose to refund the order.
Sorry for any inconvenience cause to you.
Ban
Hi Ban,
Thanks for clarifying :+1:
It is just that I wondered about the specific bin, but Iām interested in buying it whatever bin it is. So if it is ok with you, I choose not to cancel the order
Hi djozz
Yes.
This is a serious problem to KD. But i can sure that this is 100% genuine CREE LED.
I want to make sure we get the right bin , tint from our distributor.
Thanks for your understanding.
Ban
ā¦PROBLEMā¦
I just ordered and payed for an XHP50.2 5A tint, thinking it is high CRI like the description says.
But it is coded āBā which means 70+ CRI.
Now i want to cancel my order.
Sorryā¦
ā¦SOLVED (i think).
cancelled via email.
I finally order it, pay, and now waiting two days with no answer, so Ban, why your website is not working as it should, Iād like to order try web interface like on all other sites, it is just easier instead I chase your support for orders and packingā¦
I will PM you about this order, and I like if you can to fix that bugs in website.
Any chance of getting some 80+ or better yet 90+ CRI xhp50.2?
I think I am going to get one of the 4000k versions but would love a high CRI option for next time.
I hope this is an okay place to post this
Does anyone know if the carlco 3 up optic can be used with a KD triple board? I inadvertantly destroyed the optic & emitters on the KD Nichia 219c x3 board :person_facepalming: on one of my builds.
Iām hoping to be able to reuse the salvaged board on another project. I happen to be ordering from a US vendor & can use the quick shipping to finish my project sooner(& hence only those carlco optic are available otherwise Iād definitely just buy a replacement optic from KD.) Thanks!
check post #406
Honestly get the Noctigon 3XP regardless, even if it did fit.
thx, I knew I saw that post somewhere.
& point taken on the Noctigonā¦
And if you are ordering from MtnE he will reflow any in stock emitters for free, bare or on another board. He does excellent work. I have tried and it gets frustrating to get the 3 emitters and jumpers done and done right. I will never do a Tpad quad again. 3XP are easier but stillā¦ it will be done right from Richard.
Maybe KD is interested in producing 20mm quad dtp boards? Tpad are :confounded:
Interested too , in more than 5 pieces . 20mm , quad , for Carclo 10621 / 10622 optics etc , 1.6-2mm board thickness , dtp , copper .
No etc.
Carclo compatible only.
Round milled board with 5 drilled holes.
I can help with design to avoid usual problems.
Will take 50-100pcs from first batch and more in future.
Production methods and self-cost is same too other noctigon-style KD boards, so target price is $3.5 per 2pcs.
With āetcā i meant frosted version of 10621 / 10622 like 10623 , 10624 .
Yep I agree T-Pads :confounded: ! Make a 32mm triple board in the KD Black! I would really like it if they made both, dedicated parallel boards also, dislike using jumpers! :+1:
Finnaly I can log in into my KD account on their site.
Same error like first time, add to cart, click checkhout with PP, go to PP, pay then automatic get back to their site with this error :
Any other of you have this problem ?
A simple Parallel design similar to Manker, Mateminco, or who ever it actually is. But Must fit Carclo and have the Negative on the outer edge. Yes, with some Meat on the board, Not thin. Pleaseā¦ :money_mouth_face:
