Oh, thanks.
Feds looking into teen's reported electrocution by cellphone in bathtub
The Consumer Product Safety Commission is reviewing the death of a teenager whose family says she was electrocuted in a tub in an incident involving her phone.
Oh, thanks.
Here’s another charger:
I cannot test advanced usb-c yet.
Apparently there are a lot of Liitokala 100 clones being sold.
This answer claims they’re using a different circuit board:
Thank you for your inquiry regarding http://www.gearbest.com/m-goods-sn-189533001.htm
Your original question is “Which version number is printed on the circuit board? This appears to be a LiitoKala product relabeled (same misspelled word on the back, ”compalible”) but I know LiitoKala went through several revisionsl Which one is this?”
Here is the answer from Our Customer service Team:
Hello Hank,
It’s Colaier C20.”
Hi Henrik
Any update on your test/review of the Olight Magnetic Charger.
Thanks
John.
I have just finished it, but it will probably be about two weeks before I publish it.
I’d like to request a review on this charging board:
http://www.ebay.com/itm/MAX1879-Lithium-Battery-Iron-phosphate-18650-A123-Charging-PCB-solar-power-/121267763283
Would be very interested if it was an ok charger for LiFePO4 cells as advertised.
Thank you,
Bill
Another interesting charger that may be useful. Interested in how it would perform charging LiFePO4 and Lithium Ion cells.
http://www.ebay.com/itm/5A-DC-DC-Step-down-CC-CV-MPPT-Solar-Panel-Controller-Charging-Module-LED-Display/201789328946?\_trksid=p2047675.c100005.m1851&\_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20131003132420%26meid%3Dadd7461396f149c9b4873df50ed4967b%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D401262677875
Thank you,
Bill
http://www.gearbest.com/chargers/pp_625423.html
Quite cheap one cell simple-charger, even cheaper than the Lii-100
It will most likely be junk like most *fire chargers. It’s not worth the time, really.
I have ordered one. It will go in the low priority queue, i.e. it can be a long time before I publish a review.
There is a big risk it is a bad charger, UltraFire often is.
https://www.aliexpress.com/item/TP5100-double-single-lithium-battery-charge-management-compatible-2A-rechargeable-lithium-plate/32615889901.html
I found this while searching for a small but >1A charging circuit
This thing is interesting, because you can choose 4.2 or 8.2V - I think the charging current drops to 1A at 8.4V
also, the input-voltage can be pretty high.
If you are bored (lol)…
I have ordered one, but it will probably be a very long time before I get time to look at it.
Hi HKJ, there’s the new 4-slot charger Liitokala Lii-402:
http://www.liitokala.com.cn/productView.asp?id=47
It would be cool if you can lay your hands on one of these when they are available
Hi HKJ, there’s a new 4-slot charger from LiitoKala:
I expect to test it, but I do not have any in queue and will very soon have a lot of other chargers in queue (DHL was supposed to deliver them today, but it looks like they where a bit too optimistic).
Sofirn, again - very cheap 8-slot charger.
But does it trickle charge and hurt LSD cells? Can’t tell.
Got a guess on this one?
I recall some chargers were wired so badly that they could put line voltage on the outside metal frame of cell phones.
Bad thing to take into a bathtub.
And there they are: cell phone charger hot voltage outside hand risk problem electrocution - Google Search
Feds Looking Into Teen's Reported Electrocution by Cellphone in Bathtub
Bad thing to take into a bathtub.And there they are: cell phone charger hot voltage outside hand risk problem electrocution - Google Search
That is a major risk with any charger that get two skulls in my list: Index of tested and reviewed USB power supplies/chargers
