Attiny25/45/85 FW Development Thread
So basically I think the code outline I have is a good starting point regardless of these arguments. Gchart and I actually aren't far off in our lagnuage. He references the voltage where his curve hits 100% (what I call the target_vf) and the PWM level for 4.2V. Equivalently use target_vf and a slope (PWM drop per V). You could use 4.2V PWM level and slope, but you can get from one to other and it's all the same in the end.
The biggest question is how will things work switching from Vcc mode to normal mode. Right now we don't really have a voltage number. In normal mode the ADC could at least be proportional to voltage but in Vcc mode it's definitely not and the voltage we're generating now is too course for this (you don't want big step downs). The ADC is not even linear with voltage. I'd say fine, just use the inverted ADC number anyway and set adc_targets and PWM vs adc slopes. But then you'll need two sets of calibrations for these slopes and levels. And if you do want to regulate lower modes (I would) you'll need a third calibration for that since it will have to be done differently.
You do add significantly more non-linearities with this mixed mode approach. However you do guarantee that the FET modes won't cross below the ALL7135 modes, because the ALL7135's are always on full in them.
Cross posted. My biggest question is how does it deal with swtiching between ADC modes. The two ADC modes behave very differently.
I think it's pretty small. Maybe not 25 small. Not much is. The whole point of that approach is adjusts all the channels you want to use equally. But you can use or not whatever channels you want. I'd have to look at the driver to make it final of course, but I don't see a problem. Then again I have no idea what you've done that's so special about one channel. If this is anything related to your op-amp ideas I don't know why you'd care about fet regulation. Anyway, I don't know what I don't know. It's just a code sketch at the moment though. It could be selectable for many things. It also still hasn't dealt with the issue of switching betwen ADC modes yet, although it's a bit easier in the PWM-everything-in-use-equally approach than the leave-the-7135s-on-full-blast-and-just-PWM-the-FET approach, but still needs some calibration defined for both.
The zero amp voltage is more of a hypothetical figure, if you were to draw the Vf/A curve as a straight line. For example, using djozz’s 219C test it would be about 3V. It has an effect on the shape of the ramp after V_FULL_PWM.
And this works the other way around: it reduces PWM value when Vcc is above V_FULL_PWM. So you should be able to leave the modes mostly as they are now, pick V_FULL_PWM where you think the light is as bright as it should be and the code will try to prevent it getting brighter. For example, if you pick V_FULL_PWM of 3.8V, then a PWM value of 255 will remain 255 below 3.8V, might turn into 235 at 3.9V, 220 at 4.0V, 205 at 4.1V and 195 at 4.2V (these are just guesses but it does look something like that).
And yes, you just call the function on whatever channels you want to, right where the PWM value is set. In bistro, that means changing something like “PWM_LVL = pwm1;” to something closer to “PWM_LVL = regulate_fet( get_voltage(), pwm1 );”. Although the diode drop probably needs to be added to get_voltage() too.
Edit: I was tired when I wrote that code so the constants are pretty badly named. V_FULL_PWM would probably be better understood as V_REGULATION_CUTOFF or something similar. And perhaps V_ZERO_AMP as V_CURVE_ORIGIN or something else which doesn’t give any wrong ideas.
I don’t know the details but why keep multiple channels at all? If you’re operating the FET in linear mode (which I imagine you are if there’s an op-amp involved), it can do everything from the lowest low you can imagine to fully on as we currently have.
It is not that it is anything super special with the new driver, as super basic actually. In a nut shell moon will be controlled directly from the MCU and it will need to have voltage compensation on the PWM output. It will also have an FET channel that needs regulation for the same reasons we need it now.
What I have come to find with flashlights is that precision in light output is not all that important. Particularly in the high modes. Our eyes simply can’t register the change we would see. Heck 800 vs 1100 lumens is hardly noticeable by eye, you have to go back and forth quite a few times to figure it out if you don’t already know.
This is why I am just not worried about it being super precise, our eyes will not notice it anyways. I just hate thinking that there is another 30% duty left on the table for turbo as the voltage drops that is wasted for the entire life of the battery. Having the mid range FET modes for triples have some regulation is great as well.
The code is over my head but here is what should happen at the most basic level:
Increase PWM for selected channels (they can be controlled by the same multiplier if needed) by a (user adjustable) multiplier as voltage drops.
Anything past this is a bonus only needed if the space usage is worth it (or those features can be disabled if not needed).
The next most important thing I would say would be a further multiplier for the lower voltage ranges as those areas might need to be adjusted at a faster rate. It could be as simple as use X multiplier from 3.6-4.2V and use Y from 3v to 3.6V. The key is simple and space saving
As far as the 7135’s go, I am simply not worry about controlling them with software regulation. If it can do it with very little space used and can be disabled, then that is great although I find in the TA drivers that the mode spacing is quite good by simply turning the 7135’s on full blast after you get past moon and low.
If fixed it’s code is only 70 bytes then that is a much more feasible option IMHO, although like I said I don’t understand either one of ya’lls code. So I will leave it to the expert on how to do it.
The key is simple and small.
It boils down to heat, cost and space constraints. To get it to do everything with the op-amp would require very expensive components that are not available in small enough footprints to fit on a 17mm driver. Also according to DEL, to get a true moon mode out of the op-amp at all would be quite difficult.
The reason for the FET channel is that the op-amp and “regulated” mode can only dissipate so much heat, so you can not dissipate 5W in the driver, the driver will literally melt down (the negative wire desoldered itself from the FET today with only 3W of dissipation).
So once you reach the max that the driver can regulate / dissipate as heat you are stuck, you can’t go any higher.
So this is why the FET is PWM directly. This way it doesn’t overheat the driver but still allows for almost unlimited amounts of current.
It is a compromise but the best we can do with the constraints we have. If people were willing to spend $15-20 on the parts for the driver alone then other options could be pursued but that not a practical option for a group buy light. Doing it this way cuts the cost down drastically.
The real difference of this vs the TA drivers will be space savings, you can easily use retaining rings on all your lights. Adjustable output with no PWM in place of the 7135’s and it will be able to work with 3v LED’s all the way up to 12V LED’s without having to change anything but a resistor or 2. So it will power things like the XHP35 without a hitch (which is what it was designed for actually).
According to djozz’s test, 3V will be about 1A of current to a 219C and 400 lumens?
So this code will not increase the PWM as voltage drops? Only decrease it as the voltage rises?
Either way I suppose some modes will have to be adjusted but ideally only the last few of the ramp table would need to be adjusted (those that limit the duty to keep current in check).
I also want to say thank you very much to all of you for working on this. I am a bit of a perfectionist and like to understand how things work, not just that they work, this can cause me to come across as ungrateful or unhappy when I am actually exactly the opposite.
I just like to understand things and sometimes that requires breaking them down a a few levels for it to sink in.
Ah sorry, I thought the op-amp was used to amplify a sense resistor or something similar. It sounds like it’s instead used as a better 7135. I don’t know much about op-amps so I’ll leave it at that and wait until the whole thing is released. I wish I had free time to design my own driver, it certainly seems fun.
Maybe, does not really matter. That value is only to define a straight line which is used to approximate the graph in the area where regulation happens (ie. in the 3A+ range, presumably). What the graph looks like below the regulation threshold is unimportant as I don’t do anything about it.
Yes but it really amounts to roughly the same thing when you think about it. The only difference is what PWM values you have to start with and how you calibrate the whole thing. Either your modes/ramp have lower PWM values which get increased by regulation or they have the higher PWM values which get decreased by regulation.
True, I was just thinking it is less work to add PWM to modes as the voltage drops since the modes would largely remain the same as they are now except for turbo (well technically it would as well, since you already need to lower turbo in the low Vf lights).
By subtracting it, you have to start all over on the modes and mode spacing. Not impossible if this proves to be the more effective and smallest option, just more work. It also means you are committed to the regulation being active at all times as the modes will be wrong without it.
EDIT: Actually I did just realize a possible issue with this option, using this method you will run into issues where a mid range mode will reach 255pwm before the subtraction and thus not allow any more resolution, so all the midrange modes would basically be the same as turbo? Or am I missing something?
We thought about going a lot more advanced with the setup, such as controlling the FET directly with the Attiny through a DAC to give full control and reduce components / cost. This would take completely new firmware though and quite advanced firmware at that. I didn’t see this as a viable option at this point so opted for the simpler option that would work with a tweaked bistro/narsil.
I will release the driver once it is ready for the public eye, it still has some work to tweak to get the design finalized. It has been a royal pain trying to keep the components 0603, if it was machine made it could be made with 0402 or 0201 and be way nicer. I think it would also be able to fit a tiny85 in that case.
Sorry this is a bit off the current topic but Ive got an “im in the middle of modding something” question.
Is it common for Narsil (Narsil triple) to run on 4.6mA of standby current? If not, anyone know what I might have done incorrectly? I’m using 220k and 47k dividers.
Which driver are you using?
I’m using the ta17 all three channels.
Edit
This is unexpectedly high correct?
I’m not sure I follow you there. From what I understand, most firmware already has modes which use the full PWM range up to 255. My code will require no change there. It simply tries to make the light behave the same above eg. 3.8V. So unless you’re unhappy with the current behavior on a partially drained cell, there is no need to change the modes.
I imagine it might be the case that most modes/ramps were tuned for full cells and might not be quite as nice with partially empty ones… but I really don’t know. Then again, they were probably tuned for LEDs with higher Vf which did not need scaling back at high Vcc so this might all cancel out. It’s hard to say how much change will be needed to the modes without trying it in an actual light. And no two people seem to want the same modes anyway :slight_smile:
About your edit: the only range issue is that the highest power settings at the highest voltage are unavailable. But that’s the whole point of it, I think. Of course you could still make an exception for turbo, if you mean to cook an egg or something.
Yeah, I did roughly that but without the DAC, instead using the pull-up resistor + careful timing as a poor man’s DAC. It took a long long time. It’s not realistic to adapt existing firmware to that kind of system so it was probably a good choice to pick what you did.
It’s an interesting long term project though and I’m still wondering if the two PWM channels could be combined into a basic, highly accurate DAC for this purpose. Someday I’ll find out.
Does it have the zener installed?
Yeah, it should be a lot less then that. What about the bleeder resistor, is that installed?
No zener no bleed resistor
