Emitter is a little off center, at least relative to the shroud piece on the drier. Need to adjust it a bit more…. I think. I can’t tell how well the LED is centered relative to the aspheric lens. Still throws like crazy though.
I did a first quick check yesterday. Overall it´s not a terribly bad light for the price, but unfortunately also not a very good light.
Here´s a summary of what I found:
Positive:
overall solid construction, all parts easily accessible, nothing glued
very easy UI (one click on, one click off), fast ramping (3,5 seconds from low to high, 7 seconds for a full circle)
no PWM in any mode visible
takes any kind of 18650 batteries due to 2 springs design
low price
with 520 lumens (calculation via ceiling bounce) enough light for standard purposes
comes with 18650 battery and USB cable
Negative:
Fake XM-L2 LED (possibly LatticeBright clone)
maximium 520 lumens - far less than the claimed 1100 lumens
always starts on HIGH - no memory mode
threads are blank - no mechanical lockout possible
lowest setting still pretty bringt (30-50 lumens)
battery carrier a bit too wide - 18650 rattles inside light
beam has some strange rings on the outside of the spill
color temp is not 5000-6000K, but rather 7000 K, has no blue tint though…
included “UltraFire” TR 3000 is “suspicious”
Not clear yet/needs further tests:
USB charging behaviour (overcharging?)
LVP reliable?
Stand-by Drain of eletronic switch ?!?
I also posted some pictures of the light compared to the NiteCore MH20, see here (German).
TOOL ti 219b, like that much i have another on the way and a cu version in 219b flavour as well. 1st TOOL is for my work keys, changes over from a thrunite TiS.
