Threads fit better.
The threaded ends of the S1 tube have the same diameter as the original Skilhunt 18650 tube.
The A6 tube is 1mm smaller diameter.
The A6 tube is also 2mm shorter than the S1 tube.
Protected 18350 would be a problem with the A6 tube.
Inner diameters are both 19 mm, outer diameters are both 24mm.
Diameter of threaded sections S1 is 22mm (same as Skilhunt), A6 is 21mm.
S1 tube is 37mm long, A6 tube is 35mm long.
So the threads on your A6 tube were lose due to being 1mm narrower? The A6 I ordered the threads feel tight, and it looks exactly like your S1 in the pic. I dunno if the S1 and A6 look the same anyways? For now both the A6 I ordered from bangood (if that is even what I have) is fitting perfect and threads are tight and smooth so I’m not sure what could be improved anyways, unless when I get my 18350s they don’t fit!
My 16340’s fit in it too after I did the spring / magnet mod, they are the same capacity as most 18350s anyways, and are high drain so they can push the LED just fine in turbo. Probably save some weight over the 18350. The 16340 (RCR123) battery is loose in the tube, but apparently under enough tension that it won’t rattle or misbehave anyways.
Jut to be clear, this is the tube I ordered, it looks like the one in your picture.
Also the headband is $3, but shipping is $9? Hmmmmm anything cheaper that will fit? That’s 1/2 the cost of the headlamp!
Man, how did you get the head loose? Either mine has more glue or I have little girl strength. Don’t want to mar or deform the tube using tools, but I can’t get the damn thing off by hand…
One of the reviews states this reflector is a bit over 13mm tall and just over 17mm dia. I’m thinking it will not fit. The opening in the h03 head is, I think, between 14-15mm in diameter. It’s a very small reflector.
Somebody here on the forum broke his TIR, he/she contacted skilhunt via email (not the message system on the site) and got a new TIR. Don’t know if that person had to buy it from skilhunt or some other company. Think it was for an H02.
This is a brilliant mod! You made my morning
I have an H03 on the way and will try the shorty tube from my A6 immediately. And maybe replace the LED with Nichia 219c CRI 90 later.
