IMRBatteries NCR18650GA
6 posts / 0 new
Zebretta
Last seen: 5 days 3 hours ago
I bought a few of these from IMRBatteries. Seem like good batteries
But they came with blue, shrink wrap that can be applied over the battery to make them look like IMR brand.
Does anyone use those and if so why or is it just appearance? Does it make the battery run any hotter?
They did not send enough of the shrink wraps for all the batteries I bought even if I decided to use them?
Lexel
Lexel's picture
I did all my unprotected ones with an additional transparent heat shrink tube to avoid rattling in my lights
The internal resistance of those Sanyo cells is so low they dont heat up, way more heat comes to them from the LED heating up the tube on turbo in EDC light size
5m transparent tube costed me 1.78$ from China
Now on promotion
https://de.aliexpress.com/item/18650-18500-Battery-29-5MM-Diameter-18-5MM-PVC-Heat-Shrink-Tubing-Tube-Wrap/32752466121.html?spm=2114.13010608.0.0.Fp0ZIv
Zebretta
Ahhh….to prevent rattling. Thanks
Speed4goal
Its extra battery wraps if you rip a sleeve . its common in vape units for them to tear. I’ve used their wraps plenty of times its meant as a replacement a free gift basically I wouldn’t use them until a battery sleeve tears. Sometimes laptop pull sleeves tear retrieving them I’ll rewrap it with those or clear ones. They include those two wraps with every order placed
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
sac02
sac02's picture
Last seen: 1 month 6 days ago
Why is it common to tear in vape units? Is the clearance very tight, or the insertion/removal very difficult? (I know nothing about vape units)
Speed4goal
A lot of double 18650 mods are pretty tight with a lot of pressure. I’ve seen plenty of well used sets with the bottom of the battery pointing inwards. The usually tear at the top or the bottom of the battery. Some batteries are a real tight fit. Even using the string to run behind the batteries on some mods takes a little force. And then not everyone uses the string. Its actually free advertising for imr. And doesn’t cost them but a penny or two. 10 wraps is only a dollar from them. I like the clear ones. Write the capacity on laptop pulls or older cells with date then wrap lver in clear
