Wow DEL! That is a bunch of boards! I’d seen a couple of your boards at OSH Park, so I knew you were working on some. But I didn’t know you had this much going on! Impressive! Thanks for sharing these with us!
That thread is long overdue for a massive update. :person_facepalming: I’m not really sure of the best way to keep its op from getting unwieldy. It’s very difficult not only to edit a single already LARGE post but navigate it to find something. So many drivers only slightly different from each other, not to mention all the other project pcb’s. I’m inclined to just post author thread links under linear, buck, and boost and let the authors organize their own op descriptions and links and accept that there will be a fair amount of redundancy. Given that no one of us has editorial control to organize the separate threads into consistent layout under one umbrella it’s always going to be a patchwork but I need to do at least something to bring it up to date regardless of the result.
Nice work. Each new design might seem to add an unnecessary redundancy but to me that’s part of the evolution of the drivers to find out what works best. Having Oshpark available to try them in piecemeal quantities makes for a hand in glove relationship. It’s just difficult to keep track of.
Thanks for the kind words everyone. I hope to eventually add schematics and also scope traces to show the advantages of the few extra components.
Of course if you need an OTC, or would like to have the full complement of stability components on a 17 mm board, or a 3-channel board, TA is your man!
+1
Those who design boards will always make new versions for their needs. Be it a small tweak or a big change. But if it’s shared, those who are not accustomed to board design will benefit from this diversity and the designers get new ideas. I’m always happy to see new designers joining the herd and new designs coming up.
And this, RBD, is where your thread is the center of it all. Be it patchwork or not, it’s invaluable.
Which reminds me I’m overdue with enlisting more than one board to your thread myself. :person_facepalming:
Have to add a resistor and Zener diode in the same positions as on the ‘standard’ DD drivers. Here we have the luxury of C2. So swap out D1 for a 220 ohm resistor and replace (or stack) C2 with a 4.7 V Zener diode.
The same precautions hold as usual:
This is only good for 6 V emitters.
The 7135 will run hot at high PWM, but the 7135 has a good surface of copper for itself on this board and it should be OK.
Parasitic drain will be up to 20 mA while the tail switch is on.
EDIT: If the voltage reading is important, I would lower R5 to 1 or 2.2 ohm get a more accurate voltage to R1/R2. This is necessary because of that 20 mA parasitic drain.
The Yezl boards came in on Thursday so I put one together today. Fit is pretty good, just had to take ~0.5 mm off the ears for a nice snug fit.
The Digikey switches will only be in on Monday, so I transplanted the stock switch for now. It had two plastic support pins at the bottom that I was unaware of (snip-snip), otherwise the footprint is identical to the Digikey part number.
Melted the corners of the switch a little with the hot-air rework gun …will try some aluminum foil protection next time.
Nice DEL! I have to get started on the Y3 board real soon. I got in a lot of your 17's, but must have missed the 20's. I'll be ordering them asap.
Edit: wondering bout the potential of doing a similar driver for the Convoy L4. You can buy it as a host, but since the switch is driver mounted, it makes it difficult to utilize the side switch.
You can get the host here at BG listed for $20, but with Martin's code M4DCONVOY, you can get it 20% off. One of my first piggyback mods was done on the L4. Dunno... The L4 has been around a long time, it's a big C8, kind of dated looking for what you can get now in more compact pocket friendly sizes. For $16 though it's a good deal for modding. This is what I did, showing the stock driver:
An L4 driver should be an easy adaptation of the Y3 driver. Would just need the board dimensions - diameter, flat center to board center, details for the key tab at the opposite end. And the part number / pad layout for the switch you want to use.
For the Y3 driver, if you had any concerns for +vias, I measured 2 mV drop at 5 A on my sample with vias solder-filled.
My 20 mm drivers are not here yet, but I just shared a 22 mm version as well (going up is easy! ).
Amazon shows the basic dimensions for the L4’s LD34 driver. Wonder if the Y3 driver with altered ‘gibbosity’? tabs would fit:
EDIT: I can probably work with the nice photo here:
From the photo the button center is 2 mm above the PCB. The Y3 switch is 1.75 mm, so should work. The LD34’s through-hole switch would be much more durable than the SMD type on the Y3, but I would need a suitable part number and datasheet. The SMD switch should be good with a little bit of epoxy backing Tom?
Ahh. Just took my L4 apart. The stock driver is slightly bigger than your Y3 at 23.6, guess you knew that. There's slop though it how it mounts. There's really 23.8 mm measured space, and the stock back tab is too small both in width and depth. The L4's switch sticks out a bit further, is slightly higher. The height may be ok, but depth would probably be a problem, but you could glue a disc to the metal button of the L4 since it's a nice big round surface.
I think I bought some of those L4 switches from DigiKey... Gotta check.
Look'n at your design, the back tab, though you matched the driver, doesn't do all that much. The cutout in the L4 is much wider. Now of course I got an old L4, so things could have changed in the latest L4's.
I will see if I can fit the footprints for both switches. I shared a WIP 2.0 on OSH in the meantime. It has a bigger key tab. Think I will up-size the board to 23.8 mm as well, nothing a little sanding cannot fix if it ends up too tight.
