Not really giving up on the TA series as moving on to better things. There is just not much left to do with the TA setup besides possibly cramming an 0805 C2 on it and frankly the TA will never go anywhere past hand made drivers (at least not the 17mm version, the larger versions could I suppose), the backside 7135’s just make it impractical to use it in a production light.
The new driver will be designed from the ground up to be production ready, which is why I am moving the focus to it. Plus it is simply a better setup and even more efficient then the 7135’s since you can have true non-pwm regulation at any current that it can dissipate the heat from instead of just 2 channels of pre-selected current.
So While they should share the same firmware setup I am moving focus to the new driver. Anything that works on the new driver should be backwards compatible with the Texas Avenger but not necessarily the other way around.
One reason I want as few changes to the hardware as possible is that I do see these drivers being produced by a china company in bulk for a cheap and effective option for us modders. As such I want the hardware to be as complete as possible for as many setups as possible out of the box. The voltage divider is the one thing that I don’t think we can get around but luckily that is a fairly simple item to swap out and/or disable in the firmware. I suppose we could always go back to the 1.1V reference for the LVP? or will that not work with the OTSM?
So the one issue there, is for OTSM it's a bit of a bummer to see a 1S forced to a 3.3V LDO. I said we need OTSM to work at 3.3V anyway, but that's not quite true. It needs to work at 3.3V but for a standard 1-S setup it doesn't need to work there hot. You just can't get as hot at 3.3V battery as at 3.9V anyway, so a 3.3V LDO is actually placing more demand on the OTSM cap. Especially in the TA driver, there's just no need for the LDO in a 1S other than conformity, but it might turn out it's better to use generation 1 in that case anyway. Well I guess for the TA there's no downside, other than maybe a few cents in price, to just using the 5.0V LDO for 1S, so that works too.
Like I said, the op-amp needs an LDO for the voltage reference and there is not enough space for a separate diode. Plus it would be nice to have everything setup around a single LDO voltage, then no changes would be needed for any input voltage outside the divider.
Well I'm going to have to order an assortment of caps for the sake of science and maybe even build a light. I don't like the power saving I programmed in bistro now. It's too unreliable with 16ms minimum watchdog idles. It needs 1ms resolution to make sure it's always engaged when you need it. I think I have code for that too using the internal clock timer, but it's a few lines longer and it would help if that other space savings trick works out.
I don't see any downside to recommending 5.0V LDO for 1S TA (non op-amp) style. It comes in both flavors probably no? Does 5.0V require a substanitally different part or it's just a choice in the series? If building a 1S tripple, I'd just buy the 5.0V and use it as if it's just a diode. Actually, I'd use the 1st gen board at the moment, because I know it works, but assuming the LDO works out (and does actually act like a diode), then 5.0V for 1S, and well, for tripple drivers also for multi-S. Yeah, 5.0 V for any TA tripple. Sure if you ordered a bunch of 3.3's for other builds they might work ok too, but you usually know what you're building when you buy the part. 1S op-amps are a different issue. I'd use whatever is best for the build. It's the same effort either way.
You can use a normal diode on the TA drivers for 1S operation but like I said, I am not worried about them directly. Anything that works on the new driver is backwards compatible. So all development should be focused on the new opamp driver as that will be the long term winner here.
I can’t really think of a reason to use the TA series anymore once the opamp is working as it should, while they basically do the same thing the opamp will be the better one to use due to it fitting in lights easier and being more adjustable. Plus it could be machine made for group buy lights / cheap mass produced driver option compared to the TA series which would not work well outside hand built setups.
This is the driver planned to use in the Lumintop SD26. I took a 30mm LDO and converted to std diode setup. I think it would work. I added a wire jumper and a 0 resistor to make the connection of Batt+ to the MCU and C2. If anyone gets a chance, can you review/comment? Thanx!
It should work like that. I think I actually said in the TA thread that you could put the diode across the far inner set of LDO pins facing towards the MCU and it would work fine.
The way you did it would be fine as well though, same thing, different placement. Although I did figure out a way to remove those jumpers but can’t bring myself to update all the drivers with the minor change when I have a new driver in the works that should render LDO versions of the Texas avenger moot.
Oh regarding the 1.1V, no that won't work with this bistro OTSM implementation, unless you want to make a separate pin for power-off detection and voltage divider. Presently the divider voltage needs to be logic high. For 1S the only practical way to make that work with constraints on the ADC is to use Vcc "reading" , and then for 2S use Vcc/LDO-referenced (not 1.1 or 2.56) reading of the divider. It will just be a define to switch.
It's certainly possible to make a purely ADC-based implementation. It's a rewrite of bistro's adc system, not just changing a couple of initialization registers or the name of an interrupt. It won't perform quite as well either, maybe a little because the ADC uses a little more power on these BODS scales, but even more because you lose the possibility to wake on the power-on signal. Instead you only wake on the watchdog timer, which, to save power in BODS, is presently set to 0.25s intervals and is thus too un-responsive. You'd need to lower it to 0.125s at least, requiring maybe 50% more power draw in the sleep loop and still being I think noticeably less responsive (based on my non-thorough observations of that setup). So I'm not really seeing that as the direction to go in, but it could be something to try.
I'm not sure how well the 3.3V 1-S Op-amp OTSM will work though. It's all going to depend on the quality of caps we can find. There seem to be options in things other than ceramic, but anyway, it just needs searching and testing. Specifically leakage should be less than 1<uA, and that doesn't really fit with specs on Ta Ta-Polymer, NbO, but comments I find are that real world results are much better than spec.
Worst case a 5V LDO could be used in the higher voltage drivers, it would remove a lot of the point of having these mass produced though if that was to happen. The sales pitch for someone to mass produce these is that they would be the one size fits all driver for anything.
Good news is I've saved a TON of space (by attrition mostly). This is presently looking like it will be even smaller than the last version. The bad news is I'm presently noticing that it's not working well (or maybe at all) on high modes. I'm not certain if that's something new, or just something I hadn't noticed. Hmmm... something to try to understand still. Obviously that would be no good.
well.. ok, not smaller than the last one, but still 140 bytes left over for now.
Yep.. Anyway, high is working, just not well. hmm, hoping it's a pin setting thing. Not sure. Mostly I haven't used turbo because the star isn't heat sinked. So will have to figure this out. The led shouldn't be able to drain C2, and if anything should help. Well I've got at least one idea to check so we'll see.
I don't know the cause of the high mode thing yet. Haven't had a chance to do any testing. I realize that one thing my power measurements missed, well that's the wrong word... they measured the mcu power draw. But there can also be a reverse current through the diode (I was feeding power forward through the diode so didn't measure that). I checked the specs on the diode in your digikey basket (likely the one I'm using, but I'm not sure) and it's not very good:
At 25C it's around 1uA or less but at 85C it's around 80uA maybe. I wouldn't think my board is getting this hot (not sure, it's hanging in the air without a case to heat sink too, but it also has no led to heat it up), but it would only have to be 5ua to have the kind of effect I'm seeing. It's another case where I don't know how conservative the specs are. If it causes this issue or not though it's probably not ideal anyway. This would be a better choice I think:
With the graphs indicating around 1uA at 85C. That diode is a bit fragile in comparison but should do the trick (with an R5 installed to protect it).
Of course all this brings the question, how good is the LDO at reverse current blockage? I lost the link to your new LDO. uA are small. Can it really work without an inline diode?
Interesting points on the diode reverse voltage. If you find a better one that is obviously easy enough to change out. Although the LDO would be better if it works.
The latest LDO we have found is the LT3009, the real issue with it is the rather scarce availability compared to other options.
It must have been an old post. I do use Linux now (in a virtual machine simply because I don’t like having to walk over and use the Linux box lol).
Atmel complained constantly about things, Linux uses the same exact files and compiles it without any issues and the final size is smaller too boot. So I now just use that.
Yes, I know the -Os option. I'm well past that level of tricks now I hope, but it's a good tip thanks.
So, I took some measurements. At 3.3 V I'm at 8uA in sleep measured through the usual power chain, so the same as my much older tests in similar configuration. But I before I measured that I happened to be measureing at 4.2V which put me at 10uA, ok fine. But if instead I connected direct to Vcc, powering C2 directly with 500 ohms bleeder to ground upstream of the diode (the amount of resistance there really doesn't matter for diode reverse current since all the voltage will still be across the diode) then I got about 11.5uA. Ok, no big deal, seems like maybe there's 1.5uA of reverse leakage through the diode.
But I had taped a thermocouple to the diode body, and heated everything up (starting at 22C). By 55C it was 20 uA and by 70C it was at 33. Actually I stabilized at about 75 and took those numbers as it cooled because that seemed more stable than while blowing hot air on things. One time I cranked it up to 85 because the spec sheet has a line there, looks like aroun 70uA maybe on the spec sheet, and sure enough, it went off scale, somewhere pegged past 50uA. So it follows the specs pretty closely actually.
I'll look up your LDO, but this could be a real issue. I'll also try to see how warm things were getting on my high mode because I'm not sure yet that these are related issues. It's all I came up with so far though and it kind of checks out so far.
