Test/review of Panasonic AA BK-3HGAE 2700mAh (White)
12 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
DSC_3471
Official specifications:
  • Maximum Capacity: 2700mAh
  • Minimum Capacity: 2500mAh
  • Nominal voltage: 1.2V
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-info
Maximum temperature raise at different discharge currents: 1A:+1,1°C, 2A:+3,1°C, 3A:+5,6°C, 5A:+11,1°C, 7A:+15,9°C, 10A:+17,8°C
Panasonic is both selling eneloops and Pansonic cells, they are not the same.
DSC_3440 DSC_3441
DSC_3472 DSC_3473
DSC_3476
DSC_3477
DSC_3478
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-Capacity
The curves looks very much like other 2700mAh cells.
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-CapacityTime
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-CapacityTimeHours
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-Energy
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-PowerLoadTime
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-CurrentTest
Panasonic%20AA%20BK-3HGAE%202700mAh%20(White)-Charge
Conclusion
It looks like good batteries with high capacity, but the difference from 2500mAH rated batteries up to these is not very large.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
robk
Thank you again, Henrik, for all the incredibly useful reviews. I noticed that you made no mention as to whether these cells are LSD, and I took a quick look on the package and didn’t spot the telltale “Ready to Use” phrase. If these cells are not LSD they are perhaps less interesting to those of us in the Eneloop fan club.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 day 10 hours ago
Thanks for the review HKJ.
These seem impressive i did not know there was 2700mah cell.
HKJ
HKJ's picture
There are a couple of brands, but they do not give much extra capacity compared to 2500mAh and they cannot match 2000mAh eneloop in lifetime (or even get near).
flydiver
Last seen: 3 hours 27 min ago
Kind of off topic but I have some Ansmann 2700 and 2850mA NiMh. I thought they were a good brand. After just a few years use and with a fresh test cycle they come out about 2000mA, have a miserable internal resistance (around 300-500 on my Opus), and poor current support. They keep that trend up and they’ll be pathetic in a couple more years.
Not sure any of these high cap AA will amount to much long term.
To Air is Human, to Respire….Divine.
Speed4goal
Last seen: 1 year 2 weeks ago
If I got a few years out of some batteries I’d feel I got my money worth out of them. I use 2400-2500 LSD cells they only last 400-500 cycles. Walmart has the Duracell online for $8 if I get two years that’s a dollar a battery. The Walmart by me still sells the made in Japan ones. I had heard somewhere some Chinese ones were in some stores. Don’t know the truth behind that
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
xephon
xephon's picture
Last seen: 2 weeks 3 days ago
Are IR measurements accurate on the Opus? I seem to get different readings at different charge levels.
Leif
Leif's picture
Last seen: 8 hours 43 min ago
Some years back I had some high capacity Panasonic cells. I found they lost ~0.5% charge per day, and repeated high discharges in a torch/flashlight caused the battery to lose capacity. The capcity went down from about 2700mAh to more like 1600mAh in a year. I was discharging them twice a week over six months, so maybe 50 times. Perhaps these are better?
This forum may contain nuts.
No animals were harmed in the creation of this post.
Be nice to people. It annoys them no end.
flydiver
None of the chargers at this level are “accurate”. It’s more like you now have a stick with measurements on it and as long as you use it the same way you get approximate readings to compare a battery to itself or others at a crude level. There is a way to measure it that is accurate but I’m not willing to bother.
IR changes with state of charge and temperature, that’s normal. There are a number of contact and resistance issues with the charger itself that makes the reading not terribly accurate. I make sure the contacts are clean, and generally take several measurements and kind of average them, throwing out the wild cards.
My good batteries show IR below 100 for AA. When they start showing above 150-200 they are definitely not doing as well.
Larger batteries should show lower readings than smaller batteries. I have some crap AAA that show 500-700 on the Opus. But they still work in little LED motion activated night lights just fine.
Martini
Martini's picture
Last seen: 9 months 4 days ago
As always, thanks for the review, HKJ.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
sixty545
Last seen: 1 month 6 days ago
Thanks for a surpricingly interesting review.
Perhaps I’m too romantic in this, but something familiar stroke me by studying the two pictures of the cells.
1. The detail proportions are the same as the cell I have in my hand right now.
2. The color and structure of the insulation shim (gray) are exactly the same.
3. The assembly angles of the wrapper in the ends are exactly the same.
4. The metal surfaces looks the same.
5. They are made in Japan.
What do I have in my hand? -A Fujitsu Black from FDK!
FDK seem to be making these non-LSD batteries. The provider also dares calling them Panasonic Eneloop, but I know nothing about their quality.
Just had to say…
I have Eneloops that say they can be recharged 2100 times do you believe that number? There must be strict standards of recharge. I have read you only get that many recharges if its partial charging say 1/3 drained not from fully drained?
What is the most charge cycles a BLF member has done any one counting?
