the phlatlight pt-54 I'm playing with has double lenses.
I don't know much about optics, but I think it was done to make the beam less divergent, without fully focusing it.
I doubt as much r&d went into this TF double lens though ;)
Hows the light? Any more waterproof? Strong points?
do you mean the phlatlight? very different animal, besides them both having two lenses...
I did some fiddling around with the lenses - stock config, each one by itself, each in front of different emitters, etc.. Basically, with just one lens the beam is focused but still does this (imagine the D is the lens)
D<
with both lenses it is more like this (although not as concentrated as an = implies)
D<D=
disclaimer - don't buy this trustfire thinking it will have a similar beam! i have no idea what it looks like, but I'm guessing they had a similar intent...
It will depend on the angle and thickness of each lens, I feel it is difficult to know it without having it.
Also available now at Manafont, with better pictures, it accepts one or two 18650 with extension tube.
And the best of it, the head diameter, 48mm, the lens might be 45-46, which for an XM-L if it is well designed should throw quite a bit.
The lens travel is around 12mm, which hopefully means most light is thrown into the lens..
I am really tempted to give it a try, probably after christmas I will...
Hi Gorann, I will let you know once I received it, as you asked me for iton the Deerelight DBS post.
I cross my fingers it will be in my hands during next week, but I am not sure as we give the presents on the 6th of january instead of 25th of December, and the post office might be quite busy next week.
i'm looking forward to hearing about this. I'll go for this or the Z6 next. Probably this if the current draw on 1 cell is decent. Don't know what they were thinking w/ that ugly 2nd cell extension but it doesn't matter to me, I'd probably never use it. Doesn't look like she'll tailstand but I have GITD tailstand grommet like thingy that might fit...
Yes you are totally right about the extension tube, it does not match at all the rest of the flashlight.
If I were just looking for the best looking design I would go for the Z6, but I am more with the performance, and I am praying this one to be a winner.
In addition, it looks on the pictures it has well machined threads, and a general nice construction, better than most flood to throw lights available, not as nice as the Z6, but it is something..
I will not be using the extension tube either, and I am hopping it will do about 3A with a single cell too, if not I will probably use it Direct drived or with any other driver that can work at 3A.
haha, yeah, If it were pink with purple flowers, but performed awesome, I'd still buy it.
not sure if you noticed - KD claims 2.8A and lightmalls says 3A
DX says 2A for the Z6, and the reflector must be 2/3 as wide as T8. Z6 looks easily pocketable though...
I bet performance is great as long as they didn't screw up the driver or use really high loss lenses.
I do not normally believe much about the technical specs from shops as they are rarely true, or in the case they tested it, it could be done with a wrong method such as using a high internal resistance battery etc, so lets see how it is when it arrives..
I see the Z6 on other segment, probably with the Yezl T9, with maybe better construction, but the Yezl is better than normal (on the FTT lights), the Yezl has a bit bigger lens diameter by the way, but lacks of a really bad lens, that I replaced and I am quite happy with it but, as most of us I always want more haha.
Argh, I was relaxed waiting for it till now, now I want it to be here tomorrow haha, it can be great or rubbish but I want it now, and it is your fault haha.
anybody else hoping the body can be bored to ~27mm certainly the extension cannot
i know it is unlikely...but it is fat
edit: i suppose there's no chance, it would wipe out the inside threads for tailcap...
That would be a nice mod, I also want a FTT with 26650....
I will let you know the wall thickness once I receive it.
I have just received it, I am in the office and cannot show it right now, I will try to do a review tonight.
The first impression is really good, the body has a really nice feel with a thin layer of rubber on it which makes it really comforable to hold it on our hands.
Threads are quite thick and well machined for a budget light like this.
It came with all the threads quite clean.
Oh dear. That's a deal breaker for me. Its always part rubs through/off and ends up very tatty/
not me, I love rubber! really, I plastidip everything. and I mean everything (even did and entire truck bench seat ). thinned w/ naptha (coleman fuel) it sprays ok through HVLP.
anyway, so great to hear you have it in hand and that's its not junky!
really looking forward to what you have to say. this makes my day.
livingvicariouslydthrckt
It is 1PM over here, I will try to do some tests after work, in about...8hrs ( I leave at 7-7.30pm the office).
*VFMaddict, it looks to be well made, I hope it will not wears out in the short term.
I can't wait to hear what you think of it when you pop in a battery and fire it up!
I am as nervous as you waiting to see how it performs!! Haha.
By the way, the rubber cover, looks like can be removed, it is not sticked to the body, but the metal underneath, might scratch easyly as the finish is the typycal anti-slip which might scratch or get dirty easily when exposed directly.
I have fleeting thoughts of stuff like that every (work) day, especially the first few hours of the day
Yeah - I hate when that happens to me :-)
Haha, sorry a lot for the delay guys, I did not get home till now.
I have just checked the flashlight, and I am afraid it is not as good as I expected, it throws roughly as much as the Yezl T9, a bit less I would say.
The focal lenght was not quite well regulated, it does not concentrate the die very good out of the box, I have just raised the position of the first lens, the one closer to the die, and now it is a bit better, but not even with this it throws much further, it throws roughly 350m with a bigger spot than on the T9.
On the flood part of it, the image is not fully clear, as with single aspherics, there is an external ring clearly more bright, and the area it covers is slightly smaller than the Yezl.
The flood to throw system is not that good, as the head doesn't run over a tube surface, it bounces a bit if you try to push it with one finger, it has to be done with one hand.
I will try to get some pics tomorrow, sorry but I am a bit tired and it is 12:32AM over here, and I need to sleep hehe.
The lens diameter is around 44.6mm and 10mm thick, I will check for a 44 from Kaidomain if it fits the focal lenght.
The one closer to the led is about 32mm and 6mm thick.
The build quality is good for the price, but the lack of a better throw which was my intention makes it fail for me.
It is a pitty, I was waiting like a child for Santa, but I found my parents preparing the presents, which were not as good as I asked for, telling me I hadn't been a good boy.
