Ok here you are the evidence that X6 XP-L HI 1A version have DTP copper board. I bought mine directly from Ali store,so I cant confirm that you will get the same if you buy it from GB, or BG. BTW my is still stock doing 3,55 amp on fresh cell .
If you see this straight trace patern with small cross in the middle like on Noctigon, then you know it’s DTP
This guy now sells bare X6 hosts (+F30 and A6 hosts)!!! :laughing:
Minimum order of two but at $11 they are a steal.
BTW: received a XPL-HI 3A from this guy a week or so and am very pleased. 50K lux on turbo (30K on High @ 1.8A), very nice fit and small… this thing makes a C8 feel big. Easily my new go to light, really good value for $$$.
I’ve been trying to figure out if there was a way of disabling the strobe altogether so had a poke around with the solder bridges. As far as I can tell the one on the left (if looking at the LDCH text the right way up) disables turbo by making it switch back to high after about 1/2 a second… makes it difficult to switch from turbo to low mode. The one on the right (mine arrived bridged) doesn’t seem to do anything?
It was not too long. It was/is as long as the PD12/PD35/TN12. It’s about at the right size for the kind of light it is, which is a momentary/side-switch light.
I did mod my light
Installed a 20mm DTP copper Tpad
Boosted current with a 0.025Ohm 8cm copper wire parallel to the 0.01Ohm sense resistor
I did discover something not expexted during tailcap measurement,
for some odd reason the light pulls even without LED 440mA, its not related with the mod.
I get
4.63A on Turbo
2.5A on High
0.8A on med
450mA on Moon
440mA LED disconected
