[[ GXB20 Driver – Homemade Constant Current Programmable XHP50 Single-Cell Boost Driver! ]]
204 posts / 0 new
loneoceans
loneoceans's picture
Hello all and glad to join everyone here at BudgetLightForums!
Here's a weekend project that turned out pretty nice and I thought I'd share. Introducing the GXB20 Boost Driver!
    * Above shows the assembled GXB20 v2. Note typo on silkscreen which reads 3V / 6A - should be 6V / 3A instead, spring not soldered on yet *
TL;DR:
I designed and made a simple constant current single-cell (e.g. 18650) XHP50/70 (6V 3A) Programmable Boost LED Driver. I’ve called this driver the GXB20. This is a true constant current driver which takes feedback from the drive current and regulates the output to match the desired current. I designed the driver to have a 20mm diameter to fit cheap 18650 LED flashlight hosts from Amazon/Ebay. The driver is fully programmable with an on-board ATtiny84A and includes other features such as temperature sensing and cut-off, 256 levels of LED brightness adjustment via constant-current limiting (no more PWM flickering!), battery voltage sensing, memory for various modes, and is designed to be able to supply the full 6VDC 3A output with ~95% efficiency via a boost circuit running off a single 3.7V lithium battery. The GXB20 has undergone one revision and is now in its second version.
Update:
The GBX20 undergone a small update with improved layout and functionality and is now in the GXB20 V2 revision. Functional drivers were assembled and they are now currently driving two of my flashlights! As of May 2016, I have started to focus my efforts on the smaller GXB17 and will pause on working on the GXB20.
Sales and Others:
Unfortunately I am currently unable to provide drivers for sale. However I do have a bunch of GXB20 v1 PCBs available for sale if desired for $2 a piece.
I also wrote a quick temporary page of the GXB20 v1 with the BOM, firmware, schematics etc: http://loneoceans.com/labs/sales/gxb20v1
[The following is from my original post and reflects the progress of the GXB driver starting from V1]
As of right now the main functionality is working and I hope to tidy up the V1 of this driver and release it open source for all to use smile. In addition, I’m also writing up a detailed page on its operation and hope to publish it on my webpage soon (www.loneoceans.com/labs/).
Introduction & Problem
This project was motivated by the desire to:
  1. Use some of the new XHP50 LEDs from CREE which are not only ridiculously bright, up to 2000 lumens per package, but also comes in high CRI (>90) bins
    XML2 LEDs only go to just about 1000 lumens per package! Need more light Smile
  2. Run this LED from a compact, single lithium-cell flashlight. The main problem with this is that the XHP50 LEDs require 6V or 12V (depending on wiring configuration), and this requires a boost circuit to produce the 6V from the 3.5-4.2V from a single-cell 18650. In addition, the XHP50 LED can take up to 3A of drive, so the driver needs to be able to support 18W of power in a small package.
The other motivation for this project was the fact that I found some really cheap 18650 LED flashlights from Amazon/Ebay, which claim to use an XML LED. I took them apart and found that they (appeared) to use Cree XML LEDs but were driving them with a very simple current-limiting resistor + FET for PWM brightness control, and were only about ~600lm.
These flashlights had space for a 20mm PCB driver board, so I decided to design a driver around this constraint and to replace the XML LED from the flashlight (using the same heatsink since they have the same footprint as the XHP50 in 6V configuration), and also to replace the driver with my driver. The goal was to build a simple ~1500 to 2000 lumen single-cell flashlight at a low cost!
The result is a the GXB20 driver – G after my name, X referring to the XHP50/70-series LEDs, B being a boost driver and 20 being a 20mm driver.
Design and Operation
Since I was going to be designing the board from scratch, I figured that the main things I wanted was:
  • (1) proper constant current operation and brightness modes
  • (2) programmability
  • (3) safety features (mostly over-temperature cut-off!).
For adjusting brightness, a simple way and what is often done is to have a fixed boost voltage, run the LED across a current limiting resistor, and then use a FET and PWM to control LED brightness. This works OK, but due to the V_fwd inconsistencies of LEDs, this can lead to widely differing LED brightness. In addition, PWM generates flashing/strobe effects, which is not as pleasant as a true constant-current limiting circuit. After some thinking, I came up with a simple method - the LED I_fwd current is constantly sampled across a small current-sense resistor. This value is then amplified via a digitally variable amplifier (controlled via an Attiny84A) and fed into the boost power circuit. The boost circuit then regulates the voltage to maintain the desired current!
Next for programmability, I decided to go for an Atmel ATtiny84A instead of an Attiny85 due to the fact that it came in a very small 3x3mm QFN package, has EEPROM for storage of memory modes, allows me to use the hobbyist-friendly Arduino environment for sharing / open-source, and comes with a lot more GPIO for additional features.
These new features includes things like battery sensing (so I can turn off the LED drive if the battery voltage falls too low), as well as real-time temperature sensing for dynamic LED brightness control if it gets too hot.
So late last December during a somewhat boring weekend, I sat down and quickly came up with a design, did up the schematic, created a board layout and sent the PCBs to be made. Over the last week, I finally got the PCBs and components, quickly assembled them, and wrote some initial firmware to test it! Now looking back, the board -does- still have some space left, so a 17mm board might be possible too…
Programming and Testing
Soldering this together with traditional tools is possible with a bit of practice, but I was able to get access to a bench microscope which helped a lot!
Together with needle-nose tweezers and a small-tip soldering iron, I was able to put together the PCB without too much trouble. After-all, the smallest component on board is a 0402 resistor/capacitor, so it’s actually quite doable by hand. The small ICs are probably easier done via hot air or via very small soldering irons.
Next, I used a copper-plate and a large soldering iron to reflow the XML LED off the star-heatsink which came on my cheap Amazon LED flashlight. I replaced it with a 90CRI XHP50 (5700K) LED from Cree. Then I soldered it up to the main driver board. Notice I also reused the spring on the original driver board and moved it over to the new one.
For programming, I’m using the standard 6-pin AVR ISP 2 programming header. The default header is very large at 0.1” pitch, so instead I made a 0.05” 6-pin ‘adapter’ using a 0.05” 6-pin female header to a 0.1” pitch header.
Notice that the driver board has 6 pads for soldering on a 0.05” header. For this developmental board, I simply soldered the header on (which I can desolder later). Once I finalize the firmware, I can simply press-and-hold the header onto the pads during programming of the microcontroller.
Finally I did a quick test – in short, it all seems to work great! cool
Right now, I'll be mostly working on firmware and verifying its operation, as well as hopefully adding some interesting effects such as ‘candle-mode’ etc..
This project turned out to work out quite nicely even though I only spent a short weekend on it! As a result I'm sure there are a lot more improvements and things to change which I can make in upcoming revisions, and I appreciate any thoughts,comments, suggestions and questions!
More to come soon and stay tuned on this thread for updates as I continue to work on the GXB20!
- Next-gen Switching Drivers: Lume X1 and Lume1
- High Power Boost Drivers: GXB100 GAN 100W, GXB172 17mm 50W
- Older: GXF22, GFS16, GXB17 & GXB20
Edited by: loneoceans on 06/13/2017 - 13:17
NikolaS
NikolaS's picture
Grat work ! I want one !
Welcome to BLF Beer
Anthon
Last seen: 5 days 17 hours ago
Nice!! Can’t stand the wait to see these kind of drivers for sale. Would you consider selling some drivers here?
mattlward
mattlward's picture
Last seen: 10 hours 13 min ago
Omg… I want one! Put a price on it, please. Btw, welcome!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
teacher
teacher's picture
Last seen: 2 years 1 month ago
Very nice!!! Welcome to BLF…….. Smile …. Thumbs Up
I also would love to get a couple of these………. Wink
Lexel
Lexel's picture
Last seen: 10 months 2 weeks ago
I would take one in parts, can do solder job on my own
gchart
gchart's picture
Last seen: 7 hours 51 min ago
That has got to be the most amazing “first post” I have ever seen.
Sounds marvelous, I can’t wait to hear about the real-world experience!
Beachlogger
Last seen: 9 hours 33 min ago
I agree with everyone else, I want Silly
djburkes
djburkes's picture
Last seen: 3 years 8 months ago
Very nice…finally good runtime by using a 18650 instead of two 18350s!!
AEDe
AEDe's picture
Last seen: 1 day 7 hours ago
Is it compatible with low current button? Or can be easy modified for it?
hexcode
Last seen: 7 months 2 days ago
Welcome to BLF. Subbed!
Angler
Angler's picture
Absolutely brilliant! Thumbs Up
I’d bet you have some other great projects we’d love to see too.
J-Dub74
J-Dub74's picture
Last seen: 4 months 4 weeks ago
Welcome and Wow! I very much look forward to seeing how this works out, You have our attention. Thumbs Up
texas shooter
Last seen: 6 hours 59 sec ago
Loneoceans, welcome aboard. For me your timing couldn’t have been any better. I’m working to get a bit more life back into the P60 style flashlights. A machinist is currently building a prototype host for the newer 20700/21700 lithium-ion cells. This would allow dropins another host with more potential. Your 17mm driver combined with the new Cree XHP50.2 would push this project to a pretty decent level. I can only hope your driver comes to life in 17mm’s soon.
kiriba-ru
kiriba-ru's picture
Last seen: 5 hours 59 min ago
I think you wont be able to put out more than 1.8A with this inductor.
loneoceans
Thanks everyone for your kind words and comments! Hopefully when I get this driver done people will find it useful! cool
Anthon wrote:
Nice!! Can't stand the wait to see these kind of drivers for sale. Would you consider selling some drivers here?
This really wasn't my intention and I plan to release all this open source if people find it useful!
However if enough people are interested I can find a way to see if I could get a batch of them fabricated, so do let me know! Assembling by hand takes a little too long since soldering does take a while, so I'll have to see what sort of assembly options there are before I can give a price estimate. Smile Unfortunately I wasn't able to put up an OSHpark order since the PCB spec is a little smaller than OSHpark... (trace / spacing limitation).
Also, just thought I'd ask - are there any companies whom I might be able to do some sort of collaboration with to offer these for sale who can help with assembly and distribution? I'm just doing this for a hobby and I'd be happy to have people solder up their own drivers but this driver does have a few pretty challenging components to solder due to the small pitch QFN packages.
I specifically designed this (as a quick weekend project!) as a mod for my cheap flashlight from Amazon which only has a single tail-end switch. However this necessarily requires the switch to handle the full current. Fortunately it can be easily modified using the internal boost converter fet as the main switch for true low-current button operation. The Attiny84A is also much more capable than the usual ATtiny85s often used so there's a lot of overhead available. Regardless, I'm very new to the budget/flashlight community so I'd like to understand these kinds of topologies better - do such flashlights have 2 switches? Or just 1 switch having the main power from the battery permanently connected to the driver?
texas shooter wrote:
Loneoceans, welcome aboard. For me your timing couldn't have been any better. I'm working to get a bit more life back into the P60 style flashlights. A machinist is currently building a prototype host for the newer 20700/21700 lithium-ion cells. This would allow dropins another host with more potential. Your 17mm driver combined with the new Cree XHP50.2 would push this project to a pretty decent level. I can only hope your driver comes to life in 17mm's soon.
Thanks for the background! Once I make sure the 20mm driver is working fine, I'll definitely look into doing a 17mm version. So any features / suggestions / thoughts are most welcomed Smile
That was a concern I had as well - how to find an inductor small enough to fit!? Fortunately this mighty inductor has a 12A rating with 13 DC saturation current rating! Based on my simulations with 3.9V input and 6V 3A output at my operating parameters, the inductor only sees between ~5.7 to 6.2A and well within spec.
But the proof of the pudding is in the eating! So I managed to do more work and run it at full power - it works great with some ~6+A at the input side!
I was able to spend a bit more time to work on the firmware, with the idea of keeping it as simple as possible and avoid making it far too complicated with too many modes. It's still far from complete, but I was able to test basic functionality of different brightness values and under-voltage sensing and protection.
I was also able to run it for a while at its full 18W (6V 3A) output driving the XHP50 LED! The LED (on the 20mm heatsink) gets - extremely hot - really quickly, so the limiting factor of running a XHP50 at its highest power certainly seems to be more of a heatsinking issue than being a challenge for the driver! Smile The LED is of course, very beautiful and bright!
Next step is to tidy up the firmware into something presentable (I'm sure lots of people here can do a much better job than I can!) and then I'll put it into the host and see how it performs!
Nicolicous
Nicolicous's picture
Last seen: 8 months 2 days ago
Respect go to you loneoceans Big Smile
when are they available to purchase ? Smile
Nico -.-
KeepingItLight
KeepingItLight's picture
Last seen: 2 hours 36 min ago
Amazing work! Thanks for sharing it.
I am a fan of boost drivers and buck/boost drivers. I like the predictable output levels they provide. In some ways, I am a throwback. For flashlights that use low-voltage emitters, such as the Cree XP-L, I would rather have a well-behaved boost driver—and the flat runtimes it produces—than a FET driver that runs "direct drive" in its highest modes. I don't need a flame thrower that pushes an emitter to its limit.
Yes, I know. That makes me the oddball around here!
testedandbaked
testedandbaked's picture
In one fell swoop, you’ve managed to address several longstanding limitations of running lights off single cells:
1. Lack of a widely available open source boost driver (allowing high voltage LEDs)
2. Lack of a programmable current controlled driver
3. Perhaps a shift away from dependence on 7135s
4. A programmable board with a smaller QFN package (Most drivers here use the larger SOIC-8)
Welcome to BLF! This may be the beginning of a new wave of drivers.
To answer your question, most flashlights have a reverse-click switch on the tailcap that handles the full current. The other common type is an e-switch, where a single low-current electronic switch (often side mounted near the driver end) controls the modes with the battery permanently connected, variations on the theme include having 2 buttons or a magnetic ring as a switch.
There are some rarer lights with the e-switch mounted on the end, but these require a carrier for the battery with a separate signal wire going to the tailcap.
DavidEF
DavidEF's picture
Last seen: 3 days 31 min ago
Welcome to BLF! This is truly a wonderful first post. Thanks for sharing this with us! I hope you enjoy your stay!
A few thoughts I have:
  1. Learn about Direct Thermal Path MCPCB boards for LEDs. This will help you tremendously with heat issues.
  2. Have you thought about using solder paste and re-flowing the components on the driver board? If done right, it’s a lot easier than individually soldering tiny components with a soldering iron.
  3. 17mm really is the most common driver size we see in most flashlights. So getting your design into a 17mm footprint will certainly make it more universal.
  4. Other sizes are nice, too. If you’re interested, the easiest way to make multiple sizes is to lay out for the smallest possible size, then keep the same layout and only extend the board diameter for the “larger” driver sizes.
  5. Have you thought about making a single-cell 12V boost driver? We could certainly use one for the XHP-35!
- The YKK Philosophy
mrheosuper
^ about 12V, i think he(we) can modify the Feedback Resistor, so the voltage can change
if only this driver is 17mm
Forgot my pen
giorgoskok
giorgoskok's picture
Last seen: 1 week 1 day ago
Btw , the led you use is a LatticeBright (not original Cree xhp50) , i hope you know Smile
Well i don’t know , i only commented the led on the photo Silly
mrheosuper
no, he reflow the XHP50 on the old MCPCB
Forgot my pen
Lexel
Lexel's picture
Especially with 18W on a 5050 package you need a DTP star
Also a spring bypass should improve the lights performance as you get less voltage drop and heat
DavidEF
DavidEF's picture
Oh yeah, thanks Lexel! I forgot to mention the spring. I knew there was something else! The spring needs to be upgraded at least! Or, as Lexel says, a “spring bypass” can be done. Look that one up. There are a few ways to do that, and it’s definitely a big improvement for high wattage lights!
Mike C
Mike C's picture
Last seen: 5 days 21 hours ago
I’m certainly interested in the schematics. Are you going to release them too?
Splott-Light
Splott-Light's picture
@ loneoceans,
Welcome to BLF.
You certainly know how to make a Good 1st Impression.
Most of this stuff is beyond me, but good to see someone addressing the needs of the Members.
I’ll be interested to see how this all pans out.
Cheers,
Splott-Light Smile
P.S. If you get your “Milla” off Raccoon City, you’‘re then “Officially” in!
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
vwpieces
vwpieces's picture
Last seen: 1 week 3 days ago
As a first post and “weekend project” Saying Welcome to BLF and thanks for your contributions so far is not enough.
Thank you and welcome to BLF.
texas shooter
Lot of information through these pages. And we’ll mug you with it all. So just ask when needing component sources or already researched material.
loneoceans
DavidEF wrote:
Welcome to BLF! This is truly a wonderful first post. Thanks for sharing this with us! I hope you enjoy your stay! A few thoughts I have: # Learn about *_Direct Thermal Path_* MCPCB boards for LEDs. This will help you tremendously with heat issues. # Have you thought about using solder paste and re-flowing the components on the driver board? If done right, it's a lot easier than individually soldering tiny components with a soldering iron. # 17mm really is the most common driver size we see in most flashlights. So getting your design into a 17mm footprint will certainly make it more universal. # Other sizes are nice, too. If you're interested, the easiest way to make multiple sizes is to lay out for the smallest possible size, then keep the same layout and only extend the board diameter for the "larger" driver sizes. # Have you thought about making a single-cell 12V boost driver? We could certainly use one for the XHP-35!
Thanks for the warm welcome DavidEF and everyone here :). Thanks for the heads up for DTP heatsinks!
I reflowed the old XML LED off the original heatsink and replaced it with a XHP50 but as I've found, it gets very hot very quickly. As a result I've in fact ordered a few 20mm copper 'Sinkpads' for additional testing. I did some reading up and it appears that Noctigon is another good brand? These should perform better and I plan to do a quick thermal comparison test to try to quantify the improvements. Would appreciate additional suggestions for good heatsinks (short of just making my own! Though I'd like to keep to the spirit of this project which was to do a simple modification of an existing low-cost flashlight).
For reflow - I do reflow in an over on a regular basis, but I didn't send stencils to be made for this project just yet! I suppose if this project is successful enough I'd make a stencil so I can do a small run perhaps ^_^.
Again thanks on the input for 17mm, I'll definitely be trying to see how I can optimize the design for 17mm. One thing I'm concerned about is the drivers thermal performance and I tried to take as much care as possible during layout to ensure that the power components have good thermal sinking to the ground planes (and eventually to the outside ring to the host). For larger driver sizes I think it makes more sense to optimize it for even better components for less loss and to add some nice to have features such as larger packages for easier soldering and programming. But I'll like to focus on the GXB20 first, then perhaps 'GXB17' Smile
Finally, with very minimal work (or in fact... none at all!), this driver can certainly drive 12V LEDs! This is a constant current driver so it will easily generate 12V to match the desired load current. I'll have to re-check the components (e.g. the output capacitor needs to be replaced with a higher voltage one, safety protection features need to be adjusted etc) but making it a 12V driver will certainly work. The reason I went for 6V was due to the fact that (1) commonly found XML heat-sinks have footprints compatible with XHP50 in 6V configuration and (2) I did some quick simulations on the boost drive and it's a little bit more efficient at 6V output compared to 12V output (across the range).
Lexel wrote:
Especially with 18W on a 5050 package you need a DTP star  Also a spring bypass should improve the lights performance as you get less voltage drop and heat!
Will do - I'll try out with some Sinkpad IIs I purchased earlier (http://www.sinkpad.com/datasheet-sinkpad-2.php(link is external)) though it also seems like Noctigon is great too! I'll also document the spring bypass and additional methods I can do to improve efficiency. Speaking of springs, does anyone have any recommendation for good springs I can use which are not too large? For example the one I'm using now has a fairly large 8.5mm base spring which limits PCB space. I was looking at some springs like the 5mm or 7mm base springs on (http://www.mtnelectronics.com/index.php?route=product/category&path=25_81) - are these good or do you know of better ones?
Finally, I've been reading a little bit more about the different modes in flashlights and it made me wonder - would a 'moonlight mode' be something useful? And if so, what the typical brightness that people like?
Thanks again to everyone for the encouragement and kind words and for following this project. I do appreciate your time Smile
Lexel
Lexel's picture
I like the small Convoy driver spring on my C8 or other drivers
Its around 4mm in diameter
The tail spring does the most of the job being higher snd softer
If you got problems with heat on a 17mm driver you can put the MCU and other non power parts on a slave board similar to this
