In one fell swoop, you’ve managed to address several longstanding limitations of running lights off single cells:
Lack of a widely available open source boost driver (allowing high voltage LEDs)
Lack of a programmable current controlled driver
Perhaps a shift away from dependence on 7135s
A programmable board with a smaller QFN package (Most drivers here use the larger SOIC-8)
Welcome to BLF! This may be the beginning of a new wave of drivers.
To answer your question, most flashlights have a reverse-click switch on the tailcap that handles the full current. The other common type is an e-switch, where a single low-current electronic switch (often side mounted near the driver end) controls the modes with the battery permanently connected, variations on the theme include having 2 buttons or a magnetic ring as a switch.
There are some rarer lights with the e-switch mounted on the end, but these require a carrier for the battery with a separate signal wire going to the tailcap.
Welcome to BLF! This is truly a wonderful first post. Thanks for sharing this with us! I hope you enjoy your stay!
A few thoughts I have:
Learn about Direct Thermal Path MCPCB boards for LEDs. This will help you tremendously with heat issues.
Have you thought about using solder paste and re-flowing the components on the driver board? If done right, it’s a lot easier than individually soldering tiny components with a soldering iron.
17mm really is the most common driver size we see in most flashlights. So getting your design into a 17mm footprint will certainly make it more universal.
Other sizes are nice, too. If you’re interested, the easiest way to make multiple sizes is to lay out for the smallest possible size, then keep the same layout and only extend the board diameter for the “larger” driver sizes.
Have you thought about making a single-cell 12V boost driver? We could certainly use one for the XHP-35!
Oh yeah, thanks Lexel! I forgot to mention the spring. I knew there was something else! The spring needs to be upgraded at least! Or, as Lexel says, a “spring bypass” can be done. Look that one up. There are a few ways to do that, and it’s definitely a big improvement for high wattage lights!
Thanks for the warm welcome DavidEF and everyone here :). Thanks for the heads up for DTP heatsinks!
I reflowed the old XML LED off the original heatsink and replaced it with a XHP50 but as I've found, it gets very hot very quickly. As a result I've in fact ordered a few 20mm copper 'Sinkpads' for additional testing. I did some reading up and it appears that Noctigon is another good brand? These should perform better and I plan to do a quick thermal comparison test to try to quantify the improvements. Would appreciate additional suggestions for good heatsinks (short of just making my own! Though I'd like to keep to the spirit of this project which was to do a simple modification of an existing low-cost flashlight).
For reflow - I do reflow in an over on a regular basis, but I didn't send stencils to be made for this project just yet! I suppose if this project is successful enough I'd make a stencil so I can do a small run perhaps ^_^.
Again thanks on the input for 17mm, I'll definitely be trying to see how I can optimize the design for 17mm. One thing I'm concerned about is the drivers thermal performance and I tried to take as much care as possible during layout to ensure that the power components have good thermal sinking to the ground planes (and eventually to the outside ring to the host). For larger driver sizes I think it makes more sense to optimize it for even better components for less loss and to add some nice to have features such as larger packages for easier soldering and programming. But I'll like to focus on the GXB20 first, then perhaps 'GXB17' :)
Finally, with very minimal work (or in fact... none at all!), this driver can certainly drive 12V LEDs! This is a constant current driver so it will easily generate 12V to match the desired load current. I'll have to re-check the components (e.g. the output capacitor needs to be replaced with a higher voltage one, safety protection features need to be adjusted etc) but making it a 12V driver will certainly work. The reason I went for 6V was due to the fact that (1) commonly found XML heat-sinks have footprints compatible with XHP50 in 6V configuration and (2) I did some quick simulations on the boost drive and it's a little bit more efficient at 6V output compared to 12V output (across the range).
Will do - I'll try out with some Sinkpad IIs I purchased earlier (http://www.sinkpad.com/datasheet-sinkpad-2.php(link is external)) though it also seems like Noctigon is great too! I'll also document the spring bypass and additional methods I can do to improve efficiency. Speaking of springs, does anyone have any recommendation for good springs I can use which are not too large? For example the one I'm using now has a fairly large 8.5mm base spring which limits PCB space. I was looking at some springs like the 5mm or 7mm base springs on (http://www.mtnelectronics.com/index.php?route=product/category&path=25_81) - are these good or do you know of better ones?
Finally, I've been reading a little bit more about the different modes in flashlights and it made me wonder - would a 'moonlight mode' be something useful? And if so, what the typical brightness that people like?
Thanks again to everyone for the encouragement and kind words and for following this project. I do appreciate your time
Moonlight is definitely a useful mode. There are disagreements about how low it should be, however. I find that around 1 - 3 lumens works fine for me. More than a few lumens can get into being too bright for moonlight mode use. Some want <1 lumen, which is IMHO more of a firefly mode and not useful to those of us who don’t have ToyKeeper’s super night vision.
Hi Loneoceans, welcome to BLF!
Saw your crazy tesla coil setup in the science center but too bad it was not switch on that day…
Anyway, really hope you can make a 17mm version!
Welcome to the forum and thank you for sharing your experiences! Congrats on your successful full power test (6V@3A). I didnt think those power levels possible from a 20mm boost driver, much less your thoughts for a 17mm. Your skills are simply amazing and accomplished at blinding speeds far beyond anyone else Ive seen to date. Is this just a hobby or are you also a NASA EE?
Id love to hear about some of your other projects when you have time to post.
