I can get measurements. Could tear down my modded L4. Wonder if the Y3 style switch would work - I'll take a closer look.
That L4 host is tempting Tom! From what I see it takes a Convoy C8 reflector?
Printing this to scale might help to judge the fit (interior of the outline is 23.6 mm across, east-west):
Ahh. Just took my L4 apart. The stock driver is slightly bigger than your Y3 at 23.6, guess you knew that. There's slop though it how it mounts. There's really 23.8 mm measured space, and the stock back tab is too small both in width and depth. The L4's switch sticks out a bit further, is slightly higher. The height may be ok, but depth would probably be a problem, but you could glue a disc to the metal button of the L4 since it's a nice big round surface.
I think I bought some of those L4 switches from DigiKey... Gotta check.
Look'n at your design, the back tab, though you matched the driver, doesn't do all that much. The cutout in the L4 is much wider. Now of course I got an old L4, so things could have changed in the latest L4's.
Tom, I think this is the DK switch for the L4:
http://www.digikey.com/product-detail/en/apem-inc/MJTP1117/679-2400-ND/1795496
I will see if I can fit the footprints for both switches. I shared a WIP 2.0 on OSH in the meantime. It has a bigger key tab. Think I will up-size the board to 23.8 mm as well, nothing a little sanding cannot fix if it ends up too tight.
K, sounds good. These are the ones I ordered: https://www.digikey.com/product-detail/en/c-k/PTS635VH39-LFS/CKN9089-ND/1146803. On mine the actuator is slightly longer, and pressure is slightly higher, yours have a higher 100,000 cycle rating, other than that they look the same. Ohh - mine are out of stock, and thinking I ordered these for building the Roche F6, driver designed by Halo I think. This was 2 years ago...
Also - got the Y3 driver tabs sanded down a little and got a really nice snug fit in the Y3 I'm updating . Much better fit than the stock driver - should be a much improved mod, better than the stacked driver, slop fit for sure...
Nice for the Y3 Tom!
My 17 mm rev04 boards came in. They are in the thin/2 oz option, so took longer than usual. They feel paper-thin if you are used to the regular boards.
I fitted the THD switch to the draft LD-34 replacement. It is huge compared to the Y3’s SMD switch:
Still have to fine-tune the outside diameter, ground rings and the flat a little, but let me know if you have any comments. The switch took away some space for the spring as well.
Ordered, thanx! I got one old L4 and just ordered one L4 host from BG with M4D M4X's discount, so $16.
Welcome Tom.
Still wondering if I should pick up a few hosts as well. Looks like a no-brainer though.
Also check this one out: http://www.gearbest.com/led-flashlights/pp_572171.html?wid=21
An UltraFire L4 clone, cheap, but not as cheap as the real L4 host.
OK, the slightly used Y3 upgrade came out great!
After it's all modded/cleaned up:
I did 2 boards. Will get to the 2nd some day:
I used Arctic Alumina epoxy to sure up the switch:
22 AWG bypass on the spring. I also applied some solder paste on one side of the LED+ pad, then the iron on the other - think the holes filled up well w/solder. The bypass is soldered to the pad with the thru holes, so minimum path to the LED wire:
Seems to be my favorite LED right now. A KD XPL2 V6 3B, on a KD 20 mm MCPCB. Used 22 AWG because didn't think I'd get the clearance with 20 AWG. This is an early model Y3, and has a 23 mm wide flat reflector base. Later models I have use a smaller flat surface and different centering piece. The new ones need the centering piece significantly trimmed, sanded down, then the MCPCB is too low,so have to use a copper shim to elevate it. This one did not require a shim:
Here's a better shot in my lightbox studio on the 2nd driver:
Assembled view of the LED, 2nd in moon mode:
The driver fit great, nice and snug with just a little filing. The results? Well, it's impressive:
On a LK @4.20V:
- 8.9A at the tail (clamp meter) - wow!
- 2,280 lumens @start, 2,150 @30 secs
- 123 kcd measured at 5m (700 meters)
Originally, this light had a Nanjg jury rigged with a FET on it, and a XM-L2 U2 1A domed. This was from May 2014. Originally, this is what it did:
On a SONY 26650 fully charged (best performing cell at the time):
- 5.3A at the tail (DMM w/heavy gauge leads)
- 1,680 lumens @start, 1,600 @30 secs
- 121 kcd measured at 5m (696 meters)
So it got a 34% bump in lumens @30 secs, barely measurable bump in throw. The XPL2's don't throw as well as the XPL or XML2 - I've seen this in couple of other mods.
Nice work as usual Tom.
Nice job Tom! Love your reflow work on those drivers.
Built up a 2nd Y3 using an XPL2 V5 4000K LED but output and amps is a bit lower, just under 1,900 lumens, amps: ~7.6A. On this one, I added a LED mounted on top of the Y3 switch so it lights up behind the switch cover - actually came out pretty nice. I used a 4.7K resistor soldered tombstone style on the pin #3 pad, and a pink 0805 LED. I use pink because it's something different, and seems to have decent brightness for the power used. Green and orange also do well. For ramping, if you stop at a level using only the single 7135, the indicator LED will blink once - if stopped at a FET level, it blinks twice. This is the same feature I added in TripleNarsil recently. A nice trick to use with this is ability to easily disable the indicator LED:
-> from OFF, press&hold til the main LED goes ON (moon), then quickly click to turn the main LED OFF -- the indicator LED will be turned off as a result. It stays off til you turn the main LED ON and OFF again, but not using this trick method. So, it's a nice quick way to lower parasitic drain and/or just simply want the Ind. LED off when the light is not used for a while.
I dont understand how you have accomplished this Tom but do know its good.
Finally got to post the pics of the mounted LED. Tombstoned resistor, little thermal epoxy under the LED, 30 AWG stranded wire:
Tom. If I understood 1% of what you do l’d consider myself pretty smart. :person_facepalming:
Love the mod. :+1:
Nice one Tom!
I was actually wondering when I built mine if that was a missed opportunity. Would have been easy to add LED and resistor pads beside the switch. Not sure how efficient it would be in lighting the button from there though, even with the LED mounted on its side.
It's rare I can get a driver to accommodate the LED resistor - yes, wish it was there. HQ did some original work in his SRK - lot's of options accommodated - quite unique, very useful. Built one up yesterday for LDO, but will use the 2 remaining boards w/regular diode in SRK's.
