This is true but there is a price difference. Output wise the MT03 is a lot brighter but you may not be able to see by eye that well. You would need to be in a big area.
Okay i am a dope! I was wondering why the batteries are wearing out at different speeds on some occasions you need either 2 cells in series or 2 cells in parallel for the light to work. So if one cell isnāt making contact both slots wont work in either the series or the parallel. If i can get all the batteries to make contact the light runs and drains all the batteries even like with a few millivolts. I feel like the light could benefit from double springs or at least a bigger tab on the positive slots.
So how moddable is the MT03? Can we add a sense resistor to the stock driver, for example? Or is it possible to flash different firmware as Iād prefer no mode memory, and Iād really prefer the firmware of the BLF A6.
I added another video its got like 12 Min if beam shots.
Compared the MT03 to
Convoy L6
MM25MB
Car head lights
Edit i didnāt add the BLF A6 and the G20 to the video i thought i did but its not there. I will up load them separate. The BLF A6 does a good job on that field that is why i always recommend them The car head lights are from a 2014 Toyota corolla the lights are a bit shit stock i want to get newer builds for when i am high way driving at night.
Yea i was looking at them also i tried to rip them of but they are glued on real good. Right now if i fiddle with it my LG cells work okay they all drained even when i done the video last night,
I bought one of these from Banggood about 3 months agoā¦ not been very happy at all. Light worked for all of about 15 minutesā¦ and died. Trying to get Banggood to do anything about it is next to impossibleā¦. their customer service sucks as far as iām concerned. I did get Haikelite directly to send me a new driverā¦ took about 8 weeksā¦ but finally got here. Iāve never opened up one of these to work onā¦ i can do the soldering fine i suspect, but not sure exactly HOW to open this light up? Is there a spanner wrench to be utilized? where does one find on for these things? Any help would be appreciatedā¦ brand new hereā¦
Hey how are you doing man? I donāt have this light, but I do have a couple of other Haikelite lights, so this one should open the same way. There are two dimples on the shiny outer ring around the spring that makes contact with the battery tube. Use something like needle nose pliers to turn it counter clock wise, and you will have access to the driver. Good luck and welcome to BLF! :partying_face:
