I may just do that. I like the simplicity of TK’s FW, but I will look into narsil and the attiny85.
Can someone tell me where to get TK's ramping firmware and what are the requirements (13A, 25, etc.)? I've heard it mentioned many times but can't find it.
The one I’m talking about is, in the FW repository:
Toykeeper/Ferrero_rocher/Ramping_UI_table.c
It works on the attiny13a. I had to comment out the section about the red and green voltage indicator lights to get it to work on my normal FET driver from mtn.
Ahh, ok - thanx! Didn't realize it was there. Interesting... Sounds the same way Narsil ramping works, accept mine is over a FET+1 which can get tricky.
I'm trying to compile the default bistro code in AtmelStudio 7. I have added in the winAVR flavor but cannot generate the hex file. This sure is frustrating to not be able to compile known good code.
"Severity Code Description Project File Line Source
Error recipe for target 'main.o' failed Bistro C:\bazaar\Atmel\toykeeper\Bistro\Bistro\Bistro\Release\Makefile 98 Build"
Where line 98 is:
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP) $(LINKER_SCRIPT_DEP)
@echo Building target: $@
@echo Invoking: AVR/GNU Linker : 0.0.0
$(QUOTE)C:\WinAVR-20100110\avr-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="Bistro.map" -Wl,--start-group -Wl,-liberty -Wl,-litclstub32 -Wl,-litkstub32 -Wl,-lsimulavr -Wl,-lsimulavr.la -Wl,-ltcl84 -Wl,-ltclstub84 -Wl,-ltk84 -Wl,-ltkstub84 -Wl,-lgcc -Wl,-lgcov -Wl,-lcrtbegin.o -Wl,-lcrtbeginS.o -Wl,-lcrtend.o -Wl,-lcrtendS.o -Wl,-lcrti.o -Wl,-lcrtn.o -Wl,-lstdc++ -Wl,-lstdc++.la -Wl,-lsupc++ -Wl,-lsupc++.la -Wl,-lsta43464 -Wl,-ltclConfig.sh -Wl,-ltkConfig.sh -Wl,-lcrt86401.o -Wl,-lcrtc8534.o -Wl,-lcrts1200.o -Wl,-lcrts2313.o -Wl,-lcrts2323.o -Wl,-lcrts2333.o -Wl,-lcrts2343.o -Wl,-lcrts4414.o -Wl,-lcrts4433.o -Wl,-lcrts4434.o -Wl,-lcrts8515.o -Wl,-lcrts8535.o -Wl,-lcrttn11.o -Wl,-lcrttn12.o -Wl,-lcrttn13.o -Wl,-lcrttn15.o -Wl,-lcrttn22.o -Wl,-lcrttn24.o -Wl,-lcrttn25.o -Wl,-lcrttn26.o -Wl,-lcrttn28.o -Wl,-lcrttn44.o -Wl,-lcrttn45.o -Wl,-lcrttn84.o -Wl,-lcrttn85.o -Wl,-lcrttn261.o -Wl,-lcrttn461.o -Wl,-lcrttn861.o -Wl,-lcrttn2313.o -Wl,-lc -Wl,-lm -Wl,-lobjc -Wl,-lobjc.la -Wl,-lprintf_flt -Wl,-lprintf_min -Wl,-lscanf_flt -Wl,-lscanf_min -Wl,--end-group -Wl,-L"C:\WinAVR-20100110\lib" -Wl,-L"C:\WinAVR-20100110\lib\gcc\avr\4.3.3\avr25" -Wl,-L"C:\WinAVR-20100110\lib\gcc\avr32\4.3.2" -Wl,-L"C:\WinAVR-20100110\lib\gcc\avr\4.3.3" -Wl,-L"C:\WinAVR-20100110\avr\lib" -Wl,--gc-sections -mmcu=attiny25
@echo Finished building target: $@
"C:\WinAVR-20100110\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "Bistro.elf" "Bistro.hex"
"C:\WinAVR-20100110\avr-size.exe" "Bistro.elf"
Been compiling/linking Bistro fine in AtmelStudio 7.0 for a long time now, just built in under Win10. Here's a complete Bistro ZIP file, with the 7.0 solution and project file all complete. Simply unzip into an appropriate named folder (like Bistro), and open the solution file (bistro.atsln) in 7.0, and should work fine.
On my Google share: drive.google.com - Bistro
I might have some tweaks in the source code, but minor if any functional change at all.
Thank you I will take a look at this now. I finally figured out what i was doing wrong. (I'm not a C guy and have never used visual studio). I thought I was viewing the output window, but realized it was displaying then disappearing after 1/2 a second. once I could see the real output... Well Damn the problem was obvious. I ended up creating a new project again and moving over the bistro files. But when it compiles I get a Memory Overflow :( 117.8% full.
Really I'm just trying to learn how to use this thing so I can make some minor tweaks to the UI. But out of the box it has memory overflow? Seems odd to me.
I will try to import your project now.
edit: OMG thanks so much! your version compiled first try. I see allot of chages vs what is in the repo. Voltage monitor has a different delay set. fastpress setting is set inside the "if" instead of outside. Faster battery check :) Removal of unused SOS code, some changes to the strobe that I don't fully understand. Some changes to CAP_PIN (whatever that is)...lots of other stuff removed that I don't understand at all.
I'm such a newb at this, but I guess it is expected we will modify the code to fit on the MCU? Or are these typically flashable out of the box? I can see some of it was safe to remove as it did not look like it was being used, but allot of the other parts that were changed I cannot really understand what they do or the reason for the changes.
I guess I will have to base my changes on your working code instead.
Thanks!
Regarding the memory:
Did you change “Debug”-setting to “Release” when using original Bistro?
yea
The CAP_PIN change was only to remove the compile switch - function is the same. Think most changes are like that, except removing SOS, etc.
Ok, getting closer to releasing the newest driver. DEL got a chance to test out the first prototype and it works! Just needs some minor changes to perfect some things and it is ready for round 2.
A few notes for the firmware side of things.
With the new design we can drop C1 down to a ~2.2uf cap which should improve power off times.
I was also able to cram a tiny85 onto it so we now have a lot more space to place with!
1206 C2 pads were able to be used
It includes a bleeder resistor so the voltage divider can be whatever is ideal in other aspects.
Hopefully with a bit more tweaking it will be ready for release.
Hi, I have a help/knowledge request. I want to alter Toykeeper’s ramping_table_UI FW to work with FET+1, in order to get a lower moonlight mode. My hope is that this won’t be too difficult to do. A new mode list will have to be made, but the attiny13a should still be capable of running it. Before I go fiddling around trying to do this I thought I would see if there was some concise wisdom someone could give me regarding this. For example, I see in FET+1 FW codes where the pwm levels are defined for each channel for each mode, but I can’t find where these channels are assigned to the specific pins of the chip. If I succeed I would like to share the code if that is appropriate. I really like this UI, and I think it would be perfect for me if it had that moonlight capability.
I'll post my new version up is a few hours got it zipped and documented now, just no time this moment. It's a BIG overhaul and includes much easier pin assignments and cleaner configuration, along with a bunch of new features. It will remerge the divergent standard bistro, triple-down, TA, etc, and a bunch of new possibilities.
OK, I couldn't wait.
Flintrock, 2017 (C) First line goes to ToyKeeper, the original author of bistro. What is it? It's kind of a highly customizable bistro-family (OTSM, classic, TA, biscotti, a BLFA6 clone for >= attiny25) box set with lots of new features. Many configurations are pre-built (> 70 and counting) but you can compile it for custom board layouts up to 4 channels and easily make custom modegroup definitions. Much space savings to get more features into attiny25. The flagship feature is OTSM which …
Ok, getting closer to releasing the newest driver…
Also look'n great! Congrats!!
Added a link in the OP to Flintrock's bistro-HD thread. If there is anything else that should be linked or anything that should be changed in the OP. Please let me know via PM. This thread is belongs to the programmers and I will do my best to make the OP meet their needs.
Well regarding references, I've had a mind to try to write up as much as I can about everything that was learned and dreamed up about OTSM from all the discussion and testing here, (nobody can read all that), but I'm afraid I probably won't get to it.
At easyb I might not fully understand your question about Fet+1. But one thing BHD attempts to do is bring the tripple, quadruple, double(or single) channel bistro versions back together with preprocessor configs that work again. You can select any combination of PWM channels you want in the fr-tk-attiny.h. Select the corresponding layout in bistro.c Define the corresponding "ramps" any way you wish in modegroups.h. For moon modes you're best to stick to PWM and PWM2 channels, because they run on timer0. It seems to be just very difficult to get good control at low levels on timer1, although I did get a pretty good moon out of channel 4 by setting it to 0 PWM (not zero mode, mode zero shuts off PWM4 entirely, the only way I found to get full off, so just would want 0 in the ramp table for PWM4) . PWM3 works differently than 4, and is maybe ok too.
So I made little excel calculation for off-time, including power consumed while waiting to detect the pin fall, just using RC and threshold voltage etc. Everything matches up reasonably well with what I saw. It looks like tweaking a few things should get it well up over 3s with only a 3.0V battery, including going from 30uF to 47, but also getting the better diode, going to a V-chip, and lowering the pin voltage by 25%. It should work like this with a bit higher resistor values too, so that's good (I'm going to try 500 R1, 1500 R2 and no bleeder). I have the v-chip but I'd forgotten to get the diode and resistors, so still waiting to put it together. The Ta cap shouldn't be very temperature sensitive and neither should the reverse leakage on this new diode, so I'm hoping the numbers stick when hot. I think this will likely work well.
Oh and of the chips I've seen,
25's were revision G (good)
25V: revision F (still good),
45V: revision G (good),
85: revision B (bad/no bods).
So the situation with attiny85 seems bad for BODS.
Hmm... so good and bad. At 3.0V input, the new setup (v chip, Ta cap, low leakage diode, tuned voltage divider) is able to measure off-clicks over 3s in length, (I'm pretty I measured it closer to 4 once, but haven't tried to reproduce that) using only 47uF of capacitance, and does it even with high overall bleed resistance (4.3kOhm). At that voltage and bleed value, that's as good as I would have dared hoped for.
The bad, for some reason it can only do that on low modes. I've done a ton of measurements. Off-time power consumption has nothing to do with what mode it was in before it turns off, because I always shut down PWM before sleeping. mcu power consumption while it detects shutdown does impact it though. LED consumption does not, because it's isolated by the diode from the MCU off-time cap, C2. If anything high LED current should drain C1 faster and result in quicker off-time detection before the mcu eats up its reserves.
Ok, so I measured mcu current draw in all modes (again). It doesn't vary much. With my powersaving trick enabled it's about 2.1mA for 1 7135 or the fet. It's closer to to 3mA for all 7135s (the difference actually being in-line with the spec sheet drive current for the 7135s, although it's interesting that these are technically still on when the FET is running, and yet the drain goes back down to 2.1 when the FET is on). As it turns out, I can get about 1.5 seconds of off time on the FET on full power if I add back a 500ohm bleeder, but I can barely get any off-time at all from the all 7135 channel. For the single 7135, again on low, it gets very long times. On full throttle at 3.0V it can squeeze out over 0.75 s, getting close to 2s by 3.5V, all with the bleeder, so bit worse than the FET. This seems to indicate it's not about total LED current. But I'm at a bit of a loss what it is about.
It's very possible that I just missed this in the first build. I was mostly testing on low or turbo, and didn't even have the backside 7135s installed on that build.
The extra 0.8 or so mA of the all 7135s does not seem to add up to anywhere near enough too explain this, from the math or experience (I did some work to get it down from 4mA in the first place, and yes it helped, but no where near this drastic). The math from all the measurements actually adds up pretty well in line with the 3s+ I'm getting on the low mode.
hmm...
