I received full refund but I didn’t order from gearbest.
Has anyone found a good solution to the switch problem? Replacement switch? I have no experience in light modding. Any help would be greatly appreciated.
After what seemed like an eternity, the UT01 arrived today. Perfect swittch and perfect UI functioning. Nice light for sure. NW tint is nice white color…not yellowish like some of the other Manker NW’s. :+1:
Got my second UT01 today to replace the one my wife claimed to replace a Convoy S2 1.4A light that she was using (and I feel much better her having a AA NiMh light in her purse). Everything works fine and hopefully the 3rd I have coming in will also work as it should.
You can always return the defective light back to the seller for replacement. Its really worth the effort to get a working UT01. I dont use any of my Mi7 anymore since I got this light. Go figure
Ah, by the way I measured the total length of the lamp everything tightly screwd down and its
84mm long weras the specs say 82mm.
So maybe they use now a longer tube?
Yeah you got a bad one, that driver board needs to be in there solid I think to make electrical contact. I just tried “picking” at mine with a fingernail on the +B input button and it doesn’t budge.
I opened my DOA flashlight and test driver. Driver works Ok, button is dead. I need to replace button.
I find type of button: TL3340. And all shops with this button not ships to Russia
Sanctons?
Sorry, I tried it with my magnets scotch taped on the outside. One is not enough, two stacked could work. My 10x2 were rated as N52, but I am not shure about it.
I read a Skilhunt H03 a 18650 light uses a
16 x 2 mm magnet on 0,5mm wall thickness, you should use this.
