I think that’s a great attitude. :+1:
And it’s why China is probably going to ‘win the race’ of technical and industrial development very soon!
(Maybe they have already…)
It happened to Jaxman and by manufacturers and vendors that you’d never had suspected would do such a thing.
Yeah… As yishenger said: “although personal feeling is unwilling”, and in our culture it’s even illegal.
Somewhere in the middle would be best i.m.o.
In our culture developments are often slow because of patents…
Another fan of you!, from Spain very good flash lights, I have a spy and a v4 18650, I using every day!! thanks to go to the forum even with you english!! mine is very bad too
I haven’t had time to read all the posts here but took a few pictures this morning to better help you understand what I see as an issue with the driver retainer mostly, By T18
Yet, you find the time to author a post poorly disquised as helpful but negative.
You clearly expect George and others to read your post yet you do not extend the same courtesy to the other members. Why the double standard?
I encourage other members to look at T 18’s past posts and you will find that they are inherently negative and complaint filled. Feel free to review my history of posting as a comparison. No double standard here.
Why don’t you start your own company, since you clearly believe you have the expertise and from your posting- you have the time necessary .
You are constantly picking on people from other cultures, you have a habit of deleted many of your posts which were rude and crude. You are just a bully.
Hello George. love my DQG… is there any plan on putting different LED? maybe XHP 70? of course it will get hot very fast, but it sure is will be a good conversation piece;)
Maybe XHP35 HI on slightly longer head?
Hey, hold on a second. I see no problem with the post from T18. It is critisism with positive reinforcement. This is a good way to offer the information in his post. And I think his observations are helpfull. There has been some questionable quality issues with this light, though they are minor, and I think I it is information that will be helpful to George.
Anyway, what was said is usefull information and it was offered as such. In my opinion anyhow…
Edit: ok, I see the post may have been edited by the time I read it. I did not read the origional post. So my comment is only in regard to the edited post and I may be too hard on boro.
Easy guys. I believe the post your talking about had been edited before you read it as T18 mentioned. Lets keep it nice and show yishenger what a terrific honest place we have here.
Hi, T18, thank you very much for you post. here I can see my mistake of assembling now. before the glue is solid, I will check the light is work fine or not. if not work fine, I dispart it, slove the problem then assemble again, Obviously I make wrong side of the battery tube, becuase it is mirror design, so, the tailcap glued with the tube when glue is solid.
about the diameter of the cover ring, it does smaller than the host in design, to different size, its mechinical result, every size have its tolerance, such as +–0.1mm, the biggest can large smallest 0.2mm is accepted as common rule. but why tiny 18650’s ring not come out? because I use a little thermal glue on electric component will hot, but in these days, I find the thermal glue cannot do help: because before the glue solid, the ring cover is displaced already by tighten tube action; and wost, the thermal glue always will lead bad electric contact due to its leakage, so, at current 18650’s, the ring cover will drop out when dispart the battery tube.
and good find about the switch nob relationship to the rubber button, it will lead bad press action if they not contact each other. due to soldering shift of switch, PCB and host etc tolerance, there does will have this problem, it also why I try to dispart it and assemble it again, then displaced the battery tube.
very careful observation, thank you very much. and also should apologize to you about this mistake.
nice to meet you. I have an english dictionary!
Hi, Boro, don’t complain T18, I think he is a serious man, I like his detail post. maybe something he is not famillar.
about standards: in mechical field, there have many differant requirements, the tolerance are difference. highly Accuracy size should use very special designed device to manufacture in order to maintain same demmession. for light or other like products, usually don’t need so accuracy tolerance, otherwise nobody will Machining for me for so little quantity. but, I think accuracy is our goal in every field for every product if can and economic.
Hi, at current, I think only 7*XPG2 can make as small as could and power nearly reach XHP 70 (with refelctor or optics), XHP 35 HI suit for thrower, so, I now have no plan. maybe future designning tiny thrower will consider them.
Any chance of a 21700? I’d buy tomorrow. Literally.
Hi Boro, good to hear from again,
I sure wish I could explain to you what goes on in the background but I really don’t think you’d get it and beside I really don’t care what you think or what you say about me so please if you do anything today, just go rest your neck please…!
Thank you MRsDNF and LightRider, there is more here than meets the eye.
Funny thing and Boro mentioned how I delete posts, sure I do and I had come to delete the text in my post because it serves no purpose any longer because the pictures did speak a thousand words, and they have been seen and my post didn’t really need a thousand words on top of it all as Robert pointed out to me, George is aware of the issues and now just how to figure out what’s happening I guess.
I was the one who suggested to Banggood that maybe George would like to come meet us at BLF, then Banggood messaged back and said he was here, wow, sure didn’t really expect that or this from Boro, but what’s new.
Now off to start a new business writing negative posts, boy if I ever post a review here it better be completely positive or who do you think would be the first to comment?
Ha Ha
Hello George thank you for coming to BLF,
I was trying to explain driver retainer to Banggood and finally suggested maybe you could come meet us here at BLF and you came I am very happy to meet you and I do love all your products,
I am the guy who dedome all six outer LEDs when I removed the bezel… ha ha, sent picture to Banggood now tint is very yellow 3000K, maybe they send picture to you?
I got light to hot and forgot to press down on the optic when I turned the bezel and I removed all domes from outer LEDs, I can’t do that good a job removing LED dome when I try to deliberate.
Banggood try to tell you that I needed a new driver and then they told me that you said I needed a new driver and the reason driver and retainer feel out was because I admit to Banggood that I removed the bezel… ha ha ha
I had to tell Banggood what it says on your product box, about NO disassemble or no warranty…
They didn’t know and I told them I disassembled your light so I know I have to warranty and was only trying to explain the problem with retainer and driver falling out but words in English to Chinese get confused. ha
No apologies needed for me, I am very happy with product George and it is easy to fix but thought you would want to know and told that to Banggood.
I have many of your lights and as you see in pictures 2 of the 26650,
I think I have all your lights, and I do mostly understand the complications for you in manufacturing and machinist tolerances etc…
I understand how the glue got on the end cap, easy to make that mistake when you have so many tubes and end caps and glue ha ha ha,
I thought it was funny or strange at least strange thing to see, but no problem I just fix it and used silicone around the retainer lightly after perfect alignment with switch.
So now I understand difference in tolerance from 18650 and 26650 I did not understand difference, smart, that’s why you are able to stay in business, good business from smart man…!!
Yes a longer nub on switch towards rubber boot or a little stiffer longer nub in rubber boot… Don’t know which is easier for you or cost but it would be a big help when you alignment of the switch, very difficult to get perfect alignment of the switch when assembling lights, and when doing alignment of so many at one time like you do at manufacturing.
Thank you for coming George and I look forward already to your next light.
You are the best George… and thank you again.
Hello George,
thanks for your post, it´s always nice to be able to speak to the real creators of flashlights. I was just about to pull the trigger on a DQG Tiny 26650 V3.0 but the only thing that keeps me from getting one is the LED and tint selection… It seems from all the reports that the two xp-g2 tints you offer in your light are either very cold or very warm… right now there is no real neutral neither a hi cri version vailable. I´m a huge fan of the 4500-5000 K nichia 219b/c LED tints and so are many users in this forum I learned… any chance to have a new revision with Hi CRI neutral white LEDs inside? I´d be willing to sacrifice a few lumens for a nice tint and hi cri…
Thanks and best of luck for your business!
K.
Sorry, did I hear him right ? Don’t disassemble ?
Yeah right……
crz, you have to keep in mind that only a small percentage of those that purchase a flashlight have the ability to successfully mod it. Many that have tried on this light have damaged emitters, switches, driver… this is a complex and tight build, it’s not for the beginner class for sure.
Shining the lights on a white wall inside your house is one thing, but taking them outdoors is another. The differences become less. IMO, both are excellent very usable lights
DQG 26650 Tiny 3 Cool White
DQG 26650 Tiny 3 Neutral White
Exactly! In real use those tints are very much acceptable! White wall hunting is not a very good indicator of a flashlight’s potential, not sure where it got it’s popularity.
