You can always return the defective light back to the seller for replacement. Its really worth the effort to get a working UT01. I dont use any of my Mi7 anymore since I got this light. Go figure
Ah, by the way I measured the total length of the lamp everything tightly screwd down and its
84mm long weras the specs say 82mm.
So maybe they use now a longer tube?
Yeah you got a bad one, that driver board needs to be in there solid I think to make electrical contact. I just tried “picking” at mine with a fingernail on the +B input button and it doesn’t budge.
I opened my DOA flashlight and test driver. Driver works Ok, button is dead. I need to replace button.
I find type of button: TL3340. And all shops with this button not ships to Russia
Sanctons?
Sorry, I tried it with my magnets scotch taped on the outside. One is not enough, two stacked could work. My 10x2 were rated as N52, but I am not shure about it.
I read a Skilhunt H03 a 18650 light uses a
16 x 2 mm magnet on 0,5mm wall thickness, you should use this.
I just received my utorch ut01 today
and my first word:WTF
the switch is broken completely(very hard to turn on, switch mode, press 10-20 times, only 1 times work)
the positive contact on driver board is DIRTY, the most dirty one i have ever seen
AND THE WORST IS
Gearbest Sent me wrong color temp( i ordered 5000K, and they sent me something much Warmer than 5000k)
i dont know what should i do now, I WAITED 20 DAYS just to recieve this light
As you mentioned this on your above post, “the positive contact on driver board is DIRTY, the most dirty one i have ever seen”, I’m thinking why not clean and check the contacts are good before blaming the switch?
