Received after 9 days , that was quick .
Thanks Boaz
Thanks Boaz
That was fast … 9 days to Greece is crazy
Thanks again Giorgoskok
Wow, i received mine too. Fast shipping! Thanks, works great. Noticing a slight tint change but very subtle.
just noticed this as i was about to send you a paypal payment. maybe folks can give me some advice…. im actually putting this on a led “cube” offroad light that i use for a reverse light on my atv. i currently have a homemade diffuser on there… basically a cover that i cut a bunch of lines in with a grinder to give it a wider pattern.
all i need is 2” x 2”… so size isnt an issue… but what would make the beam as floody as possible? and maybe be durable to boot? although ill probably put a clear cover over top of it for protection.
I’ve had some of this stuff for ages, but it’s still in the envelope Boaz sent it in. I’ll be building another BMF SRK with 3 x MT-G2s from a cheapo SRK host and will try it out then. A few questions though…
Does this stuff come off easy? Does it leave any traces that have to be cleaned?
Does this stuff change the tint? I’ll be sticking it on another MT-G2 SRK as I use them for photography, and want one that is more of a fill light so I need it’s tint to be the same.
Mike C: it’s easy to remove and wow the glass does NOT need cleaning! No tint changes. Wonderful.
One does need a noticeable increase in output, at least for my taste, but this is very subjective.
PM sent. Awaiting payment details
I’ll say it again because it bears worth repeating …
A normal Convoy S2+ at waist height throws a beam where the outer edge hits the floor at 4 1/2 feet in front of you ,
When you add DC-FIX the edge of beam hits the floor 6 inches in front of you instead of 4 1/2 ft.
If it doesn’t take every issue out of your beam …it certainly will take 95% of them .the harder part will be looking for more lights to add it to.
Go buy more lights
I paid it on February 22nd and received it on February 28th. This has been very fast!
Right now I don’t have the flashlight in which I want to use it (Convoy M2) and I don’t have the time either. But this DC-FIX looks great. I really want to try it and I’m sure it will work very well.
Thank you very much Boaz for your product, your help and the advice.
Thanks for the info. Got parts on the way so I’ll be trying it out… eventually…
When does one not need increased output? :smiling_imp:
Just sent PM for 2 sheets of DC Fix, I have 1 light in particular I wanted to use it on, I think I messed up the emitter (5700k nichia 219c) while reflowing and there’s a ton of rings and a tiny dark area in the middle of the hot spot. Normally I wouldn’t get too worked up over some artifacts but this one makes the light look cheap. Hopefully this fixes it
much better, thanks boaz
Thanks for sharing the photos k-wong. Care to share some of the specs on that light? What distance was the wall from the light?
Recieved the dc-fix today...will wait until dark to apply and test. Thanks for the quick mail-out!
It was about 3 feet for a Lumintop ED25 (2xAA) with 219c 5700k. I’d probably do a 4k or 5k next time as it was too close to the original stock xpl emitter and less output. The DC Fix definitely helped with the multiple rings and tint shift but it was also a bit floodier.
Here are a couple before and after shots. Stock Convoy S2+ 3B tint, 16-18" from white wall. Sorry if my photog prowess is not too good but it shows the difference. Much improved beam for my use.
Before DC-Fix
After DC-Fix
The photos don't really do justice to the expanded spill area the film gives the light. Great stuff!
I bought 3 sheets of this from Boaz. He must have raced to the post office because I Paypaled him on Saturday and received it on Monday. It looks to be the real deal too. Thanks for providing this service Boaz.
@ Boaz, are you still offering this for sale?
This last comment was answered via PM ….
Yes I have sheets of the DC-FIX
As well as a thicker / harder diffuser material (about the thickness of a playing card ).
I also have a film that spreads the beam horizontally that would make for an interesting bike light beam
Lets see if we can get a few members who have integrating spheres or light boxes to do some real world testing on 3 or 4 different materials.
It might be interesting to see how close different peoples measurements with various spheres will be … When we get some real numbers I’ll post some beamshots and start putting up some of the other diffusion materials for sale …
Anyone interested in doing some testing …send me a P.M.
Boaz, still using the stuff I bought off you late last year, thanks for still offering it here!
