mrheosuper, have you tried cleaning the contacts?
No, but the problem is the switch, become sometimes it works for seconds
As you mentioned this on your above post, “the positive contact on driver board is DIRTY, the most dirty one i have ever seen”, I’m thinking why not clean and check the contacts are good before blaming the switch?
Just a thought…
i will give it a try
but very likely it’s because of the switch, many people have reported same problem like
i lost the lotery
btw, i dont know why my light has a very warm tint, warmer than astrolux s2 3d 5000k, i guess it’s about 3500-4000k
but utorch ut01 doesnt have “warm white” option, strange
my Manker E11 is very warm too, much warmer than neutral. Like a yellow-ish beige. I use it late at night for its warm-candle glow. Although with a low CRI, its really nothing to get excited over, IMHO.
[EDIT] But I still think its in the “neutral” 5000K-ish range. Its still considerably more pale than my Surefire incans. I really don’t notice it until I directly compare the two on a white wall.
Yeah, i think it’s not 5000k
at first i think they sent me wrong one, then i checked again
One thing for me personally in regards to LED tints, the temperature I see heavily depends on what color my brain happens to be pre-calibrated to. Staring at the pale-blue colors of the BLF forum for example shifts my perception to a colder nominal, so then when I look away everything looks slightly warmer. Try this… white wall hunt with your warm tint light and note its color temp. Get a yellow-orange construction paper sheet and hold it right up to your face. Shine the light at the paper with it up to your face and stare into the bright orange color for 10-15 seconds, blink a few times. Now go back and white wall hunt… what tint is the light now?
Will try it, when i have time and orange paper(:P)
I know our brain is not perfect, today i use ut01 all time, and now all my flashlight’s tint are silghtly cooler
I had the same issue with Manker U-11. I won this light and requested NW tint but tint is yellow. Closer to 5A than any other tint. Nowhere near 5000K. Shit Tint Happens…
jesus what happen with switch in that flashlight :person_facepalming:
I didn’t receive my UT01, after something like 8-10 weeks, so I submitted a ticket, and paid a little extra for GearBest to send me a 2nd one. I asked if they could test the light before sending it, given all the switch problems reported, and the person told me that all units are thoroughly tested. We’ll see…
I recently got mine and I’m lucky that I haven’t had the switch issue, but I’m having a different issue. I can’t get Eneloops to work consistently. Sometimes it turns on, sometimes it doesn’t. Sometimes you put an Eneloop in and it turns on, then you set it aside for an hour and try again and it won’t power on. I have no problem using alkaleaks. Works flawlessly every time and just by eyeballing it, both cells appear to be the same length or very nearly so. I just don’t get it and it seems like some of you are using NiMH cells. Any ideas?
Also, I’m disappointed that my Orbtronic protected cell doesn’t fit (should have read this thread first). There are some good suggestions in this thread, should we compile a list of IMR cells known to fit/work?
Also, looks like I’m not the only one to get the “surprise” warm tint model. I actually prefer this tint so I have no problem with it. :+1:
I have a complete dead light and wait for respond from Gearbest, but I have already collected a list of short protected LiIons :
My meassured Tube UT01: 51,9mm x 14,75mm
No guarantee for the list, these are only mentions from other people
- Marsfire
- Trustfire
- AW (short maybe to long) https://www.akkuteile.de/lithium-ionen-akkus/14500/aw/aw-14500-lithium-ionen-akku-3-7v-750mah-protected/a-17006/
- Xstar 800mAh
http://www.xtar.cc/products_detail/productId%3D43.html
- Soshine 14500
- Nitecore 750mAh
Nitecore nl147 battery (one UT01 User said it worked other it doesn’t)
There are different infos how long LiIon can be, maybe tolerance from tube or battery
50,8mm won’t work
50,3mm yes
Q: Manker E11 - Review / Vorstellung / Test | Taschenlampen Forum
The lamp is 84mm long, not 82mm as in the description.
If everything is to long I would go with two 0,5mm thick rings in the head and the tail. Lose in the tail, in the head I would use two solder points as fixation to prevent shorts.
Joechina
Thanks for that list Joe. Interesting that the Nitecore NL147 works. I wondering if others have had success with the NI14500A cell? I believe Giorgios mentioned using it as well. I think I’m more interested in using an IMR cell in this.
Hope Gearbest can straighten out your issue!
I have two of these lights now. The first one had a faulty switch which made it nearly unusable, so I contacted GB and they sent me a replacement. The replacement is now the wrong tint at cool white, but it works perfectly. Very frustrating. Also, they asked me to respond to the following :-
“Please follow these steps and kindly answer the following questions, in order to help us review your case:
-Does the package show any signs that it has been tampered with?
-Please send us clear pictures of the box at all angles, including the shipping labels.
-Please tell us the outer weight indicated on the box.”
:S
Hey no guarantee for the list, it’s just what i’ve read.
Interestingly some batteries are shorter on the manufactor website than on sellers websites.
So GB have refunded to me, at least their supports work well
17$, what should i grab now
I’m still waiting for mine to see how I made out n the switch lottery.
It is taking an unusually long time to get here. Ordered on Feb 12th but according to the tracking it arrived in New York on the 23rd and has been there ever since.
Bob
You can grab another if you still want one working UT01.
I’m still enjoying using 3 UT01 and no sign of switch malfunctioning so far under my normal use.
Hope the switch will last a good time
