The only Mrlite light I own (KC-05) is of very good quality.
OMG! hope it will be released soon
PLEASE PLEASE!!!!!
A teaser!!!! I want a teaser of that monster!!! As MrLite did with the J4!!!!
Anyperson has contact with mrlite to ask for photos?¿¿?¿¿??¿
agreed with fran82!! hehehe. very eager to see :D
Can he get XM-L's? Should be a much more cost efficient way of getting same results. Smaller circuit, lower cost, same brightness.
If they were actually available. It might be possible to get them in a month, it might not. Till then.....
Maybe, but kind of worthless since there's no way you can hold it if driven at anywhere near full power.
In any case, even if you get it for the emitter, I have no idea why anyone'd spend money on a sst-90 with no clue about its bin/tint, etc. It's not like wasting $10 on a crap xp-g. It's also likely not a SSR, so the soldering job is suspect.
If you want an sst90 emitter without the flashlight ... there are cheaper ways with binning ... I wondered more because of the size of the light, battery configuration and inferior heatsinking...
Yes, except you don't want the SST's unless you're sure you can mount them properly. You'd want these:
But now people know where to buy the right one. :)
Those sevens ones are lower bin poor tint. WL is 30% less WN, or about 4 cree bins apart. DE/DF is also the worse possible cold tint
Too big for an sst50. Is almost the same size as the intimidator, I beleive
Will need 2x18650 and this thick head if really is driven at 4.6A
That's true. A small size body couldn't handle the heat if it's truly driven by 4.6A.
Also it would need a IMR cell if the configuration was 1x18650...
Nice! Thank you for those pictures, juhi81. This is obviously going to be a pretty top-heavy light but considering that this isn't a weapon light, I think I can live with that. ;) As long as it's reasonably priced and doesn't cook itself, put me down for a couple.
I very much look forward to finding out a release date and a price :) it looks great! really hope it works the sst-50 to its potential!
wish it was geared towards 34570. while not as common, they would last a respectable amount of time at 5 amps
Still a nice light indeed.......wonder if there will be an available op reflector as well.
