STAR Firmware by JonnyC - Source Code and Explanation
1335 posts / 0 new
garrybunk
garrybunk's picture
Last seen: 1 day 14 hours ago
What would happen if I flash STAR off-time but didn’t have a capacitor in place? I’m looking for “off-time” memory during mode selection, but “no memory” once the light is powered off. Wondering if I can accomplish this without the cap.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
RMM
RMM's picture
Last seen: 1 year 6 months ago
garrybunk wrote:
What would happen if I flash STAR off-time but didn't have a capacitor in place? I'm looking for "off-time" memory during mode selection, but "no memory" once the light is powered off. Wondering if I can accomplish this without the cap. -Garry
Usually, the result ends up being that every click is registered basically as a "short click", where the driver would advance to the next mode (not what you want).
Doesn't selecting "no memory" accomplish what you want, anyways?  The off-time STAR with capacitor in place functions like you are describing.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
garrybunk
garrybunk's picture
But that IS what I want. When the light is on I always want a short click to advance modes. When the light is off & turned on I want it to always turn on in the first mode.
I found that regular “STAR” (on-time) even when set to “no memory” would require two clicks to advance modes because “memory” had set it. That was annoying.
Anyway, I just tried flashing STAR off-time to a 105D without capacitor and it IS working just as I wanted! Single-click always advances mode & always starts in first mode! (EDIT-see next post.)
My problem now is that I need reverse mode order which I originally planned to get by soldering star #3 on a 105C. Can I change mode order in the code simply by reversing the line entries to put high first? (I’m referring to the lines where I enter my desired PWM values – the only lines I ever edit.) Or are there other lines in the code to edit also?
Thanks,
-Garry
garrybunk
garrybunk's picture
WAIT! My bad! You’re right RMM! Upon closer inspection it’s acting like a driver with “next mode memory” which is not what I want! Doh! So I guess I’m back to switching the 105D out for a 105C.
I would still like to hear an answer to switching mode order in the code though.
-Garry
RMM
RMM's picture
garrybunk wrote:
WAIT! My bad! You're right RMM! Upon closer inspection it's acting like a driver with "next mode memory" which is not what I want! Doh! So I guess I'm back to switching the 105D out for a 105C. I would still like to hear an answer to switching mode order in the code though. -Garry
You can use ToyKeeper's "NOINIT" modification to the code that will give you off-time without the capacitor, so you can use it on the 105D without adding any extra parts (for best timing, also change the fuses to those listed in the initial code description). (it's in ToyKeeper's repository).
To switch the default mode order in the code, find this:
if ((PINB & (1 << STAR3_PIN)) == 0) {
		// High to Low
		mode_dir = -1;
	} else {
		mode_dir = 1;
Then change to this (or just solder Pin 3 to ground with the default code...):
		// High to Low
		mode_dir = 1;
	} else {
		mode_dir = -1;
garrybunk
garrybunk's picture
RMM wrote:
garrybunk wrote:
WAIT! My bad! You’re right RMM! Upon closer inspection it’s acting like a driver with “next mode memory” which is not what I want! Doh! So I guess I’m back to switching the 105D out for a 105C. I would still like to hear an answer to switching mode order in the code though. -Garry
You can use ToyKeeper’s “NOINIT” modification to the code that will give you off-time without the capacitor, so you can use it on the 105D without adding any extra parts (for best timing, also change the fuses to those listed in the initial code description). (it’s in ToyKeeper’s repository).
<span class="pyg-k">if</span> <span class="pyg-p">((</span><span class="pyg-n">PINB</span> <span class="pyg-o">&amp;</span> <span class="pyg-p">(</span><span class="pyg-mi">1</span> <span class="pyg-o">&lt;&lt;</span> <span class="pyg-n">STAR3_PIN</span><span class="pyg-p">))</span> <span class="pyg-o"> 0) {
		// High to Low
		mode_dir = -1;
	} else {
		mode_dir = 1;
if ((PINB & (1 << STAR3_PIN)) </span> <span class="pyg-mi">0</span><span class="pyg-p">)</span> <span class="pyg-p">{</span>
		<span class="pyg-c1">// High to Low</span>
		<span class="pyg-n">mode_dir</span> <span class="pyg-o">=</span> <span class="pyg-mi">1</span><span class="pyg-p">;</span>
	<span class="pyg-p">}</span> <span class="pyg-k">else</span> <span class="pyg-p">{</span>
		<span class="pyg-n">mode_dir</span> <span class="pyg-o">=</span> -<span class="pyg-mi">1</span><span class="pyg-p">;</span>
Thanks RMM! Perfect solution for me! Others previously pointed me toward “Bistro” with brown out detection and I didn’t realize ToyKeeper had a version of STAR modified with brown out detection as well.
Thanks,
-Garry
Lexel
Lexel's picture
Last seen: 10 months 1 week ago
this one is for the 13A Attiny?
does 25 44 ones work too?
HighEfficiency
HighEfficiency's picture
Last seen: 4 years 2 months ago
Lexel – Yes this works for ATTiny 13A.
On another note:
Would there be a way to configure the LVT in STAR so that it would require a duration of low voltage before going into ADC_Low or ADC_Crit?
I’ve made a couple of lights that are temperamental with the LVT. A casual knock, or bump will trigger the LVT.
Any help here?
ToyKeeper
ToyKeeper's picture
Last seen: 57 min 11 sec ago
Any help here?
Doesn’t it already do that? In STAR it has a “lowbatt_cnt” thing so that it won’t step down unless the value is low several times in a row. You could slow it down just by increasing the number of readings required to trigger it.
HighEfficiency
Toy – as always, you’re a big help. Many thanks.
I’m assuming this is the line of code I would change:
“if (++lowbatt_cnt > 8)”
A setting of 8 (default) would be 4 seconds and in this case definitely shouldn’t be tripping it. A brief bump is really only a fraction of a second.
I’ll try increasing the value to 8, 16, etc and see if that has any effect. Is there a max length of time that this program will accept ( say one or two minutes)?
Big thanks.
ToyKeeper
ToyKeeper's picture
I would assume it’s probably fine up to 254.
If a quick bump trips it, maybe it’s not LVP causing the problems. Maybe it’s actually losing power and rebooting? Loose springs barely making contact? Firmware won’t be able to fix that.
HighEfficiency
That was my thought as well but one thing stands out. I have removed ADC_Low and only use ADC_Crit in my program. When it senses LVT it flashes 10 times then turns off.
The 10 flashes then turnoff is exactly what it is doing when bumped.
That wouldn’t be a sign of a reboot would it?
ToyKeeper
ToyKeeper's picture
No, doesn’t sound like a reboot. Could easily be a poor connection though. I’ve had false LVP warnings when something wasn’t connected well, and it was bump-sensitive.
HighEfficiency
Thanks for the help. I’m going to tinker with “if (++lowbatt_cnt > 8)” and just see if that makes for a quick fix.
