I’d be interested for one, possibly more depending on pricing. I’m all for a good (maybe perfect?) lantern… but this IS the budget light forum, so budget is key. That’s not to say I expect this lantern to be sold for 8.78 on GB! lol… no, that’s ridiculous. But I certainly don’t want to pay $60-$80 for it either.
I don’t know at the moment, as The Miller is busy working on the BLF Q8 and BLF Thrower lights at this time, ( he has more resources to reach out to manufacturers than i do.
For those desperate for a lantern, just make a wire cage that supports a soda cup, use the cup as a mold for t-shirt fabric saturated with epoxy resin(use a sleeve), then drop an inverted foil cone in the top.
So, I was wondering if this could be an add-on to the Q8, like a lantern adapter of sorts. It could be something the fits over the light to make it a lantern, sorry if this is not reasonable, I’m new here.
not at the moment, i believe TheMiller is probably a bit busy working on the Q8, BLF Thrower, and other projects to to want to bother him yet on this one. I do hope someday soon we can get this rolling though. I am adding a USB charging function to the prototype (TP4056 based) to add versatility.
I’m in too, especially with an incorporated USB charging function, as IMO recharging on the road without the need to carry an extra charger seems to be key for such a device.
OOPS.this gave me a little “whoops did I miss something?” feeling.
I thought you picked it up with Barry.
The Q8 has 4 “shade points” at 90 degrees from the head (so when shining it and holding it perpendicular to a wall a shaded point is seen, caused by the point in the middle of the quad reflector.
How about a good diffuser?
Good quality,downwards facing reflective dome, with a metal frame (using the shade areas for there is less light there anyways) that has a handle so it can be hung and carried like those old fashioned storm lanterns.
And maybe a piece that screws into the Q8 between the tube and head that has the electronics for the charging (and powerbank) and connectors in it.
diffuser could be made so it clamp in between 2 cooling fins at the switch side and fixed with a nut in the tripod mounting hole.
So a camping addon set. because of powerbank also cool for normal users.
Could be a big demand for it.
