I don’t know at the moment, as The Miller is busy working on the BLF Q8 and BLF Thrower lights at this time, ( he has more resources to reach out to manufacturers than i do.
For those desperate for a lantern, just make a wire cage that supports a soda cup, use the cup as a mold for t-shirt fabric saturated with epoxy resin(use a sleeve), then drop an inverted foil cone in the top.
So, I was wondering if this could be an add-on to the Q8, like a lantern adapter of sorts. It could be something the fits over the light to make it a lantern, sorry if this is not reasonable, I’m new here.
not at the moment, i believe TheMiller is probably a bit busy working on the Q8, BLF Thrower, and other projects to to want to bother him yet on this one. I do hope someday soon we can get this rolling though. I am adding a USB charging function to the prototype (TP4056 based) to add versatility.
I’m in too, especially with an incorporated USB charging function, as IMO recharging on the road without the need to carry an extra charger seems to be key for such a device.
OOPS.this gave me a little “whoops did I miss something?” feeling.
I thought you picked it up with Barry.
The Q8 has 4 “shade points” at 90 degrees from the head (so when shining it and holding it perpendicular to a wall a shaded point is seen, caused by the point in the middle of the quad reflector.
How about a good diffuser?
Good quality,downwards facing reflective dome, with a metal frame (using the shade areas for there is less light there anyways) that has a handle so it can be hung and carried like those old fashioned storm lanterns.
And maybe a piece that screws into the Q8 between the tube and head that has the electronics for the charging (and powerbank) and connectors in it.
diffuser could be made so it clamp in between 2 cooling fins at the switch side and fixed with a nut in the tripod mounting hole.
So a camping addon set. because of powerbank also cool for normal users.
Could be a big demand for it.
As was discussed in the Q8 thread, adding a lantern attachment to the Q8 should be pretty simple, just a matter of getting the reflector angles right.
Adding a charging circuit on the other hand would be a much larger issue, it would require a new driver and most likely a redesign of the body itself, at least to some degree, at the very least for the USB port itself.
Although charging a Q8 should really be done with a USB type C connection to get any kind of worthwhile charge times, this would need the cells to be in 4S to work effectively though but it would allow for 10X faster charge rates.
You could possible add a charging circuit to the tail section of the Q8, with an extended tailcap, although charge times would be VERY long indeed. Talking ~10 hours for a full charge.
What? Put the cells in 4S to charge? That’s the worst possible way to charge Li-Ion cells! Where did you get the idea that the charger circuit “would need the cells to be in 4S to work effectively”?
Im my opinion, despite all discussion, a lantern should have a downward facing light source, like DBSAR’s prototype. You can add a sideways pointing reflector on top of the Q8, but will then still need very heavy diffusing to prevent looking directly into the leds.
Lanterns should project light sideways and downward, and only little light should go upwards.
