Test/review of GTF TR16340 2800mAh (White)
Official specifications:
  • 100% brand new GTL123A 3.7V 2800mAh rechargeable batteries
  • Capacity: 2800mAh
  • Voltage: 3.7V
  • Chemistry: Li-ion
  • Recharge: up to 1000 cycles
The latest scam in high capacity 16340 batteries.
They are a bit below rated capacity, actual capacity is 250mAh to 300mAh at low load. they do not support moderate or higher loads.
They do not contain energy enough to get warm.
Conclusion
These cells may be cheap, but compare to what you get they are way to expensive. Any decent cell will have about double capacity and handle higher load much better.
I will rate them as bad
Notes and links
Comparison to other LiIon batteries
Lol, they accidentally added one too many zero's to stated capacity; if intentional then they forgot the letters OH (Outta Here) after GTF.
Thx for the review!
:slight_smile:
Thanks HKJ.
Overpriced slingshot ammo.
Thanks for taking the time to test these cells.
That[280mAh!] sounds about right! Maybe the cycles should also have a Zero removed! 100 instead of 1000!! lol!
,Thanks,HKJ. :sunglasses:
