I got a dozen each of the Lowes LED bulbs in 40 and 60 watts for a buck each last December 2015. They are now in their 14th month of service on my front porch light and lamp post light. They burn @ 15 hours a day. That’s pretty good service so far. Regular incans lasted only 4-5 and sometimes 6 months.
Glad I was able to get in on the BlackFriday from Lowes . Good buys.
FYI, one out of 3 of my local dollar stores had the globe LED for life BR30 bulbs for $1 each. None of the stores had the regular A19 bulbs there are mentioned in this thread.
Well, if they ever come back here, I’ll by FIVE PACKS! (er, last time I counted, I figured I could spend $20 on the single bulb packs… how am I going to explain coming home with 60 LED bulbs? Oh well, I’ll worry about that when it happens…)
That 2 pack I found yesterday was up by the register. Someone at the last minute decided against it and dumped it there.
Today I went back to see what the display looked like. This is what I saw.
But wait…….
On the top shelf there is the 3 pack of the FEIT’s!!!
I grabbed it and looked around for more. I found them on an endcap
Later in the day I was in Massachsetts and stopped by a DT there.
If you look carefully, you can see single packs of GreenLite 60W equiv LED’s in the isle.
The endcap in the foreground has 3 kinds of Floodlights. 65W, 75W and 90W.
I had been in Ohio for the past 2 weeks and I had reason to stop in DT for some hand cream.
Of course while in there I checked to see if they had LED light bulbs. And they DID!
They even had the 2 packs!
I didn’t actually need any more, but I bought 1 pack as a souvenir from Ohio.
Today I needed a multi tap, non grounded AC adapter. And I knew right where to go to find one, Dollar Tree.
Non grounded wiring is obsolete here in the U.S. I never thought I would need something as rare as that, but I wanted to fork a couple of LED shop lights of the built socket. The light fixture is double insulated
I also knew where in the store to find them, in housewares. My local store is a very high volume store and my biggest gripe about it is that they don’t hire enough cashiers and personnel. When I got to the housewares section, this is what I saw :person_facepalming:
The pegboards are almost bare but there are cases of replacement goods to be hung. Looks like a buying frenzy occurred for whatever reason and I missed it.
Luckily I found my adapter at the far end of this isle and snapped another picture of this isle in the opposite direction.
To the left in the foreground is the shelf with the LED bulbs. If you look carefully you can see that there are still 2 and 3 packs of 60W LED bulbs.
BTW, I hardly ever shop online. Almost always, if something I need can be found in retail, I can get it for less there. Sometimes for a lot less.
Compare that duplex adapter at DT for a $1 vs Ebay for $3.75
Keep an eye on Walmart, they have like a power savings month or something like that once a year, LED bulbs for 88c two years ago. I ended up buying about 40 or so. Replaced all the old LED bulbs and CFLs that I hated. Can only imagine they will be cheaper, or of better quality this year
Granted, the old LED bulbs that cost from $10-20 never died in 5 years or so. I been through about 10 so far of the walmart ones. But my old LEDs were different color temps, and I only had three of them, and I HATE CFL.
Now every single light in my house is one color temp, and I still have 11 for back ups.
There is a difference between the cheap LED bulbs and the premium ones, but not sure if 10x or more the cost is worth it.
