Finally the XHP70.2 emerges!
347 posts / 0 new
grayski74
grayski74's picture
Last seen: 1 year 9 months ago
http://www.cree.com/News-and-Events/Cree-News/Press-Releases/2017/March/...LED-Delivers-Unmatched-Efficacy-Lumen-Density
“ In addition to light output and efficacy enhancements, the XHP70.2 LED improves optical uniformity through secondary optics, enabling lighting manufacturers to deliver better lighting performance. “
Hopefully sans-hole like the XHP50.2!
djozz
djozz's picture
Last seen: 23 hours 51 min ago
It already shows in the tiny picture of the led led that the build is the same as the XHP50.2
Great news!!
Jerommel
Jerommel's picture
Last seen: 3 hours 9 min ago
Thumbs Up Thumbs Up
hIKARInoob
hIKARInoob's picture
Last seen: 4 hours 28 min ago
Nice and interesting. XHP70 is a lot more popular than XHP50 in the flashlight world, so I do wonder how many existing lights will be updated with XHP70.2. First light that comes to mind that I’m interested in is the Thrunite TN36-UT…
MILSPEC
Can’t wait for the next generation of ThorFire lights with this beast.
finges
Last seen: 12 hours 2 min ago
Good news!
djozz
djozz's picture
Thing is with existing XHP70 lights that they have heavy OP reflectors, which you may not want when using the XHP70.2. The only light that comes to mind that is instantly ready for the upgrade is the Convoy L6 that has a smooth reflector available.
zeremefico
zeremefico's picture
Last seen: 2 days 1 hour ago
I don’t think xhp70.2 will have any problem with smo or op reflectors, first gen had issues with smo reflectors.
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
thijsco19
On the picture you can see it still has room between the dies so there might still be a donut hole..
Hope not..
Enderman
Enderman's picture
Last seen: 4 days 17 hours ago
WOOO
djozz, you better get one and do your tests asap Big Smile
Enderman
Enderman's picture
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 58 min 26 sec ago
Yep some one get one to djozz stat!
Now for the fun part lets all guess max output?
9000 lumens? Big Smile
hIKARInoob
Ah, that’s interesting. So XHP70.2 with smooth reflector is feasible then… nice… TN36-UT with smooth reflector then! Especially because it’s a triple, so more artifacts are smoothed out compared to single emitter… So it’s interesting to see what manufacturers are going to offer…
zeremefico
XM-L2 is next big thing after that.
Edit. XM-L3 Big Smile
My YouTube channel
K40M F16
BrianTheJay
BrianTheJay's picture
Last seen: 3 weeks 5 days ago
Thanks for the great news!
I wonder what numbers people will be getting for these when FET driven.
I’m excited to see how this does in an L6 with SMO reflector and a FET driver.
Also does anyone think that the OLight x9 will switch to using these before release?
EDIT: Here are the specs from Cree (Sorry for the poor formating)
Size 7×7 mm
Product Options 6 V
12 V
High-CRI
Maximum Drive Current 4.8 A (6 V)
2.4 A (12 V)
Maximum Power 29 W
Maximum Light Output 4292 lm
Typical Forward Voltage 5.6 V White 2100 mA (6 V) 11.2 V White 1050 mA (12 V)
Viewing Angle 125 °
Binning 85°C
ANSI (White)
2- 3- and 5-Step EasyWhite®
Thermal Resistance 0.9 °C/W
Reflow Solderable Yes – JEDEC J-STD-020C-compatible
REACH-Compliant Yes
RoHS-Compliant Yes
I have too many hobbies.
alpg88
Last seen: 1 hour 15 min ago
thijsco19 wrote:
On the picture you can see it still has room between the dies so there might still be a donut hole.. Hope not..
not really the reason, donuts are due to improper focus, i had donuts with xml, and other single die leds. i also have few multi die led lights that have smooth, even beam with no holes or crosses. it is all about the optic,
some optic covers it pretty good, i tried led engin TIR lens, iirc 83mm diameter, i use it with xhp 50, smooth tight beam. splattered maglite reflector removes any imperfections from the beam of P7 led, thou P7’s had different material used for primary optic, some domes are clear, some a bit foggy. iirc xhp xx domes are not crystal clear, that should help a bit with beam profile,
Jerommel
Jerommel's picture
They ARE crystal clear of course, but they have a somewhat pebbled surface.
tuelleric
Really good news! The only downside is that I already purchased a 86 mm OP reflector for a planned XHP70 mod. Now I better should have gone SMO, I think…
alpg88
yes that is what i mean, silicone of course is optically clear, but the surface of the dome is not smooth like xml for example,
Speed4goal
Last seen: 2 years 3 weeks ago
I don’t think a op will do bad with this new emitter. I guess I don’t understand why it would. It doesn’t now. I guess I don’t understand how it would act any different then a xml2, or xpl in a op because the dies are a little closer together. I would think it would give the beam pattern people seek from op and give the distance people want in a smooth. Am I missing something?
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
tuelleric
Speed4goal, you are absolutely right, OP is not bad at all. But for further reach I should have bought a SMO reflector. Should have made that point clearer, sorry.
Nah no one is wrong but basically with this new style XHP it will be more suited to using in an smo reflector then the standard XHP. There should be no donut hole with the updated version. The die should be more uniform Maybe making l throw better who knows.
KawiBoy1428
KawiBoy1428's picture
Last seen: 12 hours 54 min ago
70.2? It will be just like the XP-G3, L.2 and 50.2 High Output High Heat No throw! These emitters from my experience are not that great in flashlights, well not for my purposes any way, I like a big beam, with down range grunt, not really a fan of just out put, flood with out throw. Did not like the 50.2 J4-1A in my L2 at all, crummy hot spot yellowish gold corona, and it got worse when I shaved it, now this is comparing it to my other L2 similar build and tightly shaved “old” J4-1A emitter. So I’m not bothering with the new 70.2, I’ll keep my stash of (10) or (8) now XHP70 P2-1C emitters guarded carefully!! Big Smile Thumbs Up
Want more throw de-dome the old XP-G2, XP-L, or even the XHP35/50/70, (not just shaved) you can’t do that with the new emitter’s! I have tried!
I’ll live with the minor artifacts of the “old quad die” emitters and the ability to de-dome them for more “throw’ any day!! Wink
Just my .002 Cent! LOL
KB1428 “Live Life WOT
stephenk
stephenk's picture
Last seen: 1 hour 22 min ago
Looking forward to the Convoy L6 Mk2 then Wink
With all this extra output, manufacturers need to concentrate on better heat sinking. I find high output lights rather pointless if they have to stepped down quickly to avoid over heating.
tuelleric
+1
Jerommel
Jerommel's picture
Hmmm…
At some point some professional markets will want to have modern LEDs that can be used in pure throwers, like search lights, don’t you think so?
I find it quite strange actually, that the developments in LEDs are apparently going in a different direction.
Matter of time maybe.
Jerommel
Jerommel's picture
Momentary turbo button.
You’ll let go when it’s too hot and it can’t accidentally be left in turbo mode.
just an idea..
hIKARInoob
just an idea..
Interestingly, Led Lenser has this feature. Press and hold for 130% output. It’s barely visible compared to 100%, though I do like the idea of this feature for more powerful lights.
KawiBoy1428
Thumbs Up Looking forward to the highly efficient, higher output street lights! Facepalm
Jerommel
Jerommel's picture
lol Big Smile
kramer5150
kramer5150's picture
Last seen: 9 months 6 days ago
Convoy L8 right around the corner!!!… oh geez just take my $$ now!!
