Thanks for the great news!
I wonder what numbers people will be getting for these when FET driven.
I’m excited to see how this does in an L6 with SMO reflector and a FET driver.
Also does anyone think that the OLight x9 will switch to using these before release?
EDIT: Here are the specs from Cree (Sorry for the poor formating)
Size
7x7 mm
Product Options
6 V
12 V
High-CRI
Maximum Drive Current
4.8 A (6 V)
2.4 A (12 V)
Maximum Power
29 W
Maximum Light Output
4292 lm
Typical Forward Voltage
5.6 V White @ 2100 mA (6 V)
11.2 V White @ 1050 mA (12 V)
not really the reason, donuts are due to improper focus, i had donuts with xml, and other single die leds. i also have few multi die led lights that have smooth, even beam with no holes or crosses. it is all about the optic,
some optic covers it pretty good, i tried led engin TIR lens, iirc 83mm diameter, i use it with xhp 50, smooth tight beam. splattered maglite reflector removes any imperfections from the beam of P7 led, thou P7’s had different material used for primary optic, some domes are clear, some a bit foggy. iirc xhp xx domes are not crystal clear, that should help a bit with beam profile,
Really good news! The only downside is that I already purchased a 86 mm OP reflector for a planned XHP70 mod. Now I better should have gone SMO, I think…
I don’t think a op will do bad with this new emitter. I guess I don’t understand why it would. It doesn’t now. I guess I don’t understand how it would act any different then a xml2, or xpl in a op because the dies are a little closer together. I would think it would give the beam pattern people seek from op and give the distance people want in a smooth. Am I missing something?
Speed4goal, you are absolutely right, OP is not bad at all. But for further reach I should have bought a SMO reflector. Should have made that point clearer, sorry.
Nah no one is wrong but basically with this new style XHP it will be more suited to using in an smo reflector then the standard XHP. There should be no donut hole with the updated version. The die should be more uniform Maybe making l throw better who knows.
70.2? It will be just like the XP-G3, L.2 and 50.2 High Output High Heat No throw! These emitters from my experience are not that great in flashlights, well not for my purposes any way, I like a big beam, with down range grunt, not really a fan of just out put, flood with out throw. Did not like the 50.2 J4-1A in my L2 at all, crummy hot spot yellowish gold corona, and it got worse when I shaved it, now this is comparing it to my other L2 similar build and tightly shaved “old” J4-1A emitter. So I’m not bothering with the new 70.2, I’ll keep my stash of (10) or (8) now XHP70 P2-1C emitters guarded carefully!! :+1:
Want more throw de-dome the old XP-G2, XP-L, or even the XHP35/50/70, (not just shaved) you can’t do that with the new emitter’s! I have tried!
I’ll live with the minor artifacts of the “old quad die” emitters and the ability to de-dome them for more “throw’ any day!!
With all this extra output, manufacturers need to concentrate on better heat sinking. I find high output lights rather pointless if they have to stepped down quickly to avoid over heating.
Hmmm…
At some point some professional markets will want to have modern LEDs that can be used in pure throwers, like search lights, don’t you think so?
I find it quite strange actually, that the developments in LEDs are apparently going in a different direction.
Matter of time maybe.
Interestingly, Led Lenser has this feature. Press and hold for 130% output. It’s barely visible compared to 100%, though I do like the idea of this feature for more powerful lights.
