Iām going to keep running it at max power see how it goes i didnt even put a driver in and all springs are bypassed 22 gauge wire so no resistance
Reflow very important to have an excellent thermal path. Also soldered the sinkpad the brass pill (i have a copper pill too but the xhp70.2 is going on there when i can get one!)
Iāve got 3 of the 5000K 50.2ās in my latest scratch build, pulling 21.12A from a pair of Sony VTC6ās for 11,696 lumens. The cells were at rest at 4.13V at the time of the test. The KaiDomain triple reflector makes for a decent hot spot, just a hint of a dark spot but I probably donāt have em perfectly located height wise. Iām using 20Ga Teflon wires, cut out the areaās around the side of the reflector where the pads are for clearance, have filed down centering rings.
You have taken my post to literally by no resistance i meant there is no FET/springs to reduce the current thus its a low resistance as it possibly could be.
It also means that with a regulated driver(either boost, buck, or linear) the more efficient lower Vf led will stay in regulation longer and half a volt means something there.
Boost or buck? yes and and no. Without enough voltage difference between source and load you just shouldn't be using a buck. With too much, you shouldn't be using linear. Once you get to where a buck (or boost) works well, further marginal differences in voltage won't matter, and it becomes a big advantage of a buck. In the transition though I'd turn this around as a disadvantage. Lower Vf led's are bad because they require a buck, and because without one the setup on the whole becomes more and more inefficient.
If you sliced the dome off your xhp70 you would also get a little less lumenās, but more throw.
Then I wonder if the new xhp50.2 is an upgrade or pretty much the same?
One advantage the xhp50.2 may have over a sliced dome xhp70 is less of a donut hole. Then again, I think the K60 has an OP reflector so itās not likely to ever get a donut hole. On a SMO like my L6, the xhp50.2 may have a slight advantage.
Do you guys know off hand if a sliced dome xhp70 has a smaller or larger hot spot compared to a dome-on xhp50?
The XHP-50 and 50.2 fit on the XM-L footprint and can use the XM-L reflector. The XHP-70 is a much larger emitter physically, albeit not as large as the MT-G2. So comparing the 50 to the 70 is not an equal comparison. The 50.2 version has less gap between emitters but not as tight as the XHP-35 so there are still some issues. The 50.2 utilizes a phosphor covering much like the XP-G2 and as such it would be difficult to do a clean de-dome. Slicing the dome may well yield better throw but the center of the hot spot would still suffer from the gap between dies.
Well, itās maybe not as straightforward as that. Depends on several factors. And for the record, whether or not the XHP-50.2 shows a donut hole is reflector dependant, it can still show that just maybe not as bad.
I got the new Eagle Eye X9 today and there was visible donut hole from the XHP-70 beam. I was about to put in an 50.2 and thought about slicing the dome off the 70. That made all the difference in the world in this particular light and itās still making just over 3000 lumens at 4.84A so Iām thinking I might leave it just like this. Since djozz showed that the 50.2 maxes out around 5000 lumens and some 10A, itās doubtful that it will best the 70 in this light without more extensive modification.
So there are always mitigating factors that make it more complicated than simply the emitter.
Edit: Maybe some expansion on my reasoning would help. The XHP-50.2 is similar in structure to the XP-G3. I donāt like the G3 for itās beam profile and am finding a large similarity to this G3 in the 50.2. Sometimes itās not all about power, given an ugly beam profile with odd color shifts the power levels arenāt winning it over for me. Thatās just me though, and just my singular experience with my triple in a single triple reflector. I might find I love it in a different light or different reflector. Wonāt know that until I try and I have a single 50.2 to play withā¦
Dang dunno offhand, but check the CREE datasheet and usually there's a mark on the underside to indicate anode or cathode side - I always forget which is + and - and always looked it up. Finally wrote it down, but my notes are @home . I sanity check all the new LED's now - used to be easier.
Put the two dots on the bottom, plus is on the right.
This is on the XHP-50.2 ONLY! Most modern Cree emitters have the plus on the side of the bond wires. The XHP series makes it more difficult to tell but of course you can always check the data sheet, way at the bottom end.
