Carbon Fibre & Brass Mini Zoomie Build
DavidEF’s first mod post of a little zoomie light got me thinking…. :sunglasses:
Carbon fibre outer shell
Full brass internals
Friction slide zoomie
12mm plano aspheric lens
XP-G2 S4 2B on 10mm sinkpad
10250 cell
Single mode /direct drive (R200)
Magnetic brass cell carrier
Rubber switch boot
Hidden keyring loop
Reverse clicky tail switch
Length - 54 mm
Width - 14 mm
Weight - 12 grams
Max – 300 lm/ 112 lm
You are completely out of this world with this build CRX, and the fastest modder out there. That build took you half a day??
Great zoomie, man!
Thanks very much mate, seven hours. Still not tested properly yet as the JB is still drying :slight_smile:
You never cease to amaze me… Fantastic work!
Thanks mate :+1:
Wow! You’re too amazing! I can’t believe this! It’s beautiful! Great work! :+1:
Thanks mate, and thank you for the idea - I might never have made this light otherwise :+1:
The king of brass strikes once again! Seriously good looking build. What keeps the lens slide in place? Is there an o-ring tucked in there for friction like the SK-68 has?
I love carbon fibre stuff, it’s actually way more affordable than I originally though.
CRX, you are like a magician! You think of it and “poof”, there it is. Excellent work.
Thanks, it is very thin copper that works as the slide stop, you can see the detail in the picture with the red line marking on the brass tube.
Great mod , CRX .
It has become a lot cheaper over the years, I bought a 500mm x 14mm tube for £8, the cars are still a bit pricey though :slight_smile:
If only that were true :wink:
Thanks Jack :+1:
Great build. It would be popular w/ the ladies as a “lipstick light”.
Then it will need a deep red led (650nm).
I did do a red zoomie once… but this light is a big ruff n tumble mans light :smiley:
WOW , great work………talented/genius springs to mind ,yet does not seem to do you justice.
Wow!!! Awesome job!!! And so incredibly fast too. :sunglasses:
Good looking
