Nitecore TM03 and TM28 interest list.
Features
  • Utilizes a CREE XHP70 LED
  • Driven by a dedicated IMR 18650 battery to emit up to 2,800 lumens brightness
  • Ultra-bright dual-mode tactical blaze
  • Dual-switch tail cap designed for tactical use and easy application
  • Mode 1 Suppressing light: Direct access to turbo mode
  • Mode 2 STROBE READYTM: Direct access to Strobe Mode (Chinese Patent:201320545349.4)
  • Four easily accessible brightness levels and memory function for fast boost
  • Maximum beam intensity up to 21,000cd
  • Extensive runtime up to 30 hours
  • 289 meters far throw
  • Integrated metal micro textured reflector for optimal peripheral illumination
  • A power indicator LED hidden in the tail switch indicates battery power
  • Electric reverse polarity protection
  • Temperature regulation and protection
  • Anti-rolling design
  • Toughened ultra-clear mineral glass with anti-reflective coating
  • Constructed from aero grade aluminum alloy
  • Robust HAIII military grade hard-anodized
  • Waterproof in accordance with IPX-8
Dimensions
  • Length: 6.25” (159mm)
  • Head Diameter: 1.57”(40mm)
  • Tail Diameter: 1.18” (30mm)
  • Weight: 7.52oz (213g)(without battery)
Features
  • Rechargeable searchlight
  • Utilises 4 CREE XHP35 HI LEDs, max output up to 6000 lumens
  • Powered by 4 18650 batteries, compatible with li-ion/IMR batteries
  • Max runtime up to 1000 hours
  • Max throw up to 655 metres
  • Onboard OLED display provides real-time data for brightness, battery power, voltage
  • Reflectors with PDOT incorporated
  • Intelligent charging circuit
  • Temperature regulation to prevent overheating
  • 5 brightness levels and 3 special functions available
  • Dual-stage multi-functional single switch provides access to all functions
  • Built-in power indicator to report battery level (Patent No. ZL201220057767.4)
  • Onboard tripod receptacle
  • Mineral optic lenses with anti-reflective coating
  • Retaining rings protect core components from damages
  • Made from aerospace grade aluminium alloy
  • HAIII hard anodising
  • Waterproof in accordance with IPX8 (2 metres submersible)
  • Tail stand
Dimensions
  • Length: 5.59”
  • Head: 2.23”x 2.23” (Height/Width)
  • Tail diameter: 1.97”
  • Weight: 14.6oz (battery excluded)
Arrival of monsters expected by mid of April.
The price will be competitive.
Post in the topic of your interest, not in the PM!
My main thread - active Coupon codes, Flashsales & Deals. Flashlights, chargers, batteries and other popular goods.
Interested!
Interested all,thanks.
Interested Thanks
Interested in TM28 depending on the price
Interested, thanks.
There’s a chance I could be interested. Depends on price. Just been hit by a whacking great bill that’s destroyed my finances.
tm28
thanks
interested pending price and review
Also interested depending on price, but I guess waiting for a review is a good idea :wink:
Int
Interested of course in both depending on the price…
interested
tm28
Please specify - TM03, TM28 or both
Small, depends on the price
interested in the tiny
interested on both depending on price. Thanks
interested in a tm03.
i already have one, but if the price is very good, ill purchase another one.
