Test/review of Samsung INR21700-30T 3000mAh (Gray)
35 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 week 3 days ago
DSC_8691
Official specifications:
  • Standard discharge capacity: min. 3000mAh (1.5A charge 0.1A cut-off, 0.6A discharge, 2.5V cut-off)
  • Rated discharge capacity: min. 2650mAh (4A charge 0.1A cut-off, 10A discharge, 2.5V cut-off)
  • Nominal voltage: 3.6V
  • Charge voltage: 4.2V
  • Standard charge: 1.5A charge 0.1A cut-off
  • Rated charge: 4A charge 0.1A cut-off
  • Max. continuoys discharge: 35A at 25°C
  • Discharge cut-off voltage: 2.5V
  • Cycle life: 250 cycles to 60% at 35A discharge.
  • Cell weight: 69.0g max
  • Cell dimension: Height: Max: 70.40mm, Diamter: max. 21.22mm
  • Operating temperature (surface): Charge 0°C ~ 50°C (Recommended
  • Storage temperature: 1 month: -20°C ~ 60°C, 3 months: -20°C ~ 45°C, 1 year: -20°C ~ 25°C
Samsung%20INR21700-30T%203000mAh%20(Gray)-info
This is the new battery size that is slightly larger than 18650 cells. This cell is a high current cell with moderate capacity.
DSC_8690
DSC_8692 DSC_8693
DSC_8694
DSC_8695
Samsung%20INR21700-30T%203000mAh%20(Gray)-Capacity
This battery can easily handle 30A and more with constant capacity and perfect tracking between the cells.
I did try a 50A discharge, but my battery holder melted before I was finished with the first trace.
Samsung%20INR21700-30T%203000mAh%20(Gray)-Temp-20.0
Samsung%20INR21700-30T%203000mAh%20(Gray)-Temp-30.0
The battery gets warm at 30A, but not too warm.
Samsung%20INR21700-30T%203000mAh%20(Gray)-Temp-40.0
In this discharge the battery is in free air, i.e. it has better cooling.
Samsung%20INR21700-30T%203000mAh%20(Gray)-CapacityTimeHours
Samsung%20INR21700-30T%203000mAh%20(Gray)-Energy
Samsung%20INR21700-30T%203000mAh%20(Gray)-PowerLoadTime
Samsung%20INR21700-30T%203000mAh%20(Gray)-TripCurrent
Samsung%20INR21700-30T%203000mAh%20(Gray)-Charge
Conclusion
This battery is a very good battery and the best high current cell I have tested to date. At lower current there is no reason to use this cell, only when the current is above 10A is this cell interesting.
Notes and links
The batteries was supplied by ENERDan for review.
My test stations is only equipped to handle up to 30A, this means higher current must be done on other equipment.
Compare to 18650 and other batteries
Compare to 26650 and other batteries
Edited by: HKJ on 03/24/2017 - 13:38
Beachlogger
Last seen: 2 hours 51 min ago
Is this the same battery as a 30Q only bigger?
HKJ
HKJ's picture
If it had been exactly the same, the capacity would have increased due to the size increase.
chouster
Last seen: 4 weeks 2 hours ago
Thanks for the test HKJ. Impressing cell!
sac02
sac02's picture
I spit water on my keyboard when I read this.
SubLGT
Last seen: 1 week 10 hours ago
Comparing it at 20A and 30A to its high current 3Ah 18650 peers like the Sony VTC6 and the Samsung INR18650-30Q, the big advantage seems to be much cooler operational temperatures. I don’t think any of the 18650 cells can be safely used at over 18A-19A in continuous use. Looks like the INR 21700 can be safely used at 25A for continuous use. The e-cig guys will be loving this 21700 cell.
HKJ
HKJ's picture
It can be used at safely at 35A as long as it have free air around it (A metal holder can be very close to free air) (It did not get too hot in my 40A test). That is the reason I call it the best high current cell I have seen.
sac02
sac02's picture
I did not know if you meant “best” high current cell compared to only 18650, or to any cell – so I looked up Liitokala INR26650-50A and the 30T performs much better at high current. Very impressive.
cabfrank
Last seen: 7 hours 19 min ago
Very impressive indeed. If the next generation includes higher capacity, sort of like the change from the 25r to the 30q, they will be really amazing.
HKJ
HKJ's picture
I hate it, it means I have to do some extra work.
A new battery holder looks like this:
But I change the connecting wires and this means when it looks like this I have work to do:
KawiBoy1428
KawiBoy1428's picture
Last seen: 47 min 16 sec ago
WOW this 30T is one serious battery, thank you for testing and um…
Sacrificing!! Shocked
KB1428 “Live Life WOT
itsonlyme
Nice cell. That’s an interesting battery holder. Did you buy it or make it? Any links if you bought it please?
hIKARInoob
hIKARInoob's picture
Last seen: 50 min 2 sec ago
Samsung 30T’s motto: “HKJ’s equipment can’t handle my power.”
How’s that for advertising?
ferongr
ferongr's picture
Probably the best e-bike cell it seems. Unless you have an underpowered EU-compliant motor.
Tom E
Tom E's picture
Last seen: 13 min 8 sec ago
Incredible! I want one!! Or 20! Excellent job once again HKJ!!
SubLGT
Samsung introduced their 21700 e-bike battery in 2016: 4750mAh and 9A max discharge.
sac02
sac02's picture
Wow, 4750 and 9A. That does seem like an ideal e-bike cell – lots of capacity and just enough current. What size / form factor?
HKJ
HKJ's picture
It is from fastech: https://www.fasttech.com/products/1425/10024652/5339401
Lopan
Last seen: 3 weeks 6 days ago
Cylindrical, 21mm diameter and 70.0mm hight. In case that was the question.
Enveck
Enveck's picture
Last seen: 3 years 8 months ago
Where in the world can I order these cells? I’ve been using the Sanyo 20700B, but I really want to get my hands on those. Any info or links would be greatly appreciated.
hIKARInoob
Welcome to the club Enveck! Perhaps alibaba? I don’t know about shipping and stuff, I just googled this. https://www.alibaba.com/product-detail/Sam-sung-3000mah-40A-3-7V_6066868...
Cheers!
Barkuti
Barkuti's picture
Last seen: 2 days 9 hours ago
Mooch tested and is using the 30T, just asked him where he got the cells.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Enveck
Enveck's picture
Thanks, all I’ve found so far is Alibaba…. I guess they haven’t hit state side just yet. Working on getting an order thru Alibaba right now.
snakebite
snakebite's picture
Last seen: 1 day 23 hours ago
if the resistance that made all that heat were eliminated the test could be more accurate.
btw i rebuilt some versapak sticks with the 30t and they have a slight edge torque wise over the 25r.
PERMABattery
PERMABattery's picture
Last seen: 3 years 2 weeks ago
Yeah, Samsung INR21700-48G, supporting maximum discharging current at 9.6A, maximum pulse discharge current at 35A for 10 Seconds, 25A for 30 Seconds, and 18A for 60 Seconds. The nominal voltage is 3.6V, charging voltage is 4.2V. We are working on a new e-bike battery pack with just this Li-ion 21700, will come back here once there is any update. Smile
Custom Battery Pack Solutions
shadockan
shadockan's picture
Last seen: 1 month 1 week ago
From the same company ….
Enerdan ….
WalkIntoTheLight
Interesting. I was wondering what was the point of 21700 cells, when they are heavier and larger than 18650 but with no more capacity. It looks like high discharge is the answer!
I wonder if they have better cold-weather performance, too? For electric cars.
Barkuti
Barkuti's picture
WalkIntoTheLight wrote:
… I was wondering what was the point of 21700 cells…
WalkIntoTheLight, there's really no point other than the one thought by their creator/designer at Tesla Motors. Battery pack assembly cost reductions, among other reasons.
It's not the cell format what makes a cell good, but the technology and expertise which goes by it. There is a 18650 cell with this sort of high discharge technology inside or thereabouts.
However, this sort of high discharge cell technology isn't really needed for a vehicle unless you need a racing car or it's battery pack is too small. For a more normal vehicle lower discharge (C rating) cells are fine. As long as your battery pack can comfortably output the average maximum power draw of its associated electric motors and electronics everything is fine.
Cheers Party
WalkIntoTheLight
Barkuti wrote:
However, this sort of high discharge cell technology isn’t really needed for a vehicle unless you need a racing car or it’s battery pack is too small.
I was wondering if high-discharge cells perform better in cold conditions, than regular cells. If, for example, a high-discharge cell would suffer from less voltage sag in -20 degree weather, it might be useful in an electric car for winter conditions. Then again, I think they heat the batteries anyway, so maybe it’s not necessary.
The_Driver
The_Driver's picture
Last seen: 1 day 21 hours ago
I was wondering if high-discharge cells perform better in cold conditions, than regular cells. If, for example, a high-discharge cell would suffer from less voltage sag in -20 degree weather, it might be useful in an electric car for winter conditions. Then again, I think they heat the batteries anyway, so maybe it's not necessary.
For flashlights and especially headlamps this is an important aspect. High-discharge cells are much better in the cold compared to high-capacity ones! See here (in German).
shadockan
shadockan's picture
There are also batteries with high capacity, and a high C-rating rate.
Samsung 5300mAh 10 – 15A
Samsung 4000mAh 20 ++ A
Sony Vxx 5000 mAh 20 ++ A
Panasonic / Sanyo 21700 xxxxmAh xxA
There is a future of this magnitude.
The technology of these batteries seems to be superior to the 18650 in many areas.
We will see them in the future …..
