Hi, my doubt comes from the problems that had the S41S at first, if in the black version are solved like the last S41S.
I don’t really know … I own one of the first S41 (received back in June) , and it worked perfectly out of the box .
Still works great .
I have both versions. The original S41/E14 seem to have a yellow tint shift and S41S(updated) does not. I prefer the S41S, but not the weight…so I now use a S41S head with the S41 18650 tube/tail cap. It makes it a much lighter flashlight.
Thanks for your opinions, i think i will buy the S41S in stainless steel. Of course with Nichia.
Where are you guys getting your 18350 cells from? All the shops I’ve looked at are either out of stock or won’t ship to Canada (FastTech i’m looking at you)
Thanks in advance.
He ships to Canada… Wholesale Li-ion Batteries | Liion Wholesale – Tagged "efest" – Liion Wholesale Batteries
Good find. I need some batteries.
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight - Pre-order@ $29.99
Do you know price with coupon , when it will be available ?
Thanks
Already requested. S42 should arrive at the end of the month.
Do you know details about the driver?
Is it similar to the S41 driver? Similar firmware but without OTC? Does it realy have this performance?
Is this a firmware from the BLF or does Astrolux or the manufacturer has changed the Firmware to eSwitch?
Strange that they don’t have the black one with a copper ‘engine’.
Indeed!
At least they should offer it as an option (for a few dollars more?).
Maybe they are willing to offer it as a special for BLF?
They already have the cost/trouble of sourcing two different heads.
Maybe they should offer a mix and match / build your own version?
Is it just me or does the Colored version look like the lens ring is cross threaded and crooked? Leaning to the right maybe?
Sure looks like it’s not too well made…
I’m guessing it’s a poor photoshop job. The S41s has a crooked head/body as well.
I’m not lucky with s41s. Ordered 2 times, got problems both times.
First time, ordered S41a head. Arrived 4 days ago. Led’s dome damaged eventhough I haven’t unscrew it’s head(may accidentally unscrew the bezel when I unscrew the head but I’ts just 1/4 turn at most). I can noticed it only in moonlight mode. 4 leds still work fine. This may reduce it’s efficient a little but still work fine in real life. I contacted banggood for compensation and still waiting for result.
From the picture, it’s in moonlight mode.
Second order, I ordered SS body tube and SS tail cap(they’re out of stock when I order the head). Got them today. Tail cap is fine but body tube has strange color. Don’t know why, may be because they forgetting something or do coating before machining or whatever. I ordered it because of it’s looks, though. I contacted them and waiting for reply.
Sorry for low quality pics. My cheap cellphone’s camera just died and these pics were taken by a cheaper one. lol
TIR can be easily replaced. PM me if you need help for your order.
